Page 30 of 66 FirstFirst ... 20282930313240 ... LastLast
Results 1,161 to 1,200 of 2610
  1. #1161
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by MolonLabe300 View Post
    IIRC Forge sells those.
    Sent from my Pixel 2 XL using Audizine mobile app
    Think I found it.
    https://www.forgemotorsport.com/Forg...uct--1446.html
  2. #1162
    Jun 06 2016
    Florida
    Does the 2018 S6 “learn” your driving style and change things like shift points? (I’m not talking about Auto mode)
    2018 Daytona Gray S6 | S Sport | Black Optic | Carbon Atlas |
    2011 Phantom Black S4 | S-Tronic | P+ | Nav | Sports Differential | Titanium Package | Silk Nappa | SOLD
  3. #1163
    Mar 27 2019
    Quote Originally Posted by Dirt View Post
    I think what you’re referring to is an adaptive transmission. I’m not sure the S6 has it.
  4. #1164
    Mar 08 2007
    “Fuzzy logic” All Audi’s have had this for years. Which is why, when a customer comes in with a transmission concern, we’re not too quick to perform a basic settings on the transmission because it erases this and takes 500-1000 miles to fully adapt and can cause more concerns till it finishes.
    2016 A6 Ibis White 3.0 TDI Premium Plus S line sport package LED headlights
    Gone
    2017 Allroad Glacier White Premium Plus Tech Package Sport Package
    2017 A4 Ibis White Premium Convenience Package
    2013 Allroad Glacier White Premium Plus
    2001 A4 Quattro Silver RNSE
  5. #1165
    Jun 06 2016
    Florida
    Quote Originally Posted by wuplur View Post
    Could you please explain further?
    Here’s why I’m asking: when I first installed a piggyback tuner, the only side effect was more power. As time passes and more miles are put on the car, it feels like the transmission has a longer pause before engaging reverse. There’s also a minor stumble or hesitation when leaving from a stop. I don’t experience either of these when the piggyback is removed or for the first couple of days after it’s installed.
  6. #1166
    Jun 06 2016
    Florida
    Quote Originally Posted by Shuga View Post
    Pics of your former cars?
    https://www.audizine.com/forum/showt...-are-your-cars
  7. #1167
    Mar 27 2019
    Lol thank you for bringing that thread to my attention as I haven’t seen it yet, just because someone has a hard on for me I’m not going to post my cars for people to rate them.
  8. #1168
    Mar 27 2019
    Try resetting the transmission. On my Touareg the procedure is Car off.... push the ignition on engine NOT running 3: Press gas pedal all the way to the floor.... hold for 10 to 15-seconds. 4: Take foot off gas pedal 5: Turn off car. Open driver's door Close the door. Restart car
  9. #1169
    Sep 09 2010
    Destin, FL
    You troll this thread daily and you didn't see it huh? Let's see some car pictures and the post above is the most useful thing you posted here.
  10. #1170
    Mar 27 2019
    Questions you thought were too dumb to ask
    Quote Originally Posted by The Infiltrator View Post
    You Scroll through this thread daily and you didn't see it huh? Let's see some car pictures and the post above is the most useful thing you posted here.
    FTFY, I actually didn’t see that thread.
    And that’s debatable.
  11. #1171
    Nov 01 2015
    13 S6, 08 911 turbo, 04 LS1/T56 IS300, 02 VFR800, 93 MR2 turbo, 14 Tundra, 17 MKZ hybrid, 19 Q7
    LaGrange GA
    @Dirt
    Is your transmission issue intermittent, or does it happen all the time? I have a similar issue, but it is very intermittent. When pulling away from a stop, I let off the brake, the rpms drop a few hundred and it feels as though it has dropped into neutral, then it will grab 1st somewhat harshly. It will also do the same occasionally when shifting into reverse. Typically in a 3 point turn scenario. Drive forward, stop, shift to reverse, but it feels as though it drops into neutral for a second, then it will grab reverse. Does this sound like your issue?
    I cannot recall if it ever happened stock. I think it might have, but I went APR stage 2 ECU and TCU within a few hundred miles of getting the car, so I didn't have much experience with it stock. I am now stage 3 APR ECU and TCU and it still happens, but only occasionally. I had a couple of guys at APR drive it, but of course it wouldn't do it with someone else driving....
