Results 1 to 21 of 21
    Senior Member Two Rings JetG0ld's Avatar
    Dec 28 2016
    Monsoon Gray B8.5 S4, Santorin Blue B5 A4, Imola Yellow B5 S4, MK7 VW Alltrack
    Brembo 17Z kit on my B5 A4
    Good afternoon!
    I finally had the time to do the install of my Brembo 17Z brake kit this weekend. I had to swap to S4 uprights to get these to fit. While in there, I installed SPC adjustable upper control arms, and put in some new strut mounts.
    The biggest complication I ran into was having to grind my uprights down slightly to get these "Stage 2" rotors to fit. Luckily, not much was needed to clear (the structural integrity isn't an issue as it was just a few mm in an area with plenty to give. It seems this particular rotor option had only been fit to a C5 A6. But, everything is installed now.
    I got the car aligned on Monday, so I haven't really been pushing the limits of the brakes so I can allow them to properly break in. So far, so good!
    Dec 10 2013
    Pickering, Ontario, Canada
    You used C5 A6 front rotors? What specific car?
    Sent from my SM-G935W8 using Tapatalk
    03 Allroad 6-spd
    IG: 24_et
    MODS: C5 S6 4.2 Swap, Modified CSF Performance Rad, Dual 14" EFK, 4.11 Swap, 12lb TTV V8 Flywheel, B7 RS4 Clutch, Custom True Dual Exhaust
    RIP:
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Apikol also makes a set of brackets to fit these, to the tune of $230 or thereabouts.
    2016 S3
    2004 S4- 2.7t, Shaved bay, PTE5858 single turbo.
    Instagram- @Thisisastickup
    Dec 28 2016
    No they aren't C5 rotors. The guy we use for these kits modifies rotors from a Volvo or Benz I believe. The specific rotor I got had been tested on a C5 and not on a B5. He also drills them as shown in the picture.
    It's thicker than the traditional 17Z rotor so the caliper has to get machined a small bit. So the Apikol kit would work, but I got uprights cheaper. I don't think I could have used the thicker rotors with the Apikol kit due to some clearance issues (which I ended up having anyway)
    Sent from my Pixel XL using Audizine mobile app
    Monsoon Grey B8.5 S4 - Unitronic Stage 2+ SC Pulley - DSG Stage 2
    Santorin Blue B5 A4 1.8t - Motoza Tuned GT28RS - Tiptronic to 5 Speed swap
    Aug 08 2014
    New Zealand
    This is cool swap hay, I have test bolted up my z18' yesterday I swapped over my uprights to the b6 and have ml55 rotors funny thing is I had the grinder there ready to go and was looking thought I was smoking to mutch looked again and it seems I dont have to grind anything hmmmm but lucky I think was the easiest thing I have done so far lol.
    But I have to take them off as I dont have big enough rimz :( my ne house is reay next month so ill push it down the road then save up for some new wheels and stiky gearbox testing tyers lol
    Dec 28 2016
    Quote Originally Posted by marka4 View Post
    Very nice! I wanted to go with an 18Z kit myself, but my winter wheels are 17" and theyre powdercoated black so I've already invested $$$ into them, and I like them a lot as a winter wheel.
    On a seperate note, I drove the car again today and it feels great. I upgraded to Stoptech RS4 lines which has helped my pedal feel.
    Senior Member Two Rings SnowBum124's Avatar
    Sep 14 2006
    1999.5 A4 1.8t avant
    seattle
    Great work!
    BetaAlphaTau member # 40
    love my shag-in wagon
    GT2871R turbo, 630cc Siemens injectors, 034 Downpipe, SPAmanifold, TR11 FMIC, Maestro7, south bend stage 4, VR6 TB
    Aug 08 2014
    New Zealand
    Hay m8 do you think the brake lines will work on the z18 calipers? Could you put up a part number I thought I had some but I cant find them dam hay
    Dec 28 2016
    They should, we used the same lines on my buddies 18Z setup on his B5 S4. We use the StopTech RS4 Brake Lines. I don't know the part number off the top of my head. Sorry about that.
    Aug 08 2014
    New Zealand
    Thank you heeeeps iv finally made my wee spacers for the rear 9mm 1'' to space out the b7 s4 calipers and 300 disk do this swap insted of the s4 300 it will not do the whole rotor pad contact. But the b7 will :) mutch better. A person has already done this I was lucky enough to be able to read this and v nice
    Senior Member Three Rings DeathKing's Avatar
    Feb 15 2012
    New York/Los Angeles
    Looks great! I could use a brake upgrade soon...
    JP
    Current:
    '17 VW GTI Sport | VMR V804 18x8
    Sold:
    '99.5 2.8 Sport | k0mpressed tune | Apikol/034 mounts | TSW Bathurst 17x9 et35 | Falken FK453 235/40 | Bilstein B12 Kit | Neuspeed 19MM RSB | Magnaflow 14816
    Veteran Member Three Rings pee quu's Avatar
    Jan 25 2009
    Oceanside, NY
    You where able to swap to s4 uprights without having to swap axles?
    2000 B5 A4 / C5 S6 V8 swap / B5 S4 driveline swap / PVW Nov 2016
    Dec 28 2016
    Quote Originally Posted by pee quu View Post
    Yeah the axles bolt right up. I believe you need to have an 01 for this, but that could be wrong.
    Jan 25 2009
    Oceanside, NY
    is your car a 1.8 or v6?
    Feb 27 2011
    04 A4 2.7T swap, 13 Q5 3.0T S line, 02 A4 1.8T tiptronic, 01 B5S4 tiptronic
    Winnipeg
    all 01s have the larger front outer cvs whether 1.8 or 2.8.
    Aug 08 2014
    New Zealand
    Quote Originally Posted by seanf86 View Post
    I used my 01a axles with the small cv end and used vw van cv joints. had the center lathes down to take the c clip. Seems to work I couldn't find any axles tryed for a while still looking lol but the cv joints were 55bux for 2x. Rather than the 100+ for 1 here.
    Jan 25 2009
    Oceanside, NY
    interesting fact about the 01's I never knew.
    Senior Member Four Rings thedanplasse's Avatar
    Apr 05 2016
    B5 1.8tqm Avant, B6 1.8tqm Avant.
    MA
    Easiest way to run 17/18z on an a4 is run s4 uprights 01 a4 axles or s4 axles. stoptech makes the lines for them and run mercedes c230sport rotors, after boring the lug holes out to acomodate the audi lugs. IIRC you need to mill off some material off the mating surface of the caliper to have it sit correctly over the rotor.
    "Better stick to your A4 forum, peasant."
    Santorin Avant Project
    Atlas Avant Daily
    Dec 28 2016
    Quote Originally Posted by thedanplasse View Post
    It depends on what size rotors you run, the guy we get our stuff from has a set of rotors that dont require the caliper to be machined at all. I went with a thicker rotor which required grinding on the upright, and for the caliper to be machined slightly.
    Apr 05 2016
    MA
    With the Mercedes c230 sport rotor "330mm" I believe you need the machining done.
    Atlas Avant Daily
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    These look so nice tucked away, well done sir! The only thing keeping me from doing it is the cost of the adapters, should just try to make my own.
