Page 1 of 3 123 LastLast
Results 1 to 40 of 111
    Jun 04 2012
    Greenville NC
    JHM Tune, Gutted Cats & Intake Manifold Spacers... your thoughts
    Is anyone running a JHM tune, gutted cats, and intake Manifold spacers? I'm trying to determine how much power I'm looking at with a combination of just those three things.
    Jul 15 2014
    Cape Breton Island
    ~30hp + ~50% better throttle response from no heat soak and tune.
    Worth it.
    Jun 04 2012
    Greenville NC
    Awesome, that's what's I was hoping to hear
    Jan 29 2010
    north ga
    I did have that......at one point.
    It's probably the best bangs for your buck you can do after getting a catback
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    when you get it, log it blocks 003, and 031. Then send it to me.
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    No, you're not going to see 30 HP with gutted cats and a JHM tune.
    In terms of outright power delta, the JHM tune only addresses ignition and fueling. It doesn't change the cam timing to my knowledge.
    Why it doesn't I have no idea, but my observations of my own car with catless downpipes is that you loose a ton of torque unless you keep the cam lobe angles separated much more than the stock cam tables request.
    Also, I don't like gutted downpipes as you're creating a world of headache by making an expansion point right after the exhaust. This will introduce resonant frequencies which can result in reversions at certain portions of the RPM band.
    Just spend the whopping $300 and get the SSautochrome ones. I've had them on for some time and have never had any issues with them.
    For a tune, I'd recommend calling Steve at Fabspeed. As I've mentioned in numerous other threads. I worked with him on the base calibrations and he knows tuning inside out and backwards.
    Jun 04 2012
    Greenville NC
    ^ great feedback, I'll give him a call for sure. On another note, anyone know what a typical Audi/vw shop would charge to clean my heads and reseat the valves? I could do this on my own, but without another $150 in tools and numerous hours of labor, I believe it would be easier to get someone else to do it (depending on the price involved).
    Jan 14 2009
    Audi's
    Stick with the JHM tune its proven and really transforms the car. With a cat-back, DP, Tune, and JHM IM you should be able to put down 300-330WHP
    Jan 29 2010
    north ga
    Quote Originally Posted by ZimbutheMonkey View Post
    The fact you think gutted pre-cats are a bad idea is ridiculous.
    They help you in several different ways and are a free mod you can do in your own garage. Discouraging people from this mod really isn't the thing to do (IMO). You say there is a certain point on the RPM band where there is a possibility of having resonant frequencues......well so damn what? All you have so far is an assumption and we know It helps the car way more than stock for the other 95% of the powerband. Also it gets rid of the air restriction that is put directly after the manifold. The pre-cats main function is during an initial cold-start while the main cars heat up. After that all they do is trap TONS of hot air in our already hot engine bays.
    Jun 04 2012
    Greenville NC
    ^ which is why my pre-cats are being gutted at this moment. Free mod, better sound, and better power. Thanks man.
    Jun 09 2014
    BMW E28 with S54 Swap, rack and pinion conversion, vacuum brake conversion
    Jacksonville,FL Lincolnton,GA
    Quote Originally Posted by BCsniper View Post
    He was comparing piggies vs true downpipes. Piggies introduce strange harmonics with the expansion chamber that used to be a cat. Think two stroke exhaust tuning, as that is what you are essentially doing. Two stroke exhaust tuning on a four stroke motor will give you some strange pulse timing.
    Nov 12 2015
    Oregon
    I gutted my pre cat's. Now I have a strange harmonic sound coming from the empty cavities that once were cat's. As soon as I let off the gas I can hear what sounds like exhaust pulses getting mixed up. So i feel like gutting them kindof helped power.... maybe a little bit. Would I have done it knowing what I know now about cam phasing and resonant tuning.... probably not. Yeah it's free, but it sounds like crap now. I'll be ordering new DP'S. Just my .02
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    So, would it be viable to do just put a straight pipe in place of the precat then?how would the o2 spacers work then? Thanks. I hate drone and would rather not have it in my vehicle but want to get them out.
    Jun 04 2012
    Greenville NC
    So, this problem could be eliminated by gutting both cats right? But would my tune clear the CEL in that case, and pass emissions? My goal is more power and a better sound, my drawback is extra money to spend after doing the timing chain repair.
    Jan 29 2010
    north ga
    Quote Originally Posted by VinnysS4 View Post
    Funny how the other few hundred people who've done the mod didn't experience this issue. The sound is changed after gutting the pre-cats but I would expect so after cutting out that much material. Never did I hear like you're describing.
    Jun 04 2012
    Greenville NC
    I agree, I've read so many threads and posts about gutted precats and this is the first time I've ever heard this issue. 🤔
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    i got my car with the cats gutted.
    car smelled like crap. and pisses everyone off behind you.
