Results 1 to 3 of 3
    Active Member One Ring Glenn4.2's Avatar
    Feb 19 2017
    Ontario, Canada
    B8 fog light grill?
    Wondering if anyone has seen a fog light grill something like...
    Plus a light of course, Rather then....
    Or should I just start dremeling mine out? I think it looks a little more aggressive.
    Red leather on Ibis white 2011 S5 6MT | B&O | Drive select and Sport Differential | Carbon Fibre Trim | Eisenmann Exhaust | H&R sport | RS5 Grill
    Veteran Member Four Rings mozman68's Avatar
    Nov 09 2014
    2019 VW Atlas SEL R-Line
    South Carolina
    I bought the honeycomb ones on here and they are awesome...popped out the old ones and popped the honey comb ones right in.
    The only thing you need to do in between is spray some of the surrounding aluminum around the light housing black. The stock covers hide them well, but I found it looked bad when you could see them through the honeycomb. Again, popped thm off, 5 minutes to spray, popped them back on...
    2009 S5 in Bottle Green / 20x10.5 BBS CH-R in satin black (check with Mops) / AWE Tuning Track Exhaust (Mops again!) / H&R Street Coilovers (Mops...again) / Ecodes (ECS Tuning) / Rear LED retrofit (Europrice) / RS5 blackout grill (MrCarCar)
    MozMan's Build Thread
    Established Member Two Rings lizerd's Avatar
    Aug 29 2015
    Hayward, CA
    so youre not looking for the honeycomb style fog grilles? because the ones you posted are the only aftermarket ones available at the moment for the B8 S5/A5 S-Line bumper.
    2008 Audi S5 6MT Meteor Grey Pearl
    H&R Sport Springs | MSE MS52 20x9.5 +17F +10R | 255/35/20 Falken FK453
    034 Rear Sway | CR-15 STB
    034 Tranny Mount and Insert | ECS Tuning Differential Mount Inserts
    X-pipe + Muffler Delete | Megan Racing Dual Staggered Tips | 034 Intake | K&N AF
    PowerSlot Slotted Rotors | Hawk HPS Pads | StopTech SS Brake Lines
    RS5 Honeycomb Main and Fog Grilles | LED Fog + Interior Lights | CF Wrapped S-Line Trim
