Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 141
  1. #41
    Stage 2 Banner Advertiser Four Rings deAutoLED.com's Avatar
    Feb 13 2015
    US
    White/Yellow/Halogen/Strobe/Flash plug and play fogs:
    http://deautokey.com/product/dual-co...low-at-anytime
    We now have 2 models:
    option 1: White/Yellow/Halogen/Strobe/flash
    option 2: White/Yellow/Halogen WITHOUT strobe & flash
    -Plug and play
    -Error free in most cars. Some might need extra resistance - we sell a new design that DOES NOT require you to attach it to metal. It is compact and easy to install - simply plug into OEM adapter and our LEDs (100% plug and play NO splicing design)
    -Easy to switch between each color – simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe
    -BRIGHT – this is not just a novelty bulb
    -COLOR MATCH - these match our LEDs/HIDs in 5500K White mode
    -HYPER YELLOW - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens **this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow**
    -SAFE – more light on the sides and down the road when dark or in bad weather conditions
    -The Hyper Strobe / Flash – this does not simply "flash" but has a strobe/flash pattern like an emergency vehicle - you can choose between 4 different modes - video of mode 1:
    https://www.instagram.com/p/Bpjxc_ajyaS/
    3 colors:
    -Super Hyper 3000K Yellow that many like for bad weather: Rain, snow, fog
    -Clean White 5500k that matches our LED & HID Headlights
    -Halogen 4300k that matches OEM
    Video cycling quickly through colors AND different strobe/flash features:
    INFO:
    -THESE ARE BRIGHT! You might have seen the novelty fog LEDs that can turn yellow/white on amazon and ebay by the thousand that don't provide much useful light, trigger errors, die quickly, or simply don't work correctly. Our new model fixes every issue you might've seen and simply works.
    -These produce MORE LUMENS than many standalone single color white fog LEDs on the market
    -Not only are these great for safety, daily use on dark roads and bad weather this will amaze at any car show and you will have your friend asking how did you do that and where can I get those anytime you use these fogs!
    *Please note these ARE error free but in strobe/flash mode they can trigger an error in some car models – errors WILL clear once you go back to a solid color.
    UPDATED FAQ
    Is there a lifetime warranty?
    YES! As always this comes with a True Lifetime Warranty!
    Will your fogs keep changing colors if you use them as cornering lights?
    The answer is no as this only changes by turning your fog switch on/off. If you are using your fogs as cornering lights it will always be the default color of white.
    How does this work with the coming home feature?
    This works just like OEM. It will always be the default color of white.
    What if I have the yellow feature on and turn off my car; will it then go into the next color when I turn it back on?
    The LEDs will always revert back to the default color of white. Then simply turn the fog on/off for your desired color: yellow/halogen or strobe/flash mode.
    Can these turn 360 degrees?
    Yes, these are a fully adjustable design so you can turn these 360 for the best beam angle.
    Are these as bright as your single color de360 fogs?
    While not as bright lumen wise it comes very close - many people that have switched to our single color white to our dual color yellow/white LED fog kit have not noticed any difference in visibility. As we said this is NOT a novelty yellow/white you normally see. This is meant to be used to help with your visibility.
    Can you bypass the strobe feature?
    Yes, this works when you turn the fogs on/off quickly. If your next mode will be strobe simply shut off the fogs for a few seconds and then turn it back on and it will go back to the default white.
    Some more fun shots - in the rain:
    White / the super hyper yellow - this will be a hyper lamin-x yellow without the cover!
    And switch back to clean white:
    deAutoLED.com
    Facebook.com/deAutoKey
    Instagram.com/deAutoLED
    Lifetime Warranty & Support | Free Shipping within the US | LEDs Tested to work and look good in your car | Customer Service is our #1 Priority - We care what you install in your car!
  2. #42
    Feb 13 2015
    US
    stay up to date with emails:
    http://deautokey.com/mailing-list-sign-up
    -specials
    -new product updates
    -promos
    Do not miss out!
    deAutoLED.com
  3. #43
    Feb 13 2015
    US
    White/yellow/halogen color fogs with or without strobe / SOLID YELLOW NOW available:
    deAutoLED.com
  4. #44
    Feb 13 2015
    US
    Visit www.deAutoLED.com
    Email [email protected] with help
    Error Free LEDs - proven & tested
    Free shipping within the US
    True NO HASSLE Lifetime Warranty
    deAutoLED.com
  5. #45
    Feb 13 2015
    US
    New single yellow Fog LEDs out:
    http://deautokey.com/product/just-ye...ma-fog-led-kit
    -BRIGHT
    -Hyper Plasma 3K
    deAutoLED.com
  6. #46
    Feb 13 2015
    US
    Quote Originally Posted by comingabriel View Post
    How it looks installed (nighttime video)
    Get your footwells - easy to find your model quickly:
    http://deautokey.com/footwell-led-di...ll-audi-models
    deAutoLED.com
  7. #47
    Feb 13 2015
    US
    orders ship quickly and daily from the US backed by our true Lifetime Warranty and 24/7 customer service.
