Results 1 to 8 of 8
    Registered Member Two Rings lordy5's Avatar
    Sep 17 2005
    Audi a4 01'
    azusa
    Need Help ( Camber Kit..)
    I have recently dropped my car and after getting my wheels and tires I was going to get my alignment done and they told me i needed a CAMBER KIT.. I have been calling around to discover that no one can help me find a place to buy a camber kit... have any of you guys who dropped your cars ever had to purchase this..??
    Veteran Member Two Rings
    Feb 25 2004
    01 A4 1.8t, 07 A3 2.0t S-line
    Grand Prairie, TX
    search for a K-Mac kit. Probably the cheapest option in relation to CPP arms.
    Veteran Member Three Rings RAyala2.7T's Avatar
    Mar 08 2005
    Austin, TX
    you can adjust camber in the front and the back though. i've done it.
    Rob - 2000 Audi S4 VAST Stage III
    Veteran Member Four Rings scooter44's Avatar
    Feb 15 2005
    E46
    Bay Area <--> San Diego
    ^ yes you can, but only too a certain point.
    depends on how much you drop it..
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    http://www.audifans.com/pipermail/s-...er/023337.html
    i've got a set i'll sell you for $200 shipped. never opened.
    Jim
    I Do Werk.
    Veteran Member Four Rings salz2135's Avatar
    Sep 15 2005
    Austin, TX
    and do you really "need" to use a camber kit? haven't most people done their drops without them?
    Mar 08 2005
    Austin, TX
    i personally don't think you don't need to. I'm at -1.5 degrees camber all around. for reference the infiniti g35 coupes' factory camber setting is -2 degrees and during the time i worked there I've only seen a few tires with camber wear. it was mainly wear from the toe setting being off. i have no problems with my camber setting as far as camber wear. and i set my camber using the factory camber adjustment
    Jul 21 2005
    '99.5 A4 APR Stage 3+
    Alabama
    I'll be getting Koni COs sometime after Christmas. Should I tell the local VW shop just to allign my car or set the camber to -1.5 degrees. I would love the incresased handling but I'm not sure if they'll do this and I definetly can't afford premature tire wear.