    2014 SQ5 P+ | 034 Stage 2 ECU + TCU | 034 190mm crank pully | 034 Street Density motor mounts | 034Motorsport S34 Carbon Fiber Intake | Merc Racing HX V3 | Bilstein B8's w/ H&R Springs | 034 Trans insert | RSNAV 10.25
    NEW EDM MIX APRIL 2021 https://soundcloud.com/matt-scheinwa...in-my-basement
    Nov 12 2015
    Oregon
    Well I'd love for someone to hear it if they are local. I read a LOT of reviews before doing it. Everyone raves about this mod. I understand the logic of getting the heat away from the engine. The car sounds better and feels a bit more responsive, but I will be going with catless downpipes soon with my tranny swap and timing job.
    My build log
    Jan 29 2010
    north ga
    I replaced mine with longtube headers. .....the best solution in my opinion
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    I'm running FI 2.5" downpipes that came with metal cats in the pre cat position. Got these used, and I gutted the cats as they were starting to melt and collapse in the center.
    So, to address the other comments, there is a huge torque loss around 1200-1800 rpm, the smell is atrocious, and yes, weird roaring sounds when accelerating from a stop.
    The only benefit as I see it is subjectively better acceleration at higher speeds.
    Jun 04 2012
    Greenville NC
    JR, any chance you can get a video with the sound you're speaking of?
    Jul 15 2015
    Rochester NY
    My wife's car sounds a tiny bit (I mean tiny) more throaty, but doesn't smell any different and seems to drive as usual, with the precats emptied. Still have the main cats.
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 03 2014
    2009 Gray A3
    California
    Gutted my front cats last week. No unusual smell, no strange sound from the down pipes and a little more sound. Wish I had done it earlier and wish it added a bit more throat at full throttle.
    If your car is smelling from behind I presume your main cats are shot.
    Sent from my SM-G935F using Tapatalk
    Oct 05 2015
    Billings, MT
    So I am going to have this done as well as having my SAI deleted, I will have the o2 spacers installed, won't be able to get the tune to override the CEL for that for a few months, will this hurt the car at all while it is still throwing a code?
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Dude you are either flat out lying or ignorant. The JHM ECU tune does change camshaft timing. There are over 100 changes with the B6/7 S4 tune. I know because I have logged my car and multiple other local S4s.
    BCsniper as already addressed gutting the downpipes and I agree with him.
    Then your standards for quality may be different than others. I personally want my exhaust to be able come off and go back on without any issues for years. There are always going to be reasons for downpipes to come off for servicing and crappy downpipes usually don't want to cooperate when you try to take them off and put them back on. Can't tell you have many local people have shitty quality downpipes that take longer to deal with than good quality downpipes when they want me to help them. However a good example of quality parts is the set of V1 JHM headers that have been used on my car, then Slow4's car, and now currently geebus's car. Those headers have been used hard for years now and they still work great!
    Veteran Member Three Rings MantanaB6's Avatar
    Jun 24 2014
    A bunch of bikes and skis.
    Portland, OR
    I have a JHM intake manifold, spacers, piggies, and tune. There is a bit of smell off the exhaust, but only noticeable if standing directly behind the car. As far as power goes, I've never really driven a stock S4, but I'd say it pulls almost as hard as my dads B8.5 S4. Also I have a magnaflow exhaust and there is a bit of low speed/rpm boominess, but zero drone while cruising.
    Previous: B6 S4 Avant Tip Goodwood Green w/ JHM goodies (gone but not forgotten)
    B6 A4 Avant 3.0 Tip Light Silver
    B5 VW Passat 1.8t 5-spd Candy White
    Mar 08 2011
    Chicago IL
    To clarify, gutted cats on the FI downpipes=no cats. So they stink more than piggies, which retain the main cats.
    Dec 19 2012
    New York
    what dp's are you thinking of going with?
    Jun 04 2012
    Greenville NC
    So I guess my overall question is; gut my pre-cats or stick with them the way they are. Secondly, what are the odds of encountering a CEL with the O2 spacers? Is there a way to modify the spacers to help avoid a CEL? And can I rid the CEL without getting a tune (not saying I am going to skip the JHM tune, but the tune will come roughly a month after I put my car back together and I need to get an inspection done immediately)
    Jun 24 2014
    Portland, OR
    Quote Originally Posted by x4frnt View Post
    Maybe just wait to do the piggies until after the inspection? O2 spacers w/ gutted piggies could potentially not give a CEL, but there's no guarantee. Whereas there is a guarantee that with a tune you won't get the O2 sensor CEL. If you must gut your piggies immediately, people seem to have good luck with the J-bend spacers; they come with a variety of fittings to adjust the amount of exhaust they let through, so you can "tune out" the CEL by fiddling with those. People have guesstimated that gutted pre-cats or dp's may also help expelling heat which can potentially aid in preventing various maladies that affect the 4.2 in the S4, so there could be benefits outside of just pure performance increases. But don't quote me on that; somebody with more knowledge of this platform could maybe pipe up about this.
