Page 8 of 8 FirstFirst ... 678
Results 281 to 306 of 306
  1. #281
    Stage 3 Forum Advertiser Four Rings Excelerate Rep's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by Chuckster View Post
    Iíll take more when I get her outside again.
    13 mm front drop. 8mm rear drop.
    (Kept rear 5mm higher than front per recommendation by MSS).
    Absolutely lovely.
  2. #282
    Established Member Two Rings seank13's Avatar
    May 31 2017
    Olympia, WA
    Has anyone adjusted their rear height yet? Any tips for doing so? I've got a little over 1,000 miles on my kit and am convinced my installer didn't set the height correctly as I still have reverse rake.
    2017 Audi TTS
    2002 VW GTI 337
    1996 Toyota 4runner
    2008 Triumph Bonneville
    2016 Harley Davidson Sportster
  3. #283
    Established Member Two Rings Chuckster's Avatar
    Feb 18 2017
    '17 TTS & '16 Q3
    Socal
    Initially, I had both equal with no reverse rake, but asked to raise the rear to meet the recommended difference. I could have also just dropped the front more, but Iím not a low lifer. :)
    Adjusting the fronts are not as easy as Iíd like because you still have to drop the suspension from underneath since the adjustment is done from top.
  4. #284
    Feb 18 2017
    '17 TTS & '16 Q3
    Socal
    Hereís a better picture. I tried to get good lighting to show the wheel gap, which to me is secondary to the performance improvement.
  5. #285
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by seank13 View Post
    Did they set the rear 5mm higher than the front on initial install? How many miles do you have on the kit? The fronts take longer to settle (2,000 miles) I find the rear settles faster based off experience. If you don't have a good 2,000 miles on the kit and the car was setup 5mm higher in the back than I would leave it until you get the proper mileage on the car.
    To adjust you can generally do so with the supplied wrench depending on current ride height. If everything just spins while on the car, you can remove the lower outer control arm bolt, (supporting with a jack and slowly lowering) to get some of the pressure off and make the adjustment that way. It really depends!
    Cheers Sean!
    Man Rick was right, those wheels really pop on there, Chuck. I love it!
    Thanks,
    Greg
  6. #286
    May 31 2017
    Olympia, WA
    Quote Originally Posted by Excelerate Rep View Post
    Cheers Sean!
    Thanks, Greg! The tip about using a jack to relieve pressure could come in very handy. With regards to the installer setting rear 5mm higher, I'm not convinced they did. If anything I think they set it 7mm (one turn) lower. That said, I'm going to check all the measurements before I go doing anything. I only have 1,000 miles or so on the kit so I imagine it has settled some but not completely. I would normally leave it be until 2k, but I have a track day on Sunday and am concerned about the handling being off at speed. I'll definitely be adjusting again at 2,000. But before I do any of that I have to get myself out a VCDS screw up from messing with the rear brakes .
    2017 Audi TTS
    2002 VW GTI 337
    1996 Toyota 4runner
  7. #287
    Feb 14 2014
    Audi's
    Branford, CT
    I definitely understand that! I don't see anything wrong with your plan of action.
  8. #288
    Feb 14 2014
    Audi's
    Branford, CT
    @Lusky - Track Pack Equipped.... also equipped with a crap ton of horsepower. Installed, Purchased and built by MSS Kits Dealer - Iroz Motorsport.
  9. #289
    Mar 22 2016
    Las Vegas, NV
    First startup should be today. 60 miles engine break in then swap out the break in oil; then 700 miles of driving to break in the clutchpacks on a conservative 700whp tune. Suspension will get a chance to settle then
  10. #290
    Jun 14 2017
    Hopatcong NJ
    When are you bringing the car to Sparta? Iíd like to drive it.
    2017 Ibis TT 11/17 Austins-Michelin Snows 11/17 MSS KIT 2/18 StopTech ST40 BBK 3/22
  11. #291
    Established Member Two Rings DKo5's Avatar
    Aug 25 2014
    Quote Originally Posted by Lusky View Post
    700whp? Jeez. E85 I assume? Should be quite the beast!
    Sent from my Pixel using Tapatalk
    2015 S4 DSG - Daytona Grey
    EPL - JHM 179+CTS / Bilstein B16 / Milltek Non-res / Roc-Euro / AMS Cooler / Eurocode - sways+endlinks+Alu Kreuz / 034 mounts / CR-15 / RS-51 19x9.5 / PS4S
  12. #292
    Mar 22 2016
    Las Vegas, NV
    MK3 TT MSS Spring Kits - We want to know, are you interested?
    Quote Originally Posted by DKo5 View Post
    Yes e85. That is just the break in tune; Iroz will turn it up soon
  13. #293
    Aug 08 2017
    Ď16 VW GTI heavily modified
    Beaumont/Alberta/Canada
    Very envious of your build, I wish I had a Hank in my backyard! Just installed his DP & MP, almost a crime to hide those perfect weld in a place that is seldom seen. Ordered his ECU/TCU tuning also so I can get rid of the PO420 cat MIL. I might have to line something up for a trip south next winter and have Hank massage something in the way of a big turbo into my car :)
    Cheers!
  14. #294
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by Cale262 View Post
    Cheers!
    Peer pressure
  15. #295
    Established Member Two Rings kevinlee709's Avatar
    Jul 31 2014
    Audi SQ5 | BMW 1M
    toronto
    anyone with the track pack and fully lowered? I'd like to see what the fitment is like at the max. Thanks!
    current : MK3 TTRS (coming soon) | M235xi
    previous : 1M | SQ5 | MKV GTI | MKV R32
    instagram : _k___l_
  16. #296
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by kevinlee709 View Post
    Williams Black Coupe is equipped fully lowered on track pack. Ill find and post the photos.
  17. #297
    Jul 31 2014
    Audi SQ5 | BMW 1M
    toronto
    thanks!
    instagram : _k___l_
  18. #298
    Mar 08 2015
    Does TTS have MRS?
  19. #299
    Feb 18 2017
    '17 TTS & '16 Q3
    Socal
    Yes
  20. #300
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by reyoasian View Post
    Does TTS have MRS?
    Indeed they do.
  21. #301
    Feb 14 2014
    Audi's
    Branford, CT
    Don't forget about the 10% off we're running on MSS Kits either. Valid until Sunday.
    Williams Coupe!
  22. #302
    Jun 14 2017
    Hopatcong NJ
    Am I a baby if this sale irritates me?
  23. #303
    Feb 18 2017
    '17 TTS & '16 Q3
    Socal
    Yes :) 🚨🚑🍼
  24. #304
    Jun 14 2017
    Hopatcong NJ
    happy 420 chuck
  25. #305
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by ourlee View Post
    Yes :) 🚨🚑🍼
    Rick, you and Chuck crack me up. This was a last minute deal proposed by someone and someone twisted my arm to make this happen.
    If anyone else needs anything in the future, I will do my best to work my magic on other parts. You guys have my e-mail information.
    Cheers!
  26. #306
    Jun 14 2017
    Hopatcong NJ
    To cry about your awesome sale is to hate capitalism and America. Iím just teasing.
