Results 1 to 30 of 30
    Nov 20 2014
    New York
    b8 GIAC stage 2 6MT bypass
    So I've had this issue for a while where I shift fast and upon starting in next gear car feels like it hit a brick wall. I finally caught it on logs. It appears the bypass stays open in next gear for a very long time. I'm gonna send logs to Giac but I wanted to see if anybody has an idea or same issue. See logs attached below. It's the last log from the file with the highlighted part being in next gear and bypass significantly opened
    Veteran Member Three Rings FromRagsToS4's Avatar
    Jan 23 2017
    Idaho
    Does it almost feel like it's a really badly slipping clutch? Like, the clutch pedal is all the way out and you're completely in gear, but when you press the gas it revs up to redline like it was in neutral?
    If no, what do you mean by hitting a brick wall?
    Veteran Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    What fuel are you using ?Is it the wright map for your fuel ? Looks like you are getting knock & timing is being pulled (4-5 *),also your IAT's are into the 60's when it happens, so a little on the hot side
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    Quote Originally Posted by FromRagsToS4 View Post
    no... i think he means that the tach just pauses where it is and it takes a second to 'catch its breath' and start accelerating again
    is that correct OP? if so, i've had that happen before
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Jan 23 2017
    Idaho
    I've had that happen too. I figured it was just clutch slip so I let off and put it in neutral then tried again.
    Nov 10 2014
    Apex, NC
    this might not be tune related and more audi design related
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Nov 20 2014
    New York
    I wish I could get a video of it but I don't feel comfortable on that shift. When i said it feels like it hits a brick wall I meant in terms of acceleration, it accelerated as you can see on the logs but car is very slow because bypass is open. Also I'm running E85/93 mix, same mix that everybody is running and I usually get that timing retard and iat's should be around 70-80c for the bypass to open due to excessive heat soak. Also clutch isn't slipping, stage IV JHM and ECS LW SMFW. I know what clutch slip feels like from the stock clutch days
    Jul 21 2004
    South Florida
    Thats interesting the bypass is opening for 500rpm after the shift which puts you in that next gear at around 5400rpm. During that time the ECU is also only targetting from 0psi of boost to 4ish psi of boost. The non outlined part of the log showing the before shift gear shows you targeting 17psi from 5100rpm up to shift. Thats odd. Do you feel anything like stumbling at all when this happens or just not as much power? Do you see any misfiring going on? Any fuel pressure issues?
    2018 Audi S5
    Gone-
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    My car does it occasionally when shifting really fast. If I have ESP completely off it has never done it. I think it's a function of traction control.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Nov 20 2014
    New York
    Quote Originally Posted by bhvrdr View Post
    No weird stumbling to misfiring, just feels like a really slow NA v6 car lol if I get off the throttle for a split second and get back on it bypass closes and it starts pulling like it's supposed to
    Quote Originally Posted by rtl5009 View Post
    I always pull logs with everything in the car off and traction completely off.
    Jul 28 2009
    Philadelphia PA
    hmmmm. Very interested in what GIAC says. Can you send me the full log, [email protected] Thanks.
    c8 a6 allroad
    Nov 20 2014
    New York
    Emailed it to you, I have a few more where the bypass opens to 66% when off throttle and as soon as I'm back on it it goes straight to 0 as it should.
    Jul 28 2009
    Philadelphia PA
    It took over 2 second for the file to request full boost after you lifted your foot off the accelerator when it lagged. That is so weird. It started to see a lot of knock correction right at the top before the gear change. It was really lean while the flap was open too, low to mid 12's. It seems to be protecting from further knock.
    c8 a6 allroad
    Nov 20 2014
    New York
    I wouldn't really blame it on the fuel and the map because this sometimes happens on 93 fuel on the 93 map, I'm gonna see if I can go out and replicate it on pump map and catch it on logs, not sure I have time though. And I'm not sure if you can interpret the AFR's like that due to the mix
    Jul 28 2009
    Philadelphia PA
    Lambda is lambda, I just assumed you were on gas changing the scale is easy. So you are on an E mix!
    c8 a6 allroad
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Can you email me your fuel pressure and lambda logs? I'd like to see what happened after that "point of no return." You were on your way to hitting the timing targets (ecu is seeing everything it likes), but then it went downhill from there (ecu is seeing something it doesn't like, so its bypassing). The amount that you were bypassing almost resembles what the bypass looks like when the engine is idling.
