Results 1 to 7 of 7
    Dec 25 2016
    West Chester, PA
    Help!! Engine removal
    Hey guys,
    A buddy and I are working to pull the engine from my 09 A4 and ran into an issue..
    All of the harnesses, hoses and engine mounts are free, and tranny bolts have been removed. The engine and tranny and separated, so we pull in the crane, bolt the engine to the hoist and it's time to go...right? Wrong!!
    We neglected to unbolt the torque converter before the giving the engine a pull.. Once we did and it lifted the tranny along with, we knew something was wrong. Double check everything and realized our error.
    Now the issue is, turning the crank is not rotating the converter plate to bring the bolts to where we can take them out...as it should. There is about a 1/2 inch of separation between the block and tranny, so I think we managed to yank out the input shaft.
    Dilemma is, other than turning the crank, how can we get the plate to turn so we can reach the bolts; or is there another safe way to disconnect the tranny with the bolts installed??
    Beer, music and wrenching normally work out well...geez.
    Any guidance you can offer is much appreciated!!!
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    No idea if this will work, spin the driveshaft?
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    You have to slide out the drivers side input shaft from the transmission.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Dec 25 2016
    West Chester, PA
    Spinning the driveshaft doesn't do it, but thanks.
    Pm'd you for more details on what pulling out the driver side input shaft will do. Thanks
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by tyronet27 View Post
    Maybe it's just me, but why aren't the details going in the thread instead of in a PM where no one in the community can see them? It will lead to a duplicate thread of "I found this, but there was no response and I didn't want to necrobump this one, so..."
    Just my $0.02
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Dec 25 2016
    West Chester, PA
    Quote Originally Posted by bakedziti View Post
    Just my $0.02
    Pm'd him (1) so he would get the message, in case he doesn't check updates to this thread. And (2) because his signature implies to do so. I'm planning to post the solution here anyhow...which is why I also put the question here.
    Oct 23 2014
    Buffalo, NY
    That's fine, and I certainly don't mean to cause trouble; but we need to end this cycle of threads dying and leading to duplicate threads on the same topic. I appreciate that you'll post the solution, as well as the outcome.
    °2011 A4 | 6MT
