I had the opportunity to do some testing on the OEM upgrade charge cooling that I did versus the Revo charge cooler.
SETUPS:
OEM+ Setup: This is the the B8.5 OEM dual pass center heat exchanger with the added B8 side mount heat exchanger. This was performed on 2/23/2017 at approx 6:11pm. DA was approx: +1542 with an ambient temp of approx 74 degrees F.
Revo Charge Cooler: This is the Revo center heat exchanger with the B8 side mount heat exchanger setup as a divorced system running 95% water and 5% coolant. This was performed on 2/25/2017 at approx 3:59pm. DA was approx: +1842 with an ambient temp of approx 83 degrees F.
Both sets of runs were performed on the same tank of approx 96-98 octane mix of Shell 93 and Sunoco 100 octane fuel.
PHOTOS:
The core of the Revo charge cooler measures 22.1 inches Wide x 17.15 inches Tall x 1.6 inches Deep
RESULTS:
SUMMARY:
The results have been consistent on back to back runs now. The Revo charge cooler is performing significantly better than the OEM setup.
Over a full 3rd gear pull the rise in IAT for the stock setup was a total of 25C. It rose from 49C to 74C.
Over the same 3rd gear pull in worse ambient conditions, the rise in IATs for the Revo Charge cooler was a total of 14C. It rose from 45C to 59C.
Timing was also increased from a max of 23.25 on the stock cooler setup to 25.5 degrees on the Revo charge cooler setup with no other changes made to the programming, fuel quality, or vehicle and under worse ambient conditions.
Overall i'm extremely pleased with this setup. If anything I went in with a bias that this may not have been a very good bang for the buck purchase but it has exceeded my expectations significantly. This would be my second purchase after tuning and a pulley.