    See the difference:
    www.deAutoLED.com
    -Thank you for the support and trusting our company over the years!
    deAutoLED.com
  8. #48
    Feb 13 2015
    US
    Check www.deAutoLED.com banner for updates!
    -orders ship daily!
    -Free shipping IN THE US
    -TRUE Lifetime Warranty
    deAutoLED.com
  9. #49
    Feb 13 2015
    US
    No joke very bright hyper yellow 3K Plasma Fogs:
    This 3K hyper-yellow 3K is also available in the switchback white/yellow model:
    And solid white:
    http://deautokey.com/product/led-hea...ast-1800-lumen
    -easy install
    -lifetime warranty
    -plug and play
    deAutoLED.com
  10. #50
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    I just installed the yellow/white fogs. Very bright and effective. What I am not quite liking is if you flash the high beams to pass (or just flick the high beams) the fogs change the color mode. It is the same as momentarily toggling the fog switch. Yes this is how they are designed but it is a bit annoying. With this knowledge, I would consider just getting single color. I am glad I did not get the flash/strobe version because it would be a problem having the flash and strobe on the road.
    2014 Estoril blue Cab Chestnut brown interior
  11. #51
    Feb 13 2015
    US
    Quote Originally Posted by Neil F View Post
    Hi, this does happen due to the OEM Audi voltage sending it to fogs when hitting high beam but very rarely would you use your high beams like this so we have not seen it be a big concern. The only time you might see an issue is if you have it on halogen color (which many do not run) as next setting would be flash/strobe. Some do not mind as it gives extra attention if you are going to quickly flash high beams on/off and not in halogen setting no concern for flash.
    Thanks for your feedback and update. We appreciate it.
    deAutoLED.com
  12. #52
    Feb 23 2018
    2015 A3 2.0t Quattro
    Tennessee
    Is there a fog bulb version for the S5 that is only clean white color with no cycling option?
  13. #53
    Feb 13 2015
    US
    Quote Originally Posted by nikocb1 View Post
    Yes it is here - just choose your bulb model on the drop down menu:
    and all models are solid white or solid yellow - then switchback with or without strobe:
    http://deautokey.com/fog-leds
    deAutoLED.com
  14. #54
    Feb 13 2015
    US
    Choose your Fog LEDs
    Just yellow Fogs
    Just White Fogs
    White/yellow with or without strobe:
    deAutoLED.com
  15. #55
    Mar 18 2015
    2015 GL450
    IL
    Just installed the Plasma Yellow 3000k and they are fantastic. Much brighter than stock with a greatly improved beam pattern.
    The only issue that I had was that I couldn’t turn the lock ring very far in the socket. They seem tight but I’m worried that they might vibrate loose over time. Any ideas on how to tighten them further?
    Sent from my iPhone using Tapatalk Pro
    2016 S5 6MT - Brilliant Black, P+, High Gloss Black, Sport Dif, B&O, Tech, Nappa
    Engine: GIAC Stage 2 & SC Pulley / ECS Carbon S-Flow Intake
    Suspension & Wheels: H&R Street Performance Coilovers / Vorsteiner VFF-103 (Carbon Graphite)
    Exhaust: AWE Touring
    Cosmetic: OEM RS5 Grill / PPF & CQuartz Finest Coating / 35% Pinnacle Tint
  16. #56
    Feb 13 2015
    US
    Quote Originally Posted by RVJ View Post
    Thanks for the feedback. We have not seen any issues like this - try pushing further in as there is a rubber gasket around the bulb (it is red). But there should be no problems.
    Keep us updated.
    deAutoLED.com
  17. #57
    Jan 13 2017
    marlton/nj/usa
    deAutoLED,
    Question: How are the Yellow vs 5k white leds arranged on the bulb? I had been using both the yellow and white and I have noticed the yellow hitting high road signs and overhead signs. I not really checked the plasma yellow light pattern vs 5k white until this morning on a dark street. The yellow is illuminating objects higher up than the 5k white. I assume it is due to the white and yellow LED physical arrangement.
  18. #58
    Mar 18 2015
    2015 GL450
    IL
    Quote Originally Posted by deAutoLED.com View Post
    Keep us updated.
    Seems to be fine. It might be that I had to go through the wheel well and it was a pain to put the bulb in while holding the liner back.
  19. #59
    Jan 13 2017
    marlton/nj/usa
    That why I suggested to you to pull the grill off and remove the housing...…………...
  20. #60
    Mar 18 2015
    2015 GL450
    IL
    Tried but got worried. Was pulling pretty hard and it wasn’t budging. Was paranoid that I might break something.
    I do need to get them off though. Lenses have some pitting and I want to polish them.
  21. #61
    Jan 13 2017
    marlton/nj/usa
    Just pull. I've had mine off numerous times and nothing broken
  22. #62
    Jan 30 2017
    Kennesaw, GA
    Disappointed with the service level from these guys. Sent an email and FB message a week ago with reminders and no reply....
    Guess I'll go with ECS.
  23. #63
    Feb 13 2015
    US
    Quote Originally Posted by gamov3r View Post
    Sorry to hear this. It is never our intention to ever ignore anyone and it must've been missed so I do apologize.
