Page 15 of 15 FirstFirst ... 5131415
Results 561 to 575 of 575
  1. #561
    Veteran Member Four Rings thedanplasse's Avatar
    Apr 05 2016
    RI
    Maybe. I haven't seen it in a while. This pandemic and my parents being far away has made this even more challenging.
    Rear sf bushings will be ordered later this month.
    "Better stick to your A4 forum, peasant."
    Santorin Avant Project
    Atlas Avant Daily
  2. #562
    Apr 05 2016
    RI
    Screw it, I just ordered the solid 034 rear subframe bushings.
    Atlas Avant Daily
  3. #563
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Excellent, full send
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
  4. #564
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Where did you find the seals for side plates and rear diff tube? I'm not having any luck. I stripped my torx bit trying to get the side plates off.
    Sent from my LG-H931 using Tapatalk
    1998.5 A4 1.8TQM My Build
  5. #565
    Apr 05 2016
    RI
    It was a long time ago, lol but I think I got them off of ECS (triggered) or FCP.
    Atlas Avant Daily
  6. #566
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    I looked the other day and the o-ring for the tube was NLA. I've got the shaft seals, but need the rest.
  7. #567
    Apr 05 2016
    RI
    What o-ring?
    Atlas Avant Daily
  8. #568
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Is there not an o-ring between the housing and the front shaft for the rear diff where they split?
  9. #569
    Apr 05 2016
    RI
    Two axle seals, and a front input seal. There's a o-ring where the 4 bolts that hold the front piece on, but I was going to reuse that one, and the big one one the side.
    Atlas Avant Daily
  10. #570
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Ah, I assumed you had replaced those 2 as well.
  11. #571
    Apr 05 2016
    RI
    010 325 381 A - is the smaller front one.
    N 905 144 01 - is the side cover one.
    lmk if they're still available. I may snag some.
    Atlas Avant Daily
  12. #572
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Sweet! Looks like ECS has the side cover one available and Pelican Parts has the front one.
  13. #573
    Apr 05 2016
    RI
    Quote Originally Posted by xdewaynex View Post
    Lmk how the new ones feel compared to the old ones. If it's barely different I'ma leave 'em. Mine are still very flexible, not dry at all.
    Atlas Avant Daily
  14. #574
    Apr 05 2016
    RI
    Subframe bushings came in today. Finally took a picture of said subframe too. Thanks, Tyler.
    Atlas Avant Daily
  15. #575
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Well, I had no luck getting my hands on the larger o-ring anywhere online. Im in the same boat as you, having to order all new bolts for the side cover, 90% of them stripped, even had to cut the head off of one.
