Results 1 to 17 of 17
    Mar 07 2015
    2003 SL55 AMG, Audi Q7
    San Francisco, CA
    Best way to the bleed cooling system?
    I replaced the thermostat, water pump, some hoses and installed the APR front heat exchanger.
    I used a vacuum based coolant filler but i am not sure if i got all the air out. Car is not overheating, the cabin warms up nicely but I hear lots of "water moving" like sounds when i drive. Does this mean I have trapped air?
    Other than opening the bleeder bolts on the supercharger, what else do i need to do to make sure that there is no air trapped in the system?? Any other bleeding valves? Any tips?
    Veteran Member Three Rings Jflow23's Avatar
    Apr 09 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    Engine needs to be over 2k rpm when you open the screws...2 man job. It may burp by driving too.
    Mar 07 2015
    San Francisco, CA
    Ok. This is for the supercharger side of the cooling system.
    How do we bleed the engine side? How do we get air out of the heater core? Any other bleed valves?
    Established Member Two Rings weaselp1's Avatar
    Apr 21 2016
    Milwaukee, WI
    Quote Originally Posted by danmm7 View Post
    PM sent
    2013 S4 Premium +
    GIAC Stage 2 and TCU
    Phantom Black Pearl, MMI, B&O, Alcantera, CF
    Eurocode AK & Sways, Moog End Links, CTS Turbo Intake, CR-15
    HRE FF01 19x8.5 ET45 with PSS 265/35/19 - Summer Setup
    Alzor 18x8 ET35 Rotor reps with Nokain R2 - Winter Setup
    Registered User Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    Quote Originally Posted by weaselp1 View Post
    PM sent
    Awww post stuff here so others can see it
    Apr 05 2016
    Portland, OR
    Geoff
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Try the vacuum purge & fill again. But you have to dump out all the coolant first.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Turn the heater on then shut the car off so the heater valves are open.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Apr 21 2016
    Milwaukee, WI
    Quote Originally Posted by jbullin2 View Post
    I have the coolant refill procedure in a PDF document from elsawin ...can't post pdf files. Please pm me and I can email it to you!
    Thanks,
    Mike
    2013 S4 Premium +
    Jul 01 2012
    14 B8.5 S4, 90 Toyota Supra turbo (575 whp), 02 Subaru Wrx (stock atm),
    North little Rock, Ar
    Thanks,
    Mike
    Can I get that pdf in a pm too? Lol
    Apr 21 2016
    Milwaukee, WI
    Quote Originally Posted by mrb5_supra_wrx View Post
    PM me your email ...Can't send PDF files in PMs
    2013 S4 Premium +
    Senior Member Three Rings rgvsq5's Avatar
    Feb 03 2015
    Texas
    Reviving an old thread because it seems there is a special tool required to open supercharger bleed screws. They appear to be philips, but even using a large philips bit I believe I may have stripped one of them out. They are in there tight! Help?
    SQ5 | APR Stage 2+ : APR CPS v2 : AWE : Bilstein : H&R : ECS Tuning : 034Motorsport : P3Cars : Adam's Rotors : E-Code : XPEL
    Mar 21 2015
    Quote Originally Posted by rgvsq5 View Post
    Theres a thread from whipped where he replaced them with some modified regular bolts.
    Jan 09 2014
    2012 a4, 2015 s4
    TX
    I used a manual impact driver from harbor freight, using the Phillips #3 bit. It took a couple of whacks with a hammer but it comes loose. https://m.harborfreight.com/impact-s...ase-37530.html
    Dec 25 2019
    Howell, MI
    I used the schwaben coolant purge tool. The one you hookup to an air compressor. You can visually see the hoses fully collapse. I use like 90-100psi. Not sure if this fully gets air out, but it seems alright.
    - - - Updated - - -
    Have a full bucket of coolant and then after you create the suction you open another valve and only coolant gets sucked back in with a hose you dunk in a bucket of coolant
    Senior Member Three Rings Slvrbul8's Avatar
    Apr 14 2021
    300zxTT and E46 BMW 330i
    Roanoke, Va
    I thought the APR HX was supposed to be self-bleeding with no human intervention required?
    Jul 31 2016
    PA
    Quote Originally Posted by Slvrbul8 View Post
    That feature is to maintain a path for any residual air, it's not a replacement vent for the whole system, it's not even at the high point. It's just to help keep the HX from getting air bound. If it was significantly drained/filled, it needs a full system bleed.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
