Results 1 to 6 of 6
    Veteran Member Three Rings Olde_English's Avatar
    Dec 07 2016
    Singlespeed S-Works Epic Hardtail and Specialized Epic Evo
    Prescott, AZ
    APR DP and Upgraded Mufflers?
    So I recently got the APR DP and HFC with the stage 2 reflash.
    From reading on the forums it seems that most of the power I can get from the exhaust/DP is from the DP and reflash and that the Catback would be minimal gains but better sound.
    I was wondering if I could just get aftermarket mufflers to get a better, deeper sound while keeping between the CC and the muffler the same.
    If so what kind of mufflers would work? My car is a 2009 A4 Avant (Dual Exit).
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by Olde_English View Post
    Probably not worth to do... The dp actually brings some nice tone to the stock mufflers!...
    But maybe a set of magnaflow mufflers to replace the dual stock ones may work well.
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Dec 07 2016
    Prescott, AZ
    Actually looking through the exhaust thread Im thinking I will go the route Poodini went. But I would probably need 2 mufflers since I have dual exit, right? Or is there just one center muffler that splits out to the two mufflers at the back?
    Veteran Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    You could do either setup. If you want more noise reduction, then go with dual rear resonators/1 per side. If you want a more aggressive tone, straight pipe off a single middle resonator which had a dual outlet.
    Dec 07 2016
    Prescott, AZ
    Quote Originally Posted by Poodini View Post
    Thanks again man. This will probably be on the back burner until I get the 3.0 IC installed
    2016 Sepang Blue B8.5 SQ5 | 034 Stage 1 | CTS Turbo Intake
    Senior Member Two Rings inception's Avatar
    Mar 19 2015
    2018 Q7 3.0T
    phoenix arizona
    you can also do magnaflow muflers in the middle and rear
    2018 S6 APR Stage 1
