Results 1 to 5 of 5
    Mar 07 2014
    9 codes need help
    Hey everyone, just picked up an 01 laser red avant 1.8TQM with 200k. Don't have proof but PO has stated the head was rebuilt about 40k ago and there's a K04 installed, not sure about the ECU since I haven't been able to drive it. No brakes but was bled yesterday and now I have a pedal!!!!
    Anyway down to the car running. The O2 sensor was cut and there was a loud tapping noise (I thought the motor was bad) now after changing the O2 sensor the noise is gone. The pipe is separated at the flex pipe so I'm looking to clamp it with an extension until I can get a replacement put on. There is also a Spectre "CAI" and a small cone filter on the breather hose. The issue with the car is that it stalls when under load. It starts up and idles fine, but put it in gear and the it just proceeds to cut off. Put the car on 4 jack stands and put it in gear and no issue, as there is no real load. I can get the car to move tho if I keep the revs high enough to prevent it from falling. Also when I do move it its sounds like an STI with a straight exhaust.
    These are the codes that pops up even after clearing them. I do not have Vagcom
    1289, 1473, 0102, 0031, 0136, 0445, 0037, 0418, 0412
    Also I am missing a gas cap so I will be getting one Thursday so I know some of those emission's codes would clear out. But any idea how to get these dealt with? All help is appreciated
    Mar 07 2014
    Also I did a live data check and I noticed the MAF reading is at 0.00 even after swapping out to another MAF and unplugging the connector while the car is running and got no changes to the idle.
    Dec 05 2007
    Not going to spoon feed you things you can do yourself. Use the link below to decipher what your DTCs (diagnostic troubleshooting codes) are for, and then post up the ones that you are having difficulty with. I will assist from there .
    https://www.google.com/webhp?sourcei...%20tech%20wiki
    Mar 07 2014
    It was actually the fuse for the ECU 31 or 34.
    Dec 05 2007
    Nice you were able to fix the issue yourself. Even nicer...you updated your own thread
    Very underrated deed around these parts. Kudos to you, sir!
