Results 1 to 18 of 18
    Aug 02 2012
    2000 S4
    Harrisburg
    Misfiring under boost but no cel
    The car runs strong until you go wot and push the boost it starts stuttering like its misfiring and then it smells distinctly like gunpowder smoke.. But there is no engine light one and no cels.. Daily driving is completely fine otherwise
    Aug 06 2008
    Canadia
    What tune?
    the B5 S4 is like the mafia... there is only one way out!
    Nov 19 2014
    Portugal
    Aun what ECU? some does not have misfire detection...
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Sounds like spark is being blown out. What plugs are you running and what gap are they set too? With stock coils you want to have gap set at .023-.025 and with fsi coils you want .025-.030
    Sep 07 2012
    Tucson, AZ
    Does the car burn any oil by chance? I had that same gunpowder smoke smell when my turbos were shot. Also is your car stock or tuned?
    Feb 19 2016
    B5 S4 Avant e60 m5
    Bethlehem pa
    Same thing was happening to me @wot but I would get a flashing cel for 15 sec. replaced my spark plugs gapped correctly for my stage 3 tune and I was good to go
    Established Member Two Rings j-dells's Avatar
    Feb 09 2016
    Minnesota south suburbs
    My car is doing the same thing and I got recommend to change to better plugs that are also gaped right. And if that didnt help then to check my fuel system
    Line health
    Clogged filter
    Pump flowing strong
    Injectors and rail not restricting
    And so on.
    Sent from my SM-G935V using Audizine mobile app
    2002 B5 S4 SRM ko4 hybrids Stage 2 eBay tune at 21 psi
    2000 Grand Prix GTP Def not stock (Rod bearings... awkward)
    Aug 02 2012
    2000 S4
    Harrisburg
    MTM stage 2 tune. It has misifire detection for sure I use to get the code.. And NGK plugs idk what they are gapped too
    Senior Member Two Rings 616_S4's Avatar
    Mar 07 2016
    2001 S4
    Grand Rapids Michigan
    check gap, boost leaks, and make sure that you're up to temp fully, mine would do this when the thermostat was going bad, but now at 26 psi it runs strong.
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    a coil getting weak will also cause this, re-gapping smaller may fix it for a while. I had to swap to fsi coils to get it to be reliable.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Mar 17 2009
    2001.5 S4 Pearl white with white interior 6 speed.
    Earth
    Probably not your problem but I was having the exact same issue as you and my fuel filter was very clogged. Changed it and ran so much better.
    Senior Member Two Rings AudiTuner1187's Avatar
    Jan 17 2014
    Delaware
    I had same exact issue. Did the 2.0t coil converaion and all was good. You might have a weak coil/icm
    Sent from my SM-J320P using Audizine mobile app
    Aug 25 2016
    1999 Cummins 24v
    Nor Cal
    Sounds like you need to update your coils to the newer 2.0t style and delete your icms, made a night and day difference on my car and completely eliminated the "random misfires" code
    Mar 07 2016
    2001 S4
    Tighten your gap before dropping cash on coils
    Aug 31 2014
    2002 stage 3 a6 6MT 2004 cavalier
    Charlotte/Roanoke
    Quote Originally Posted by Corradovolksb View Post
    Also use dielectric grease on the plug wires. This is what stopped it for me I had dark tracer lines on the porcelain where the spark was shorting out. AlphaVR is who I learned it from and seems like everytime I have this happen it's what it takes to stop it. Also NGK COPPER plugs will spark stronger and resist being blown out better than the expensive platinum plugs. You just have to change them much more often... Speaking of witch I think I'm due
    Aug 02 2012
    2000 S4
    Harrisburg
    Car was sitting for a while but finally getting around to the 2.0 coils and new plugs. My old plugs were gapped to .04" previous posts suggest running around .028" but reading multiple other threads posts say to run around .04"??? I have stage 2, 21psi, bkr7e, and will have the 2.0 fsi coils
    Jan 17 2014
    Delaware
    From what ive seen. Run .028 for stock coils. 0.04 is if your running the conversion, stonger spark, so you can up the gap without them being blown out
    Aug 02 2012
    2000 S4
    Harrisburg
    Fsi coils in plugs gapped to .04" all misfires gone and runs good.. What was originally wrong was the icm was bad for anyone wondering
