Alright so the old thread was flooded with lots of posts, i figured I would start a new one with all of the details without having to go through 5 pages of comments making things a bit easier.
It started out as a no crank/ no start problem about a month ago. Out of about 100 tries, around the 80th attempt it randomly cranked+started up then died after a few seconds and wouldn't crank or start again. So I replaced the battery, battery terminals, removed and cleaned the connections, replaced battery ground wire, checked other ground wires, replaced alternator, replaced ignition switch, checked fuses, listened for fuel pump(I can hear it).
Then after replacing the starter yesterday the car would turn over and after a little hesitation it would crank up but then immediately stall out. If I tried to turn it on immediately again it would just turn over and over etc without cranking up. If I waited a few minutes then it would again start after a little hesitation then immediately die. This morning I attempted to start it but it just turned over and over and over without every cranking up. Then I tried it again and it wouldn't do anything, back to the no crank/no start symptoms since this morning. I jumped the starter posts to each other and I can hear it turning strong and fast like it's supposed to, but when I turn the key it does absolutely nothing. Dash lights come on, but when I turn the key I hear nothing but the fuel pump.
