Results 1 to 22 of 22
Thread: Turbo longevity
    Jul 31 2016
    Montana
    Turbo longevity
    I was browsing an allroad forum and reading a thread theyhad on how to help stock turbos last as long as possible seeing as how they have to pull the motor to replace them. Don't know why I was reading this especially about an all road.
    The top suggestions were:
    Let the turbo properly warm up.
    Let the turbo cool down (probably only needed if you were really beating on it as good synthetic oil and an oil cooled turbo do a lot)
    And the last most common recommendation was to get rid of the cats with a test pipe or go high flow cat as they said heat kills the turbo seals especially since the cat hangs right off the the turbo.
    Realistically for our cars is there anything else to help the turbos last a long time? I know the turbos are cheap but taking care of the one you already have is always a smart choice. What about cat deletes, useful or no in relationship to turbo longevity? (Regardless of emissions) I can see benefit of getting the cat out of the engine bay for heat etc,
    Aug 19 2013
    minnesota
    Well you need your cat to calculate the fuel-air mixture. There is always an upstream and downstream oxygen sensor on either side of the catalytic converters. So unless they're tuning that whole equation out I see that possibly being harder on the turbo
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Nov 07 2010
    South of Heaven
    Quote Originally Posted by jacobsen View Post
    You do not need a cat, the second O2 sensor is simply an emissions device and has nothing to do with how the car runs. On the B6 there is a wide-band pre-cat O2 sensor and narrow-band O2 sensor post-cat so they would able to use both if they wanted to which they do not. The second O2 sensor simply makes sure the emissions are dropping enough to show the cat is working properly. Most of the heat a turbo will see will come directly from the engine although ambient heat from the cat would not be all that great. What the OP mentioned above are all good points but one that is missing is using high quality oil and changing in frequently. The harder the car is being driven then the sooner it should be changed.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Aug 19 2013
    minnesota
    Motul is king
    Jul 31 2016
    Montana
    I did say using high quality synthetic oil but did leave out regular changes with a proper sized oil filter...I did notice a typo in my original post it should say water cooler turbo not oil cooled turbo.
    2nd o2 is remedied with a spacer or having it tuned out, no biggie. More along the lines of heat effects from cat being off the turbo.
    Senior Member Three Rings dalazybastard's Avatar
    Apr 08 2016
    Orange County, CA
    You're pretty much on the point about oiling and operating temp.
    One thing I would add is proper oil change intervals.
    I never heard anything about the cat causing heat buildup on the seals. I always thought that was due to improper warm up and cool down.
    Just a couple B5's, you know.
    Jun 21 2005
    Milton, Ontario
    The only time a catalyst would cause heat build-up is if it is clogged up and creating abnormally high back-pressure.
    Otherwise the other points stated are spot on for turbo care.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by SleeperAvant View Post
    This ^^ a plugged cat will kill a turbo pretty quick, for some reason I've had to remove/replace the cats on my B6 1.8t B5 1.8t and B5S4 and my wifes old 2.8 car previous owner removed them and the replacement B6 we got just set an engine light for the cat. It must be a german car thing as I've never had to do a cat on any other car I've ever owned.
    Both B6s the stock turbo lasted 120k miles, the B5S4 stock turbos 180k miles and my B5 1.8t is still going strong on the stock turbo at 180k miles.
    Dec 16 2014
    Quote Originally Posted by seanf86 View Post
    I just rolled over 120k and am wondering if I should pull it and take a look.
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by JKCutler3 View Post
    Get an inspection camera and pull the front o2 and check it that way
    Aug 19 2013
    minnesota
    A lot less work haha
    Veteran Member Three Rings red4life5's Avatar
    Dec 29 2016
    2004 Audi S4 Avant
    Cleveland, OH
    Motul is king
    I agree with that. I use 8100 excess. Does one need to use the "specific" motul oil?