    Can you also log cylinder activity across all cylinder + bypass? Interesting to see if the corrections are isolated to one bank to narrow down what's going on.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Jul 28 2009
    Philadelphia PA
    My car did this today second to third gear, flap just stayed open and I was building zero boost with the accelerator mashed. I was not logging. I literally looked down at the boost gauge and it was drawing a vac at full throttle. Not much but some which makes sense with air ridding past the bleeder in the sandwich plate for the boost gauge. Did you happen to figure anything out? My car literally fell on its face. It wasn't missing, just no boost. I had ESP completely off.
    I was on the pump file and have 3.5 gallon of e in the tank so knock (logs show zero knock) is not the issue and in no where close to maxing out the fueling system (in on roughly e25). Logs from a few days ago are super healthy and the car feels strong.
    c8 a6 allroad
    Active Member Two Rings lukasB8's Avatar
    Nov 09 2014
    frankfort,il
    Giac stage 2 here, my car does this aswell and i always run the pump map with 93 octane, while doing a pull you shift into next gear and feels like it hits a wall and if you keep it floored you can feel the boost then start to creep up about 3-5 secs later, i cant figure out it...
    Jul 28 2009
    Philadelphia PA
    Sonic did you figure anything out?
    c8 a6 allroad
    Nov 20 2014
    New York
    Quote Originally Posted by lukasB8 View Post
    Are you both tuned by GIAC? I got in contact with them and after a few back and forth emails it seems like the issue arises because the tach moves slower than actual rpms and we're hitting the rev limiter throwing us into soft limp mode. It also could be that the ecu cannot react fast enough to give fuel back in time and close the bypass. Also it turns out we have no lift shift so if you want to actually get on it like that just don't lift off the gas and it reacts better than letting off and getting back on it in next gear. I only tried no lift a few times and it didn't seem to hit that wall in next gear. It happened to me a lot of times and on logs it seems like when I let off and switch at 7000-7200 per tach, sometimes it goes as far as 7400 at which point it's already passed rev limiter. Hope that made sense, im a little under the influence haha
    Jul 28 2009
    Philadelphia PA
    We're both on GIAC. Why don't other tuners have this problem?
    c8 a6 allroad
    Nov 20 2014
    New York
    They might have it and people haven't stumbled upon it, most cars are DSG, maybe most people don't shift as fast as we do. Before I got the clutch done it happened once or twice because those were the only times I said fuck it and shifted fast knowing clutch will slip so I blamed it on that. Try not lifting off the gas and shift very fast around 7150 or before
    Jul 28 2009
    Philadelphia PA
    I shift fast as fuck- One time a tech at the VAG proving grounds (outside of phoenix) was in the car next to me doing and we were doing pulls and he came up after and asked if my car was a DSG cause I was shifting so fast. lol.
    You are right, I only notice it if I am really deep in the tach when I shift.
    c8 a6 allroad
    Nov 20 2014
    New York
    Yeah and I think that really fast shifting paired with us trying to squeeze every rpm out of the car pushes us into soft limp mode and ecu cant recover fast enough. I haven't drunken the car due to the shitty weather but as soon as it gets nice I'm gonna log under same circumstances I caught the issue on logs and not lift of the gas. Give it a try and report back if you have the means to open it up like that
    Jul 28 2009
    Philadelphia PA
    Are you sure all GIAC files have nls and not just AWE or forge?
    c8 a6 allroad
    Nov 20 2014
    New York
    I don't have a forge nor an awe pulley, so i dont even know what file I have. I did a launch and I no lifted 2-3 and it was awesome lol I have no lifted the car before but I switched so late in the rev band that I thought I banged off the limiter but it seems like it's holding wherever you clutch in.
    Nov 09 2014
    frankfort,il
    so has anyone with logs contacted GIAC? curious to see what they say. My car bogs now every other pull i do its getting ridiculous...
    Apr 04 2012
    MSP
    Just reading this.
    I've had this happen a couple times while shifting very fast at WOT.
    Senior Member Two Rings withENEMYin's Avatar
    Jul 24 2014
    2017 Q7 3.0t, 2008 Q7 4.2L
    Chicago, North Burbs
    I have experienced exactly this, I thought my belt was too loose. I just put on a tighter belt last week and it happened 4 days later under hard shifting. It makes me check as if I forgot to turn traction control off.
    2014 RS7: Milltek Turbo back, RocEuro Intakes, Ported TB
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by withENEMYin View Post
    I have gotten mine to do it with ESP completely off. Rev it high and shift fast and it will happen.
    c8 a6 allroad
