Results 1 to 11 of 11
    Feb 09 2017
    Ocean Springs, MS
    HELP!!! Hard to clean headlights
    Hey all
    I am currently trying to clean my headlights and I have tried many methods so far. I am trying to clean the cloudy haze that is still left on my head lights
    I have used:
    Turtle Wax Headlight Restoring Kit
    Turtle Wax Polish/Compound
    3M 320 Grit Sand Paper
    3M 800 Grit Sand Paper (Wet/Dry)
    I have done everything to buff the haze off the lights but I can not get it to come clean. I have done everything carefully by hand.
    The yellow came off, there is still a haze there (in comparison to the edges of the light, which havent been effect and are still nice and clear)
    I would appreciate any advice.
    May 20 2010
    I'm in the process of doing this for my C5 headlights and got the Sylvania kit. Came out very clear except there's still one bit of imperfection that looks like it's deep within the plastic that I cannot get to.
    Veteran Member Three Rings Mr.Avant's Avatar
    Jun 18 2012
    Edmonton
    I refinished two sets of xenon's now. Went through an entire WET sanding process before moving on to Polish. Looked something like
    600 grit
    800 grit
    1000
    1500
    2000
    Polish
    3m for protection
    Your first cuts with aggressive sand paper are to remove the major flaws/chips/hazing etc. As you move up in grit, you are smoothing the surface, removing all scratches from the previous, lower grit.
    Lots of elbow grease, the results were rewarding.
    03 A4 1.8TQ STD | Atlas Grey | S4 Alcantra Reacro's | S4 Bi-Xenon Lights
    Motoza Stg 1+ | TT 386cc injectors | Unitronic 3" Downpipe+HFC | Magnaflow 16601 | S5 coilpacks | SAI Delete
    JHM Short Throw Trio | BFI GS2 | Pioneer Navi | S-Line Wheel | Hardwoooood
    H&R Front Springs w/ ECS Coilover Sleeve | Statis Rear Coilovers | 3sdm 0.06 | 18x8.5 | et 27 Rear 32 Front
    May 20 2010
    Quote Originally Posted by Mr.Avant View Post
    600 grit
    800 grit
    1000
    1500
    2000
    Polish
    3m for protection
    What he said. My kit included 400, 1000, and 2000 grit, plus an included polish. I added a 3000 grit, and some polish of my own on top of it. After doing all that, I used the clear coat (with UV protection) included in the kit. That's where it is right now. I am 100% happy with one of the lenses, but will probably go through another round of polishing on the 2nd lens.
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    @Mr.Avant what polish did you use?
    "Beep beeeep bloop boop" - R2D2
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    Jun 18 2012
    Edmonton
    Quote Originally Posted by Willënskraft View Post
    It was not plastic specific. Any compound for mild oxidation and swirling with a rotary polisher would do the trick. 🖒
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Are you sure the remaining haze is on the outside? When I've refinished lenses before I found it useful to sand in one direction and alternate direction when changing grit, if your not using an orbital.
    Jul 31 2016
    Montana
    I have used turtle wax headlight kit 2-3 times and was always disappointed, used 3m drill kit twice since then and was happy
    Oct 14 2011
    Norcross, GA
    Thank you.
    Veteran Member Three Rings oaybar007's Avatar
    Sep 17 2006
    Ellicott City, MD
    The 3M kit is really good. It helps to have a corded drill because it does take a lot of progressive sanding and then a hell of a lot of polishing. I usually lose patience and end up with a half decent result, but that's my fault!
