    Sep 03 2009
    San Antonio, TX
    Federal Employee question re: GS pay explanation
    I'm thinking about applying for a civilian job with the government in the Seattle-Tacoma area. The job posting lists the pay grade as a GS-0610-10 with a salary range of $68,721-$86,220 DOQ.
    I get that "GS" essentially means it's a salary position and "0610" is the code for a nurse series and the "10" is the grade level but when I pull up the OPM GS pay schedule for that region, I can't place the job in a specific step level. That starting pay falls between a step 5 and a step 6.
    What am I missing here?
    Jan 24 2008
    West Coast
    Quote Originally Posted by sa_seahawker View Post
    Here you go: https://www.opm.gov/policy-data-over...600/gs0610.pdf
    Keep in mind that the top salary is actually a GS-11 grade. Generally there will be a locality salary adjustment, depending on where you live (i.e. higher cost of living areas), for instance, Seattle has a higher pay than, say, Omaha, NE.
    Moderator
    Sep 03 2009
    San Antonio, TX
    Just to clarify, I checked the GS-10 level steps for the Seattle-Tacoma area. I was under the impression that if you were a GS-10 step 4 (for instance) you would get "X" salary. Because the low salary in the job posting was $68,721, I assumed it would correlate to a specific Grade/step. I've checked the 2016 and 2017 pay tables and neither has a grade/step identified with either salary (the low or high) for the Seattle-Tacoma area. Additionally, I checked the base pay table (minus locality pay) and still nada. As for the benchmark points, the points for a GS-10 only go from 2105-2350 (which I thought may correlate into pay, but even that would still fall below the starting salary).
    Sorry for the 20 questions. Leave it the govt to make things as complicated as possible. I just like to know exactly how I would be paid before I put in for a position. I also have yet to receive an email back from any recruiter or POC. But I thank you in advance for your help.
    MY BUILD
    Jun 08 2007
    Orlando, Fl
    The low side of the pay it shows is the lowest they'd bring you in as, plus locality. So in other words, if you meet the qualifications and they bring you in as a GS-10 step 1, $68,721 is that plus locality. Locality pay is computed as a percentage of the annual pay per year added to your salary. The high side of that pay shown is what you could get if you're highly qualified. Refer back to the announcement and it may say, to qualify as GS-10, 52 weeks of experience combined with education/ to qualify as a GS-11, 52 weeks of experience and secondary education. Don't worry about steps too much, those are your within grade increases. Each year you will move up a step. I've been a federal employee since 2011.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Established Member Three Rings fatherdeath's Avatar
    Jul 20 2016
    2016 Honda CRV EXL, 2006 Dodge 2500 laramie mega cab, 1974 Buick apollo
    Tampa, FL
    if you have GS or GSE oconus pay question i may be able to help
    SOLD:2017 S6 Mythos Black Arras Red interior all the Wayne tech gadgets, RocEuro, EPL stage 1, 15mm front/20mm rear spacers, Eurocode Sways, end links, billet mounts ALL
    American enjoying the autobahn
