Audi A4 B6 1.8T Avant
Throttle body not being aligned.
Getting the following error in VCDS:
17987 - Throttle Actuator (J338)
P1579 - 001 Adaptation Not Started
Gives same/similar error on the VW/Audi software at dealer.
Throttle Body will only aligned once this error is removed.
When ignition is turned to ON position the throttle body makes a scratching type of noise.
Have removed throttle body & cleaned with carb cleaner.
Still not working.
I have tested current on plug to throttle body.
- Pin #2 to Ground gives me recommended 5V.
- Pin #2 to #6 gives me recommended 5V.
Also done continuity of wires from plug to ECU & they check out fine.
Car starts but dies seconds after that. When unplugging the Mass Airflow Meter/Sensor car idles fine & can drive, but i'm guessing it will be heavier on fuel.
Any one have any ideas of what I can do to fix?
