Results 1 to 7 of 7
    Dec 19 2004
    Fluidampr vs. Stock Crank Pulley swap questions
    Now that my car hit 50K miles, thinking of replacing the crank pulley as a proactive measure.
    Don't want to go over-sized or solid pulley so I either get stock or Fluidampr.
    However, looking at the Fluidampr site, it's unclear to me if they even make a stock sized pulley for our cars. If they do, which part number would it be (651211)?
    If going with stock, there are many brands out there, ranging in price from $200 to ~$400 for Audi brand. Any recommendations on what to avoid/get?
    2011 B8 S4 | EPL Stage 2 | KW H.A.S. | APR Stage 1 & 2 Carbonio Intake | Borla Exhaust | Eurocode Alu Kreuz | Eurocode ÜSS Stabilizer Bars and End Links | 034 Motorsport Trans Mount Insert | Spulen Rear Differential Mount | Hartman RS 4 Wheels
    Veteran Member Four Rings MugelloB7RS4's Avatar
    Feb 06 2015
    Quote Originally Posted by Cooper993 View Post
    Im not sure Fluidampr make a pulley for the supercharged 3.0L V6, as far as I know they only had listed the 30V engine which was a previous 3.0L NA motor. Someone correct me if I'm wrong, but I don't think its available.
    Nov 27 2015
    UK, West Berks
    Correct p/n is 651201
    2015 monsoon grey S5 sportback (yes the one with 4 doors)
    - MRC stage 2 (189mm Vdamper/Fluidampr crank pulley)
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    The Fluidampr without the sleeve is stock size and bolts right up. Also nice when you decide to tune just grab your preferred sleeve angle add.
    Best wishes.
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    They do, I have 1 on my 2012 A7.
    Sent from my Pixel 5 using Tapatalk
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    I know you say you don't want a overdrive pulley but the future you may want a power bump down the road. You don't see these things hit the classifieds too often.
    https://www.audizine.com/forum/showthread.php?t=936708
    Sent from my SM-N986U using Audizine Forum mobile app
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
    Established Member Two Rings PenttisHSR's Avatar
    Dec 22 2016
    England
    As regards a stock replacement, I went with Febi bilstein same as OE at less than half the price from Audi.
    Part No. 32196
    Link for spec....... https://partsfinder.bilsteingroup.co...+kW+%2F+333+hp
