Originally Posted by
SR7D1
Hey everyone! Well, Primetime and I logged the car on Saturday and I have posted the link below. To review, I have the GAIC FORGE Stage 2 files and TCU tune. Here are some things I can share about that day:
Temperature was 30-32* out and we did not log IAT's because of how cold it was.
Plugs have about 8 months use, factory specs/gap. Car has 60K miles and PLM heat exchanger.
I am running straight 93 octane gas. So therefore these logs are on the 93 file from GIAC.
Tracks are closed up here so we went to "Mexico" to log.
So, I am not sure that the FORGE is the same as the AWE file? And, I know only enough about what to look for as relayed to me by Ron, what do you guys think?
https://drive.google.com/file/d/0B83...ew?usp=sharing
ignition timing isn't bad, considering the amount of corrections you had. You hit 17.5-18.3* peak in a few areas up top, and you did hit 19.125* with a -1.875* of correction in one area. If you add back in the corrections, you'll hit closer to 20-21*. I would be curious to see where your IAT's went, even in cold weather, the S/C will heat up those IAT's since looks like the runs were done with 3-5 minutes in between each other (or at least as far as I can tell via the VCDS timestamp).
Also, the specified charge pressures are in the 2000-2250hPa range across the majority of the board, this is pretty typical on stage II files that I've seen across several tuners and right where they should be to keep the bypass closed. With that being said, I am able to hit a few degrees higher on timing targets on my AWE stage II file, and my specified charge pressures were higher up top (normally in the 2300-2400hPa range, unobtainable for a standard stage II set-up).
I do wonder if your correction value's are due to a winter blend? The ignition correction value's are on the higher side than I would prefer, but it doesn't seem to affect the actual timing too much, which makes me wonder if your other cylinders are seeing almost 0* of correction. How long has it been since you had the plugs changed? If so, what spark plug gap?
