Hello to all! Like the title says:
Is it absolutely necessary to pull off the front bumper and put the core support into the "Service Position" to remove the oil pan on an Audi B6 1.8T engine?
In the Sticky for the oil pan removal it says this needs to be done but I have seen some other DIY's for this job and it looks like the front end has been left on in some cases. Hopefully someone that has done this job with the front end on can give some insight to this.
If the oil pan removal is a total PITA with the front end on, I will take it off but if the job is just slightly harder but not impossible to do with it on, I will leave it on. I really don't want this job to take any longer than it has to by taking off a bunch of stuff that doesn't have to be removed.
I need this info ASAP because I am helping a buddy who is a novice car mechanic do this job TOMORROW MORNING!
The reason we are removing the oil pan is because the low oil pressure light comes on sometimes in my buddy's 2002 A4. We are hoping this is happening because of the common "oil sludge blocking the oil pump pickup screen" issue with the 1.8T engines. The engine does has 215,000 miles on it so it makes sense.
Any help or advice is greatly appreciated! Thanks in advance!
