Hi guys,
Havent been online in a while and saw this thread and the shoutouts so I thought i'd represent the s4/rs4 section and share some of my experiences.
First, if you wanna relocate your abs, I can't help.
Second, I like what trb1 said. 99% of people arent intimately familiar with their cars and this is a really important thing to understand if you do decide to remove the abs unit. This was the first abs car i personally owned so naturally I wanted to get rid of it for about the first 6 years of ownership. Besides the prop valve, your pad compound and bedding them in properly is the next thing to be mindful of. I perfer not having abs for two reasons, adjustable bias & the ability to use different pad compounds for street vs track setups. Porterfield makes the best damn street pad iv'e used and gives a very nice, progressive engagement - kind of like the opposite of a turbo spooling up. The benefit is that they perform nearly the same cold as they do at temperature and the deeper you go the more you get. They are easily capeable of dropping around 20-25mph in a second when threshold braking around 80-90% When i had the abs unit in the car, i couldn't use the pedal as deep as without. In certain circumstances, like turn 4 at willow springs ive unexpectedly gotten a foot full of abs when trail braking and it is no fun. But then again neither is chording a tire from locking up a wheel...
I'm gearing up to build another car like my black one and will possibly look into something more exotic like a pedal box combonatin with a staging brake but here was my first one which works perfectly even now,
Routing:
master to ?/-3fittings - prop valve (top)
prop valve to linelock/turning brake/rear calipers (far left, bottom of prop valve)
prop valve to front brakes (middle and right port, bottom of prop valve)
Tilu, i'll measure the master to -3 adapter tomorrow and let you know what it is.
Sent from my iPad using
Audizine