    13 S5
    19 Q7 Prestige, black optics, luxury, cold weather
    14 911 Turbo S 68mm turbos, methanol injection, Kline headers and exhaust, Cobb AP, AMS intercoolers, IPD y-pipe and plenum, BMC filter
    14 Panamera Turbo Fabspeed downpipes
    93 MR2 turbo gen3 3sgte, t3/t4, 264s, AEM
    05 C6 Corvette 6MT, built engine, twin turbo, methanol injection
    02 VFR800
    19 RAM 1500 Limited
  12. #1172
    Jun 06 2016
    Florida
    Quote Originally Posted by vman932 View Post
    @Dirt
    It only seems to do it after the piggyback has been on for a while, but my issue does sound similar to yours. The hesitation is fairly consistent after it shows up.
  13. #1173
    Nov 01 2015
    LaGrange GA
    I assume your piggyback tune is strictly ECU correct? No TCU tune? I'll try flashing my ECU back to the stock file and see whether or not it shows up.
    13 S5
    02 VFR800
    19 RAM 1500 Limited
  14. #1174
    Jun 06 2016
    Florida
    Thanks man. And you’re correct: ECU only
  15. #1175
    Sep 09 2010
    Destin, FL
    I found this interesting and thought I'd share. Might be a good idea for people with the old oil screens and haven't changed them yet.
    https://blog.amsoil.com/is-an-engine-flush-good-or-bad/
  16. #1176
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    @Dirt
    There's actually a class action lawsuit against Audi for the issue you're describing but they probably won't use your car as part of their lawsuit since the TCU is tuned. Here's the latest news on that: https://topclassactions.com/lawsuit-...d-leave-amend/
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
  17. #1177
    Nov 01 2015
    LaGrange GA
    Quote Originally Posted by ericw. View Post
    My issue only happens from a stop. The issues described in that class action suit are shifting into 2nd, 3rd or 4th, or hard downshifts on decel. I don't have any of those issues. No mention of anything from a stop.
    Quote Originally Posted by class action lawsuit
    The Audi class action lawsuit alleged that the defective gearbox caused “juddering” or jerking in the affected vehicles when shifting into second, third, or fourth gear.
    The plaintiffs said that the defect also caused a dangerous pause before acceleration that could result in a hard downshift when decelerating.
    13 S5
    02 VFR800
    19 RAM 1500 Limited
  18. #1178
    Apr 23 2011
    Sac Area, CA
    What about this part?
    The APR TCU tune solves for the rough shifts.
    IG @lolzhax
    //AGILITYDRIVES.US
  19. #1179
    Nov 01 2015
    LaGrange GA
    Read the portion after what you bolded: "could result in a hard downshift when decelerating" - This implies the "pause before acceleration" is while in motion.
    13 S5
    02 VFR800
    19 RAM 1500 Limited
  20. #1180
    Apr 23 2011
    Sac Area, CA
    Could isn't a certainty and the TCU tune has changed the shift points for better shifting.
    Sent from my SM-G950U using Tapatalk
    IG @lolzhax
    //AGILITYDRIVES.US
  21. #1181
    Established Member Two Rings PeoplesChoice's Avatar
    Dec 23 2018
    Chesterfield, MO
    I have a 2014 RS7 and I'm looking at a the AK-Racing-47 lowering module. It says that in order for it to work, I have to have the factory air suspension. How can I tell if I my car has this?
    https://www.youtube.com/watch?v=wdhlXAzulso
  22. #1182
    Apr 23 2011
    Sac Area, CA
    Quote Originally Posted by PeoplesChoice View Post
    Your car will change ride height between comfort and dynamic mode if you're on air ride. You'll also have the "raise" function on the MMI. All RS7 in America came with air ride unless it's the Performance edition.
    IG @lolzhax
    //AGILITYDRIVES.US
  23. #1183
    Dec 23 2018
    Chesterfield, MO
    You are awesome, thank you!
  24. #1184
    Jan 07 2011
    2013 C300 4Matic
    Stock s7 ( with intake ) vs b8.5 stage 2+
    Which is faster u think?
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
  25. #1185
    Mar 27 2019
    B8.5 what? S5? S4?
  26. #1186
    Jan 07 2011
    2013 C300 4Matic
    B8.5 what? S5? S4?
    S5
    Present:
    IG: bknewtype
  27. #1187
    Mar 27 2019
    S5
    Hmm. I think it’d be extremely close. You have the weight...
