After having issues with the front right door not unlocking with the rest of the car, I replaced the door lock module. Before that, when I would grab the handle to unlock the car, the car would try several times to unlock the door until I let go. The only way to open the door was by pulling in the inside handle.
Now, after replacement, the code persists and the touch handle will only lock the car, not unlock. The door lock operates just fine and unlocks and locks every time at least.
Door control module? Touch sensor? New door lock module somehow?
Thanks.
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007567205
Coding: 011C13204E00410001
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 236