    I sent you a PM to gather some info to see if the team can find your emails and reply right away.
    Thank you
    deAutoLED.com
  24. #64
    Jan 30 2017
    Kennesaw, GA
    Thank you
    I STILL can't get an answer from you. My question is very simple - if I want slightly better than stock performance from my 2014 Audi S5 Coupe, which low beam bulbs do I need from you? You keep asking what bulbs I want in our exchanges - I DON"T KNOW!!! I'm asking you!!!
  25. #65
    Feb 13 2015
    US
    The team sounds like they are asking you of the bulb type you need and housing style. You can find this information 1) in your car's manual 2) or looking at the housing inside engine bay it is sometimes embossed with all bulb info option 3) is an online bulb guide but please know these come from 1 company and are not always accurate.
    Once they know this information they can help get you exactly what you need.
    Thank you
    deAutoLED.com
  26. #66
    Jan 13 2017
    marlton/nj/usa
    Our cars take a D3S. Checked via forum search. https://www.audizine.com/forum/searc...archid=9969826 deAuto offers 4500k (stock temperature0 and 55000k (little more blue/white) http://deautokey.com/product/new-d1s...en-audi-models
  27. #67
    Feb 13 2015
    US
    Is it all models? I know some had h7 also. It is best to always look as these bulb guides are not 100%. But all Audi models would have them inside engine on headlight stamped or on a sticker:
    deAutoLED.com
  28. #68
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    Why don't you set your fogs to stay on with the high-beams? I think that would solve this issue and it's simple to do with Carista or OBD11, VAG-COM, etc..
  29. #69
    Feb 13 2015
    US
    Find out why we are the go to place!
    LEDs for your Audi: Front turns, Low Beam, Fogs, Interior, Reverse and everything else - we have custom LED kits you cannot find anywhere all plug and play error free.
    If you cannot find what you need on our website: www.deAutoLED.com - simply email [email protected] for instant help - we have 24/7 customer service and ship daily from the US.
    We know many might've had bad experiences with other LEDs and many emails start with "This LED had this issue will your product have the same problems" - the answer is NO - our LEDs are tested in your model to work and look good.
    Some examples:
    -Error free front turns that are bright and can be seen in direct sun light
    -Low beam d3s HID that are bright and clean white that match other LED DRLs
    -Fog LEDs that shine wide on road and help and are not a novelty
    -Error free plug and play reverse LEDs you cannot find anywhere else that are very bright
    -Interior LEDs that are all different style bulbs - we don't just throw 20 194 wedges that look the same like some kits. Each one is designed around your housing
    -We customize our LEDs to work with the Audi electronics and why ours are sometimes the only ones that work - working is 1 thing but we then also make sure they are bright and something you want to use.
    Thank you
    deAutoLED.com
  30. #70
    Jan 13 2017
    marlton/nj/usa
    Quote Originally Posted by RockJGC View Post
    Hey Rock,
    Yep did that. You sent me the list of Carista not too long ago with regards to shutting off the ecode bulb error and I decided to get a Carista module. Yes setting the high beams to stay on with high beams was one the changes I did.
  31. #71
    Jan 13 2017
    marlton/nj/usa
    deAutoLED,
    deAuto,
    Can you comment?
  32. #72
    Feb 13 2015
    US
    deAuto,
    Can you comment?
    Hi, sorry for missing your reply. Yes the bulbs are aligned different areas - please set the bulb 9 and 3 in your housing. You will see a slight difference in beam but nothing that causes any issues on road or usage. Did you email the team for help? [email protected]
    Thank you
    deAutoLED.com
  33. #73
    Veteran Member Three Rings FamousLastWords's Avatar
    Feb 06 2013
    So far so good. LED fogs installed and the look/function great. I had a slight issue when using both resisters (added to the order); one of the bulbs either would not turn on or would not change modes. I disconnected the second resister and everything works perfectly, no error lights, no issues.
    2015 S5 | 034 Stage 1
  34. #74
    Jan 13 2017
    marlton/nj/usa
    No resistors should not have been necessary
  35. #75
    Jan 13 2017
    marlton/nj/usa
    I have the same fogs
  36. #76
    Feb 06 2013
    Good to know. I thought I read it was needed in another thread. If they’re not giving you issues without I may swap the one out.
  37. #77
    Jan 13 2017
    marlton/nj/usa
    Quote Originally Posted by FamousLastWords View Post
    Not needed
  38. #78
    Feb 13 2015
    US
    Perfect LED installing weather:
    www.deAutoLED.com
    Thanks for sharing. It looks great.
    Yes some models do not need any resistors - we suggest trying without - you can always purchase later if you see any issues.
    Thank you
    deAutoLED.com
  39. #79
    Jan 13 2017
    marlton/nj/usa
    Thank you
    I checked and the leds are on the sides (9-3). That is the only way they will go in the housing. For what ever reason, the yellow illuminates higher
  40. #80
    Feb 13 2015
    US
    Diodes are higher yes you can turn 9 and 3 and put yellow on bottom and white on top.
    They are diodes stacked on top of each other.
    But that being said they are thin profile and while higher would not cause glare to others.
    deAutoLED.com
