Originally Posted by
papadoc
You have that correct. There is no reason to flash back to stock at the dealer, for if there is an issue, there is an ECU flash counter that you cannot alter. Audi will get that and say goodbye to warranty coverage. So yes, pay to play, but those who think the ability to flash back to stock is an advantage are mistaken. If you go with an ECU tune, just forget the possibility of Audi paying for anything drive train related.
Ability to flash back to stock 100% is an advantage, flash counter or no flash counter.
My S6, with EPL tune, was in for drive train warranty work. Flashed back to stock prior to taking it in... during the course of the diagnosis, Audi kind of took over the situation and instructed the dealer to do a "spec vs actual" before they would warranty anything further. The "spec vs actual" is where Audi will catch a tune and flag TD1 by comparing parameters the ECU is supposed to have against what it does have.
The spec vs actual is detailed enough they caught my VCDS mods, such as lap timer enabled, and changed it back. But they detected nothing else that would cause me to be flagged TD1 because i had flashed back to stock. If I would have taken your point of view and said "might as well leave the tune on because they will see the flash count change anyway" I am 100% confident I would have gotten flagged and Audi would have stopped right there with their warranty work.
In addition to dong the spec vs actual can they go in and look at the flash counter? Maybe, I don't know. I can't say I know exactly how all that works with the flash counter nor have I ever read anything definative. Does it log date and time is was flashed? Does it tell them what parameters where adjusted with the flash?
i would much rather them notice a flash counter issue than also be able to detect an actual change in the timing and boost parameters. At least with the flash counter there is probably some gray area for argument and pleading ignorance, as just because the car has been flashed does not mean they know what might have been adjusted with the flash and if it had any bearing on drive train parametners.
Unitronic also has flash at home ability, so they should be considered an option as well if that is important.