    Oct 05 2015
    Billings, MT
    Same questions as me, i am also doing a SAI delete which i know will cause a CEL, my question is will that CEL hurt my car at all of it stays on for a while?
    Mar 27 2010
    solar system
    OK, let me rephase this: Having an expansion chamber that necks down right after the exhaust pulse exits the engine WILL RESULT IN A REVERSION IN SOME PART OF THE RPM BAND
    If you knew the first thing about pulse resonance tuning, you'd know that this is a BAD idea and that you're much better off ponying up the whole $300 and just getting a 2.5 in straight pipe.
    If someone is so broke that they can't afford it, then hey, knock yourself out and make piggies. It will be better than stock.
    However the OP is asking what his options are and I'm telling him. If you don't like what i have to say, than go pound sand...
    Oh, and does anyone have any logging data for a car with piggies? I'd be interested to the MAF readings from cars with piggies it vs straight pipes.
    Mar 27 2010
    solar system
    Quote Originally Posted by JimmyBones View Post
    Then show me the logs....
    Or better yet, why don't you show me a screen shot of winOLS comparing the two...
    Have you actually dissected a JHM file? I have.....
    Before he passed (RIP) Daz sent me a copy of the JHM S4 file and guess what THE CAM TIMING TABLES WERE THE SAME BETWEEN THE JHM FILE AND STOCK!!!
    I know exactly how many maps were changed, and it's not 100's. It's 54 including the smaller 1D and 2D maps;
    There are 28 3D maps changed and of those 28 3d maps, 8 are just maxed out torque limiters.
    Dude, I know the S4 ECU inside out, sideways and backwards. I've literally spent about 1000+ hours over the last year dissecting and staring at the tables as I developed my own definition file for my 560G ECU. I also have literally hundreds of different revisions for the file that I have now and Gigabytes of logging data that I've poured over.
    My job takes me all over the backwoods highways of our Province so when I would go to Court in a far off location, I would set up my bench flasher to run off an inverter, go out and log my car. Stop, tweak the file, reflash the ECU, rinse lather repeat... Sometimes I'd try 5, 7, 10 different versions a day.
    So don't think that you know anything even close to what I know about tuning these cars, the simple fact is you don't......
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    If you saw a file where the cam timing tables were the same as stock, you didn't see a JHM file.
    Mar 27 2010
    solar system
    Quote Originally Posted by Jake@JHM View Post
    Oh, so you're saying that Daz was lying to me?
    I've seen logs of your V6 3.0 file and the cam timing tables were exactly the same as stock, for both the intake and exhaust.
    Here's the intake and exhaust logs from a JHM tuned Audizine member
    Intake and exhaust from my stock ECU
    If you have changed them, then someone post up some cam timing logs of a JHM tuned V8.
    Until I see some kind of proof, my statement stands.
    So, are you going to show me some kind of proof that you guys changed the cam timing tables?
    Aug 31 2011
    Lathrop
    Do I think a thief lied to you? Certainly. However there is always the possibility that he was the one that was fooled..
    Dec 07 2009
    East Coast
    How dare you guys question ZimbutheMonkey?!?!? Don't you know the almighty protol. First and foremost, you must post your rather impressive complete credentials in an automotive industry, specifically in the department the topic in question is on. These do include your previous employer/s, length of employment, exact position, etc... There's a form somewhere on here. After he'll glance at it and still dismiss everything you posted just to flip you off and move on as a selfproclaimed ultimate expert on a subject matter.
    Forget the B8, keep the V8!
    Apr 03 2010
    Northern Virginia
    Why bother posting logs. You are just going to ignore them anyways. See Mr. Wrong's post below for a better explanation.
    As usual Jake's posts are on point.
    Quote Originally Posted by Mr.Wrong View Post
    This post is hilarious because it is true.
    Mar 27 2010
    solar system
    Lol, of course, when I ask for proof, this is what you come back with. Pretty much what I expected, bravo..... (slow clap).
    Not likely Daz was fooled, he knew more than you, me, and this whole forum combined when it came to tuning.
    Also, shame on you for calling Daz a thief. But anyway, if you want to talk smack about a dead guy who can't respond to your comments (REAL classy by the way Jake ), I guess Ill have to do it myself...
    Calling Daz a thief implies that he somehow stole and implemented aspects of your file in his own work. Trust me, Daz didn't need to steal a damn thing from you guys, anyone who knows anyone in the tuning scene knows that Daz could have run circles around you guys in his sleep, period, end of story.
    Why do I know this, because unlike your operation, Daz was actually open and forthcoming with what he knew. He was an invaluable asset to the tuning community and we're all worse off for his being gone, can we say the same of JHM?.... no, didn't think so....
    PS: I also suppose that the forum member with your V6 tune and supplied the picture above of his logging data (which demonstrates no changes to the cam timing tables) was lying too.
    No need to flip you off, your handle says it all
    Jun 04 2012
    Greenville NC
    If someone wants to send me a cable, I'll do a stock vs piggie mapping comparison 😁
