Results 1 to 18 of 18
    Oct 19 2016
    Austin, TX
    Question for those that started with Chipworks and are now flashed...
    Just wondering if you could do it all over again, was it worth going with a full reflash vs. Chipworks?
    Would you have just waited a bit longer and simply reflashed? Or simply not reflashed and kept the box?
    Surely this has been covered before but these threads generally get muddy and long.
    Dec 11 2015
    boston
    Quote Originally Posted by Jsalicru View Post
    I started off with chipwerk s module and had it for about a year , i recently reflashed the car with epl stage 2 and also did the transmission tune also and i could say the full tune is a lot better especially in a dsg car. The drivability is a lot smoother and the power increase is more noticeable .
    13' s4 ,ibis white ,b&O, sport diff , dsg , full nappa
    Epl stg2/dsg flash . Cts pulley . Ecs Kohlefaser Luft-Technik . Rotiform spf 19x10 all around . Enlaes decklid . Rs4 grill . Deval diffuser . Ecs diff mounts . H&R OE springs . Awe Touring .....
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    The don't regret chipwerke at all, it was nice to start there when my car was brand new. I did the stage 2 also and was a really nice power bump from stage 1. Now I have EPL stage 2 and it's much smoother and the throttle response is better. Have a 7200 shift now instead of 6500 too!
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Quote Originally Posted by ModItNow View Post
    +1
    But I have the Unitronic version.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Jan 19 2016
    Harrisburg, Pa
    Unitronic 1+ is much better than Chipwerke IMO
    Sent from my SAMSUNG-SM-G930A using Audizine mobile app
    Oct 19 2016
    Austin, TX
    Ok. Thank you for the feedback on that. Sounds like skipping is the way to go from your concensus
    Senior Member Two Rings tonton's Avatar
    Sep 19 2016
    '14 Audi A8L TDI
    Washington DC
    Not necessarily.. Since I am still under warranty I chose the chipwerke PRO over a flash for obvious reasons.. and according to bhvdr he had better numbers with chipwerke than with APR stage 1. Also being able to remove the chip at a moments notice is very useful.
    Senior Member Three Rings MS203's Avatar
    Apr 09 2011
    '15 S4
    Newport Beach, California
    You should start out with the CW. It will keep your warranty in tact for the time being until you decide on what Stage 1 flash to go with. Keep in mind that you will have absolutely no problem selling a used CW on here whenever you decide to get an actual tune. There is always someone looking for one it seems.
    –Matt
    2015 S4: Brilliant Black, hardwired V1, Roc Euro intake, H&R Street Coilovers, CR-15, SPC Adjustable Upper Control Arms, 034 Rear Sway Bar w/ Moog Endlinks, 034 Rear Subframe Mount Inserts, AG M510's 19x9.5 on Michelin PS4S (255/35/19), AWE Track w/ 102mm diamond black tips, Chipwerke Pro-S.
    Oct 19 2016
    Austin, TX
    Love these counter arguments for it. Hmmm
    Established Member Two Rings <3S4PLAY's Avatar
    Mar 24 2015
    Bay Area
    I would just go straight to a stage 1 tune if I had to do it all over again. The chipwerke boxes give you a pretty good taste of what you can expect out of a stage 1 tune. An actual tune from GIAC, 034, EPL etc etc will be much more refined and will also extract a bit more power safely
    Deactivated Four Rings
    Jun 23 2011
    Or get a real tune and TCU for a little more money and be able to sell the tune when you are done.
    Jan 19 2016
    Harrisburg, Pa
    U could give Chipwerke a try...if u decide u don't like it you can send it back. I did that and had no issues returning it...their customer service was great. I ultimately ended up with Unitronic 1+ and the flash at home was awesome. Unitronic customer service and Modded euros were great to deal with.
    Senior Member Two Rings jayferzahir's Avatar
    Feb 05 2015
    Audi S4 and Audi R8 Spyder
    Westlake Village, California
    I paid $150 for a chipwerks pro from someone in my city and can't complain at all well worth it in my opinion, I'm still on stage 1 and running 91.. going to put 93 and upgrade to stage 2
    2016 B8.5 DD
    RS Grille| CTS Intake| ChipWerkes Pro| AWE Track| 10% Tint| interior LED upgrade|
    2014 Audi R8 V8 Spyder SOLD
    2013 Mercedes C63 SOLD
    Apr 09 2011
    '15 S4
    Quote Originally Posted by jayferzahir View Post
    93 in Cali? I wish lol. How do you plan on running 93 octane? Are you mixing with E85 or 101 octane to get that? It kills me that CA only has 91.
    I am about to tune so I have to decide if I want to go with a lame 91 file... or say f*ck it and get a 93 file and therefore be forced to properly mix 91 and 101 from a race gas pump near me each time I fill up. It's too bad that "because race car" and "practicality" are inversely related.
    –Matt
    Feb 05 2015
    Quote Originally Posted by MS203 View Post
    Yah 91 with 3 gallons of E85
    2016 B8.5 DD
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I run a 93 octane file with an e85 blend. Been working out great.
    Senior Member Two Rings sigaddict's Avatar
    Jun 21 2014
    Plano/TX
    Hands down a flash is better. I had the chipwerke pro and went to epl. It's a huge improvement in power delivery and driveability
    2012 S4 - ECS RS4 Grille
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    The flash is better but honestly when I went from Chipwerke to stage 2 I was underwhelmed. Sure the car is quick but I was not blown away for the $2000+.
