Page 1 of 3 123 LastLast
Results 1 to 40 of 85
    Veteran Member Four Rings MattboyR32's Avatar
    Nov 28 2006
    Orange County, CA, USA
    BC Racing coil over install help
    Installing the bc racing cool overs. Do I need to take this rubber and metal thing off the top of the suspension (the thing that the control arms are bolted to)
    Cheers
    B7 RS4 6MT Daytona Grey
    JHM 2.75" catback non-res, piggie pipes, 034 transmission, engine mounts, strut mounts & end links, Apikol diff mount, Hotchkis adjustable rsb, Escort 9500i (HW), JHM lightweight rotors, JHM intake manifold spacers, BC Racing coilovers,
    RIP: B7 S4 DTM 6MT Dolphin Grey
    JHM Tune, Corsa Catback, Piggie Pipes, Bilstein PSS9, RS4 Reps, Blackvue Car Blackbox (HW), Escort 9500i (HW)
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Remove the rubber on the top brace, the struts have it all built in. You may have figured that out already though.
    Nov 28 2006
    Just found out from BC racing that I need to remove that. Thanks mate!!!
    Senior Member Two Rings SQ RS4's Avatar
    Feb 02 2015
    2008AudiRS4 2016AudiS6 2009NissanGTR 2016HondaPilot
    Clarksburg, MD
    What made you go with these over the KW V3, Bilstein PSS9, or even the B14?
    Nov 28 2006
    price primarily
    customisability, obviously there is some work to be done, but you can order with swift springs at different spring rates
    each part is replaceable fairly easily
    plus it has the adjustability
    to be fair they are maybe not as "easy" to install at least for the fronts with the removal of the oem bushing thing. but outside of that, there is no real difference to the rest of the aftermarket coilovers. rears were straight forward. Interestingly the springs were shorter than the KW HAS springs I had on. which made install super easy although the rubber bushing provided by BC was much thicker, so I might have to install that if it sits too low. I also kept the KW HAS adjustment perch for the rears. It's such a pain in the butt to adjust the rear ride height, but the KW HAS has this hex bit hole that with an extension you can use to ratchet it up and down instead of having to lower the whole subframe that the others. So would recommend getting that! I know the bilsteins don't have that nifty feature.
    I didn't go the bilsteins because I had them on my B7 S4 before and found that the front bounced quite a bit when set to soft.
    Also got a great deal from 65vetteC6! :)
    Feb 02 2015
    Clarksburg, MD
    Good to know - curious to hear your impressions of how they perform. I was just curious as I was recently shopping for coilovers and ended up getting the KW V3.
    Established Member Two Rings DAYTA's Avatar
    Dec 30 2014
    Over on the NSX forums, the BC Racing coilovers have received some very solid reviews. Many guys liken them to a cheaper and slightly lesser alternative to the KW V3s which are the gold standard for the NSX. I'm running KW V3s on my NSX and I love them.
    However, given that my RS4 is higher mileage and a DD, I don't want to spend $2k+ on a set of coilovers so the BC Racing setup has me interested. The problem is that there are zero reviews for the S4/RS4 applications so I'm also curious to hear your impressions.
    Daily Driver: 2016 VW Golf R
    Family Hauler: 2018 BMW X5 xDrive35i
    Weekend Toy: 1997 NSX
    Nov 28 2006
    Mr NYC_Legacy has them installed already....
    I'll hopefully have them installed this weekend! :)
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by MattboyR32 View Post
    That I do with Swift Spring as well, custom valved to my specifications at 14k Front, 22k rear springs. The ride is a bit harsh for NY but that was to be expected with the track spring rate I ordered. I also ran BCs on my B7 S4 and they never let me down. Cheers Matt on your new set up.
    "Brake last, finish first."
    Feb 15 2007
    Link to these?
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Nov 28 2006
    https://store.bcracing-na.com/br-ser...2008-p828.aspx
    As requested. :)
    I just have the standard 12k front/rear springs from BC. Figured I would give them a go before investing in the stiffer swift springs that Mr NYC has. :)
    Nov 28 2006
    So now I have to get this bushing thing off the thingamebob any thoughts short of blunt force? The metal inner bit spins easily enough but a quick pry with a flathead did not do anything.
    Sep 20 2015
    Use a punch and knock it out. Worked for me and took 3 mins
    Nov 28 2006
    Yay! so some progress made today. Got the oem bushing out of the hat thingy!
    Got the rears done in entirety!
    Now just waiting for the 034 strut mounts to arrive before putting the fronts back together.
    By the way, can anyone tell me the torque and yield specs for the rear subframe bolts. I can't find it anywhere.
    Cheers,
    Matt
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Matt, do you need to re-insert the metal piece with the new strut-tower bushings you got from 034?
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Cheers,
    Matt
    Bentley calls for 110 Nm + 90° (for all 4 bolts) , same as front subframe.
    don't forget to replace the bolts
    Nov 28 2006
    Quote Originally Posted by jakeoboy67 View Post
    thanks!
