Good Morning Everyone.
My 2001 Audi b5 s4 is misfiring.
Code reads only p0300.
All coils fire except cylinder 1.
I do not know why.
Here's what's been done:
-swapped working coil packs around to cylinder 1 and they stop working.
-unbolted & pulled coil packs up a few inches, separating from plugs, to hear the spark firing from coil pack to plug.
-The above happens on all except Cylinder #1.
-Pulled spark plug form Cylinder #1, and it looks fine. ~15,000 miles old.
-There is no water in ECU.
-The plug from wiring harness to coil pack on Cylinder #1 looks fine.
-Just started doing it in the middle of my drive last week, then stopped, than started again the next day.
My Questions:
1) Would a clogged injector be known by the ECU, and thus stopping any signal to fire coil pack on cylinder #1?
2) Even if Cylinder #1 had a bad plug, a known good coil pack should fire (just like my experiment above) when pulling the coil pack off the plud for a few inches while car is running.
3) Any other suggestions?
Thank you all.
Cheers.