  28. #1188
    Jan 07 2011
    2013 C300 4Matic
    Whats the lowest someone went on factory air without issued? Im looking to close more of my wheel gap but iv already exceeded whatever was recommended on the vagcom guide. I think 14-17mm or something like tnat
    Present:
    IG: bknewtype
  29. #1189
    Veteran Member Four Rings ThewhippetsS5's Avatar
    Jul 12 2013
    MD & HI
    17
    Sent from my SM-G960U using Tapatalk
    - Jeremy | Instagram: Oahu.Homes
    2012 Audi R8 GT
    2016 Audi RS7
    2015 BMW X5M
  30. #1190
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by ThewhippetsS5 View Post
    17
    Whats the current value on urs? U lowered?
    Present:
    IG: bknewtype
  31. #1191
    Apr 23 2011
    Sac Area, CA
    B8.5 what? S5? S4?
    The stage 2 S5 will be faster especially against a stock S7.
    S5 3.0t will run mid 11's at stage 2 w/ 100 octane.
    IG @lolzhax
    //AGILITYDRIVES.US
  32. #1192
    Junior Member Two Rings
    May 02 2019
    Georgia USA
    I have a 2017 A6 Quattro. Being all-wheel drive. Do I need to rotate the tires? I know I should balance them but not sure about rotating since they all should have the same wear on the treads.
    2017 A6 3.0T Prestige
  33. #1193
    Apr 07 2006
    Burlington, Ontario
    Quote Originally Posted by X_BMW View Post
    I would rotate front to back as the front wheels carry the engine weight and do all the cornering so they'll wear slightly faster...at least that is the way I approach it.
    2013 Audi S7: Audi exclusive interior, carbon fiber updates, RS7 rear bumper conversion, 20" PUR FL26 wheels
  34. #1194
    Jun 06 2016
    Florida
    Agree with this
  35. #1195
    Established Member Two Rings bryanb8's Avatar
    Apr 10 2018
    NorCal
    I was advised from more than one Audi service center not to rotate tires on a Quattro car. Balance yes, rotate no.
    Current: 2018 S6 Prestige - Glacier White Metallic/Black, S tronic, Valcona Leather, Bang & Olufsen, S Sport Package, Driver Assistance Package, 20" Black Optic Package, Carbon Atlas Inlays, Audi Beam Rings
    Former: 2014 S5 Premium Plus - Glacier White Metallic/Black, S tronic, Nappa Leather, Sports Differential, B&O, Carbon Atlas, Side Assist, MMI Nav Plus Package, 19" 5 seg Peelers, SC badges, all weather package
  36. #1196
    Oct 18 2016
    WA
    The thing to look out for is having big differences in tread depth side to side and front to rear as the car will treat the worn tire(s) as wheel slip, which will lead to excessive wear or damage to the diffs. I forget what the exact numbers are for the maximum allowable tread difference side to side and front to rear, but you can find it in the owner's manual. Tire wear depends on a lot of factors (alignment, air pressure, how you drive the car, etc), but I'd venture a guess that with the car being rear-biased and those wheels doing most of the work when you're accelerating...probably going to see a little bit more wear on the rear tires.
    It's totally fine to rotate the tires within the wear recommendations of the manual. Rotating just front to back should be most helpful if you're looking to get the most life out of a set of tires (something is probably out of alignment if you're seeing substantially different wear side to side).
  37. #1197
    Jun 06 2016
    Florida
    Quote Originally Posted by bryanb8 View Post
    Why?
  38. #1198
    Apr 10 2018
    NorCal
    They all said they wear at an even rate and not to rotate them due to alignment issues as well. Some may not agree, but I'm just stating what they all have been telling me for years. Surprisingly, this has rung true for all my previous Audi's with Quattro. When I replaced the tires the wear was always within 1/32 of tread on all...and I even take the twisties home every day from work. Just passing along, I'm sure some will swear by and fume about non-rotation of tires on any car.
  39. #1199
    Oct 31 2018
    Astoria NY
    Are there factory rear and side sunshades for the A/S/RS7 models? I’ve found the rear with part number 4G8-861-325, but it appears to mount in a less than ideal location. I’m looking for something that will attach close to the glass instead of behind the rear headrests.
  40. #1200
    Aug 08 2018
    New Hampshire
    Quote Originally Posted by Practical View Post
    Just get a ceramic tint, tidier and looks cool.