    2010 A4 S-Line Prestige
    2004 S4 Avant Greenwood Green
    2011 A3 K04
    2008 A3 -Sold
    2010 Audi A4 K04 -Sold
    Aug 19 2013
    minnesota
    The specific is not as good as the 8100 x-cess it has a lower TBN.
    Aug 19 2013
    minnesota
    But Mobil Delvac 1 SHC 5W-40
    has an enormous TBN 16!
    This is my new favorite oil lol. I'm going to try this stuff out next Oil Change.
    For the record Laboratory Testing shows motul oil to be pretty much the best. The molecules don't break down during testing.
    Apr 15 2014
    Ottawa/Gatineau Canada
    Smart!
    Dec 16 2014
    well played sir. well played
    Jun 21 2005
    Milton, Ontario
    Another method would just be to run the car, then inspect temperatures pre-cat and post-cat with a laser temperature gun, aiming it at your exhaust pipe. If they are virtually the same temperatures the cat isn't the problem, however if the pre-cat temp is much higher than post-cat temp than you have an issue.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    What would help is to know what the turbos typically fail from and what oil was used. Coked line? A bit more insulation on the feeder and make sure a synthetic oil is used. Coking in the bearings, address heat soak and again verify that the right oil was used. Lots of ways that a turbo can go, not all can be fixed with PM.
    Aug 19 2013
    minnesota
    And lo Jesus said to Thomas, T6 is good group 3 but group IV and V motul is the right thing to do. For if you could find delvac SHC 5w40 Within your land you should consider it too IV/V perhaps better even than motul as it has a higher Flashpoint and a TBN of 16. Whereas of the three T6 has the lowest flashpoint of the three.
    The question of viscosity and oil filter efficiency is of great question. From the oil pump to the turbo that is. What is better thinner or thicker. Thinner will go faster but will it cushion the bearing as steady, thicker will be slower but will it cushion the bearing firmer? I think there are three most important parts of motor oil friction, Flashpoint and TBN. I've done my research on the various oil filters that fit the B6. One of the filters that will fit on the B6 which has the same bypass pressure will actually go down to 3 microns.
    WP1144 x2 internal filters 3@50%-6@99% micron and 14@50%-36@99%. bypass 2.5. operating pressure 14 bar. GPM flow 6.87.
    950/4 single filter. 20@50% 50@99% micron. 2.5 bypass. Operating pressure 14 bar. GPM flow 15.85.
    The two filters are very much alike other than the Micron rating and the gallon per minute flow rating. My question is does viscosity grade effect gallon per minute flow? And if so, would the wp 1144 be riding with an open bypass in the B6 because of the finer filtration restricting flow? How much does the oil pump flow per minute?
    I'm going to copy this info over to the oil filter thread. The wp 1144 is used in a lot of small displacement diesel motors period we're such and particles May matter more as there are tons more because it's diesel.
    Jan 10 2013
    03 A4 Avant 1.8TQ
    South San Francisco, CA
    My car is at 165K and the turbo recently cracked at the wastegate. Fun times. Swapped in a used turbo with 130K and in good condition. Still getting a slight underboost but its not dumping all the boost like before. Hoping just an N75 but not worried anyways bc I just picked up a 2015 Mazda6 GT to replace the B6 so the B6 needs to be sold
    //Auto Union Bay Area : NCAC Member : Motoza Stage 1
    Veteran Member Four Rings MCT9891's Avatar
    Jul 06 2009
    2008 VW Jetta Wolfsburg 2.0T 6DSG
    Staten Island, NY
    It's worth mentioning that the 2.7T is more of a turbo-killer than 1.8's due to the location and immense heat the turbo's are put through...
    Jun 21 2005
    Milton, Ontario
    Quote Originally Posted by Kevin C View Post
    I personally run Rotella T6. I've read about BAT users on VW Vortex using high ZDDP racing oils like Brad Penn 20w50 for further protection, especially those built engines that see high boost and high rpm.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
