Originally Posted by
mtroxel
When you clear the codes, your long term fuel trim is reset to 0. Then you need to drive a bit before the fuel trim figures itself out. But....that also means you probably have an intake air leak, so that the default long term trim is pretty far from correct. So like jbain, I wonder what codes you're clearing? Any of them have to do with fuel trim or intake air leaks? Those codes are there for a reason.....
jbain2
What's your hardware setup? Any recent changes to the hardware? I would guess that the ECU has adapted and clearing the codes causes the ECU to read differently until it adapts again. Post VAG-COM codes.
I have stock ecu. I never did anything to it.
I have some frames about a/c flap and a p2181 thermostat that's it.
I have a vcds but don't know how to use yet lol
This is my numbers on neutral gear
LuccaT