    Nov 28 2006
    Quote Originally Posted by ven0m View Post
    you mean the metal thingamebob that attaches the rubber spring bushing to the top hat thingame? No, once out, it's out. plus it curves out far enough that the coilovers don't actually clear it, so the coilovers would be balanced on this non-structural piece of metal.
    Sep 20 2015
    If Im not mistaken I think he is talking about the strut mounts from 034 that comes as two piece shells. You have to remove the circular plastic with metal washer to install the 034 mount for the strut tower.
    Nov 28 2006
    ahhh that, yes, two screwdrivers seemed to get the two circular plastic pieces that hold all the parts together to come apart. They sort of slot together, pry back a bit of the rubber from the mounts and you can see how they are holding together. :)
    Nov 28 2006
    Anyone got any guidance on best way to remove the DSC and lines from the car? I thought I saw a post ages ago that it was easier to just cut the pipes instead of trying to unthread it all? If so what to use for cutting the pipes? hacksaw? tips?
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    Just buy the caps to cap them.
    Nov 28 2006
    did that. but seems sort of pointless to leave it in...
    Jan 16 2017
    Toronto, Ontario, Canada
    Sorry if I'm going a little off topic here, just wondering why you're ditching the KW HAS?
    Nov 28 2006
    want the flexibility to adjust the damping. fast transitions in cornering tend to upset the car, the weight transfer from one side to the other is not handled well. So looking to tie that down some more. Otherwise the HAS kit/DRC was perfect for daily driving. really soft enough to cope with normal roads and the ability to lower it for looks is also nice. Just looking to take the next (small) step in handling improvement for the track. This car for me is a garage/track car. Not a daily anymore like it was when I had the HAS kit installed.
    Mar 11 2008
    B7RS4 & e46Ms
    What I do when I'm adjusting ride height in the rear, is use the old bolts for the multiple iterations of dropping and tightening the subframe. Once I finally get the ride height set and I'm happy, then I replace the bolts one at a time with new ones and torque to spec.
    FRRG AZ Ring
    Nov 28 2006
    great tip. the KW HAS height adjuster allows an allen key on a long extension to be passed through from the bottom control arm up the center of the spring and holds the base in place so you can turn the adjuster. no need to lower the subframe to adjust it anymore! :) yay!
    May 10 2015
    Slovenia
    Same is with the rear-base on the KW Clubsport. Allen-key to hold it in place.
    (yes finally got the Clubsport!! )
    James May: "Yes."
    Nov 28 2006
    Best laid plans right... So the KW adjusters for the rear are not long enough. The rear is too low. :( so everything comes apart and modifying the rubber bushing to sit between car and kW adjuster. Lol
    Nov 28 2006
    Modifying the rubber bushing to accept the KW adjusters was too much of a ball ache. So in went the bc racing adjusters. If I update the stock bc racing springs I'll order them an inch longer and put the kW height adjusters back in.
    Nevertheless all is back together and first drives are positive. All the way soft is firm but not ridiculous. Where the drc would sometimes bounce the compression and rebound only happens once. So far so good. Just got to finalise heights front and rear! Yay!
    Jul 19 2017
    Quebec/Canada
    Hi Matt,
    Are you still happy with your BC coilovers ?
    Nov 28 2006
    totally. In soft they are a bit stiffer than KW HAS springs, but not crazy stiff. In hard, they are fantastic. The tenability for the track is so much more helpful. So much easier to dial out understeer. My most recent event at buttonwillow saw no understeer at 10/15 f/r. Love them. I don't see the need to switch to swift springs at the moment. They came with the stock 12k springs front/rear. There is enough variability in the damping to account for anyone unless you are doing serious track stuff.
    Jul 19 2017
    Quebec/Canada
    Thanks for your reply in and on MP.
    I'am just hesitate between BC coilovers and B8 shocks with my H&R srings and H&R ARB.
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by g-shock View Post
    I just ordered a set of the BC coilovers with digressive valving (DS series) and 12kg/14kg Swift springs, so will have another data point for you in a few weeks. I won't have a point of reference for comparison though as my RS4 came with Stasis Motorsports which needed to be serviced (and the parts delay there is what prompted me to pick up another set) so the ride was pretty much garbage (significantly poorer than my B6 A4 with Eibach pro-street-S coilovers)
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Jul 19 2017
    Quebec/Canada
    Thank you Matt Devo, I'am waiting for your feedback
    Jul 19 2017
    Quebec/Canada
    [QUOTE=MattboyR32;12234175]Installing the bc racing cool overs. Do I need to take this rubber and metal thing off the top of the suspension (the thing that the control arms are bolted to)
    Cheers
    Is it the dampering setting screw on the top of the spring, in the U gap ?
    Account Terminated Four Rings
    Apr 30 2017
    yes
    Jul 19 2017
    Quebec/Canada
    Thanks funky.
    Jul 19 2017
    Quebec/Canada
    Got my BC
    Audi RS4 B7 2007 - Misano red
    20'' peelers - H-pipe
    82 000 Kms / 51 000 Miles
    Jul 19 2017
    Quebec/Canada
