Originally Posted by
leggydan
I tried to retrofit the reverse camera kit to my 2012 a7. it seems to randomly work for me, sometimes it displays the camera view, but no OPC display, sometimes just a black screen. so my question is was there a factory option possible to have the 360 degree OPC with park assist and also the reverse camera? Mine is EU spec 3.0 TDI
Sorry, missed this question.
The answer is yes, there is an option for front and rear cameras on the A7 platform, however you don't get the "birds eye overhead view" that you get with the A6 platform as there is no option for cameras in the wing mirrors.
I retro fitted a rear camera into my A7, and it was fully functional every time, including OPC. So my question would be are you using an aftermarket solution, or are you using OEM components, including camera and control module, and correctly coded to the car?
Regarding front
and rear cameras.
While similar to the stand alone rear camera, it is in fact a completely different system. The single rear camera installation is an analogue camera. The front and rear camera solution uses digital cameras, with a completely different control module, but the principle of operation is similar to the single rear camera, and the on screen display is the same - the front cam picture doesn't have the tire track guides, just a red line which any object shouldn't cross.
You should talk to a good aftermarket OEM installer for advice
