Results 1 to 24 of 24
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Vibration Under Mild Acceleration
    Hey guys, been having some issues... ok a lot of issues lately, but most of those are for a different thread and another time. I'm trying to figure out what is causing my car to vibrate under mild acceleration. Gentle and harsh acceleration don't reproduce this issue but if I keep a consistent mild acceleration I get a vibration in the peddles and throughout the rest of the car. Not enough to shake things around much but definitely noticeable. Car runs reasonably well otherwise.
    A side note to this is that when coasting to a stop I get a ticking noise that is similar to a baseball card in the spoke of a bike tire like we did when we were kids.
    A second side note is that my car will not break 20 PSI.
    My Car:
    09 A4
    APR K04
    EC FMIC
    AWE exhaust
    APR intake
    6 speed TIP
    Recent maintenance:
    Timing chain tensioner
    Oil pan
    Trans fluid drain
    Rear diff fluid
    Coolant flush
    Carbon clean
    Fuel injectors
    Fuel filter
    High pressure fuel pump
    Spark plugs
    Any potential ideas or fixes would be greatly appreciated. I'm getting so sick of this car not functioning properly.
    My 2009 A4 Prem+ Build thread
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Did you make sure that you left your toys in the bedroom?
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Established Member Two Rings Mussa's Avatar
    Oct 31 2015
    Istanbul - Turkey
    That ticking noise while coasting is 99% from a loose wastegate.
    2011 A4 B8 2.0 TFSI Quattro S line S tronic // APR Stage 2 98 RON - OEM Dual Exhaust - OEM 3.0 TDI FMIC
    - USP HFC - RS4 Black Grille
    Mar 24 2014
    Wait I just reread this and am done making jokes... you still can't get above 20PSI with a K04?
    Re: the vibration, did you replace that motor mount yet? Could easily be causing the engine to move more than normal... under high acceleration it could torque so far over that the vibration goes away, under light acceleration it may not twist the good mount enough to vibrate.
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by Project Quattro View Post
    Could explain vibration, but I wonder what the low boost is from?
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    I have a similar vibration and have been thinking motor mount. It's only noticeable when the engine is labouring a bit, going uphill at low rpm and before it kicks down. Normal or hard acceleration is fine.
    2011 A4 Avant
    Mar 24 2014
    Quote Originally Posted by jmeenach View Post
    He's had this basically since the K04 went on, and maybe even longer.
    Aug 19 2016
    Newport Beach/CA/USA
    Motor mount, tranny mount, and lower rearward control arm bushings are culprits for vibration in 09.
    Oct 30 2006
    B8 A4 Avant 6spd
    Production Solution
    Updated front wishbone links are equipped with larger (75 mm) fluid-filled bushings that help dampen steering wheel oscillation.
    Wishbone links are available with two different size ball joints that are not interchangeable. If the vehicle is equipped with the original wishbone links that have the smaller 65 mm bushing, use the VIN to search ETKA to determine the size of the shouldered hex nut (Figure 4, point 6). Use the shouldered hex nut size to determine the correct wishbone links from the Required Parts table.
    8K0498998 (Kit) includes:
    8K0407693R - Left wishbone link – M12
    8K0407694R - Right wishbone link – M12
    8K0498998A (Kit) includes:
    8K0407693S - Left wishbone link – M14
    8K0407694S - Right wishbone link – M14
    -18 718 GTS
    Jul 07 2012
    Boston, MA
    Quote Originally Posted by Mussa View Post
    Normally I'd agree with you but this is different than the wastegate issue I had with my K03. I'm very familiar with that sound as it was about 25% of the reason I went to the K04. This is more of a sharper sound that actually changes pace depending on the speed of the car. When it was the wastegate on my K03 it was the same frequency and was independent of speed.
    I used to regularly hit 26 PSI when I got my K04 originally.
    Quote Originally Posted by Militant-Grunt View Post
    Production Solution
    Thanks for this info, but it's not just the steering wheel unfortunately. Its almost like the entire car is shuddering.
    Side note, yes my engine mounts are shot but I feel like that wouldn't be affected by acceleration?
    Mar 24 2014
    Quote Originally Posted by Lambda13 View Post
    Could be, I kind of outlined my thinking above. The engine definitely moves under load, especially with the power you're putting through it.
    Under high acceleration it could torque so far over and press against the mount so that the vibration goes away, under light acceleration it may not twist the mount enough to vibrate.
    Oct 30 2006
    B8 A4 Avant 6spd
    If the engine mounts are shot, and you know this for a fact, I would start with that and continue with your diagnosis. If a problem isn't clear cut, you need to start with the obvious.
    -18 718 GTS
    Mar 17 2014
    Los Angeles, CA
    +1
    instagram
    Jul 07 2012
    Boston, MA
    +1
    There's no way I'm gonna spend another $500 unless I can 100% confirm those are the issues. On the fence with just straight parting the entire car at this point. I've had enough bullshit to last me a few years at this point.
    Oct 30 2006
    B8 A4 Avant 6spd
    Thats the German car life. Got to pay to play son. If you can't keep up get a honda.
    -18 718 GTS
    Jul 07 2012
    Boston, MA
    If I told you what I've paid in maintenance in the last 6 months you'd be sick. Trust me I'm familiar, but thanks for the reminder lol
    Sent from my SM-N920V using Tapatalk
    Oct 30 2006
    B8 A4 Avant 6spd
    Shame you're not in the NYC area, my rates are reasonable
    -18 718 GTS
    Jul 07 2012
    Boston, MA
    Haha good to know. I'm down that way occasionally. I do most of my own work, unless it involves a lift...
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    Andrew shot engine mounts are also really bad to just hold onto. Puts unnecessary strain on shit. If they're shot they need to go. Ill sell you my 034 mounts and swap in some stock ones eventually. You'll have less NVH than you have now lol. They still are annoying but at least you'll know your mounts are holding down the fort like a mofo. On that note, I read somewhere that shot mounts and excess NVH can actually trigger the knock sensors to think its pre-detonating. Again I only read this on this or perhaps Vortex so not sure if that's total bullshit. But I agree, if it's broken they need to go. Remove the obvious broken issues. Also- let's finally log your car with the VAGCOM sitting in our garage and look for timing retard or low N75 duty. Let's get some data we can post on here for folks to inspect, instead of some theories written on a cocktail napkin
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Mar 24 2014
    Swap the mounts. It's worth it. You like that car and once you get though these 100k mileage-related repairs it should serve you well for a while.
    Jan 15 2014
    Boston, MA
    I think it's got another 50k in it easily. I'm hoping to get 175,000 out of mine without much fuss.
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    If you are looking to spend the least amount of money to figure out what the issue is then just drop it off to a shop and have them figure it out, otherwise you're likely to replace more than a couple fairly large ticket items before finding the culprit of this issue.
    2016 S3
    Instagram- @Thisisastickup
    Jul 07 2012
    Boston, MA
    Quote Originally Posted by b6Hate4 View Post
    I'm thinking you're probably right. I may have to do that...
    Dec 01 2011
    sounds like it's the mounts, the engine definitely shakes more when accelerating. i would say check the front lower curved control arms too, those are known to go bad on the 09s, i had to replace mine for vibration too, and about to do mounts next.
    just followed you on fb, will have to keep you in mind. where in nyc?
    IG @theshawon
