Page 12 of 66 FirstFirst ... 210111213142262 ... LastLast
Results 441 to 480 of 2610
  1. #441
    Sep 02 2017
    How warm should the Heated Steering wheel feel?
    I barely feel anything and I'm not sure it's working.
    Thanks
    Sent from my Pixel XL using Tapatalk
  2. #442
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by BenMTL View Post
    This thread should be sticked at the top of this section
    Anyway, is the center bore for A7s 66.6 or 66.5? If I get wheels that are 0.01mm off, will I need hub centric rings or not a big enough difference to notice?
    Agreed!
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
  3. #443
    Sep 28 2009
    suburb
    It gets quite hot with mine,.
    Quote Originally Posted by Reflexxx View Post
    Thanks
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
  4. #444
    Established Member Two Rings BB c7's Avatar
    Jan 23 2016
    Chicago
    Quote Originally Posted by SleekS7 View Post
    Yes, you need a Vagcom capable tool. I used OBDEleven tor reset mine. https://shopdap.com/store/vw-audi-sc...obdeleven.html
    You can use it to do all the VCDS modifications as well.
    Hello. Interested in this device. Much cheaper than rosstech cable.
    Other than reseting reminder what else can i do with it ?
    Is there big difference between OBDEleven and Rosstch ?
  5. #445
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    Quote Originally Posted by BB c7 View Post
    Rosstech is capable of doing much more, especially with troubleshooting and logging.
    OBDEleven is like basic rosstech for dummies with some preprogrammed functions but doesn't have access to everything. It might be fine if resetting or reading fault codes and doing a few mods is all you need.
    Sent from my SM-G950U using Tapatalk
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
  6. #446
    Mar 17 2017
    Redondo Beach, CA
    Quote Originally Posted by ericw. View Post
    It can do all the VAGCOM codings and adaptations same as Rosstech. The preprogrammed "apps" are just a bonus when you don't want to spend the time to go through making the same changes via long coding, the same long coding you are forced to do with Rosstech.
    It also automatically stores all the changes you made in case you want to reverse it. I believe it can also log, but haven't needed to use it. If you are looking to do VAGCOM mods like lowering, green screen, VIM, laptimer, or anything else like the 99% of us, OBDEleven is a good cheap option.
    Go with Rosstech if you are not technical or want to do more indepth coding that haven't been discovered yet. They have outstanding support.
    2013 Phantom Black S7 | Bang & Olufsen | Driver Assistance | Night Vision | HUD | Comfort seats | LED headlights | 20" 5-arm-rotor design | Carbon atlas inlays | Cold weather package | EPL Stage 1
  7. #447
    Apr 23 2011
    Sac Area, CA
    I'm under the impression that you can't log every sensor with obdeleven. Also anything with security codes required. I could be wrong though. One thing I'm sure of is that the app is more user friendly than the vcds software.
    IG @lolzhax
    //AGILITYDRIVES.US
  8. #448
    Mar 17 2017
    Redondo Beach, CA
    I've used it for live data monitoring and there's a plethora of sensors and data to choose from, can't say if it's "every" sensor since I don't think anyone knows them all You can do security codes, I've had to do that for some of the codings I've done.
  9. #449
    Jan 23 2016
    Chicago
    So u saying OBDEleven harder to use ?
    But able to do pretty much everything?
  10. #450
    Jan 23 2016
    Chicago
    Well just did some digging on obdeleven. Looks like i can do coding instead of using a app spending $. Bit how would u figure out the coding when enter a new value ? Is that coding same code as a ross tech ?
    Os there a any online source do u know ?
    Thanks
  11. #451
    Mar 17 2017
    Redondo Beach, CA
    Thanks
    Easier to use.
    Yes.
    Same as Rosstech, you are still modifying the same settings regardless of which tool you use.
    Here's a good start of some known VAGCOM mods http://www.audizine.com/forum/showth...-list-and-help
    The wording/description of each module may be slightly different between OBDEleven and Rosstech but you are still accessing the same modules on your car. Once you understand how to "translate" the Rosstech instructions to OBDEleven it's a no brainer. But if you are the type that must follow directions to the letter, get a Rosstech since most VAGCOM instructions like in the link above will be based off using Rosstech.
  12. #452
    Jan 23 2016
    Chicago
    Easier to use.
    Yes.
    Thanks for the info.
  13. #453
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    My B7 A4 has down tilting mirrors when reversing (so I can see the curb etc).
    Can any A7s do that? How?
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
  14. #454
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    AFAIK most modern Audis do this when the passenger mirror is selected with the selector switch...
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
  15. #455
    Veteran Member Three Rings sickmade0331's Avatar
    Nov 11 2013
    Monroe Washington
    If I remember correctly you have to switch to right mirror put car in reverse change mirror to desired level then switch out of reverse fox mirror to normal driving setting then when you put your car in reverse with the right mirror selected it should tilt to the level you put it at for parallel parking.
    Sent from my SM-G955U using Audizine mobile app
  16. #456
    Nov 11 2013
    Monroe Washington
    Thanks
    You can turn the heat up via vagcom
  17. #457
    Established Member Two Rings jtron's Avatar
    Jun 23 2017
    Gainesville, FL
    This is literally burning my insides. B8 A4 2.0t and C7 A6 2.0t have the same EA888 Gen 2, correct? Parts should generally be somewhat near a direct fit?
    2014 A6 2.0 TFSI Prem Pl | APR 93 STG II | K&N RAI | APR Downpipe | Custom 3" w Borla Mufflers | Spec 1 SPL-001 | H&R Coil Springs
    Prev: 2012 A4 S-Line
  18. #458
    Junior Member Two Rings reggiesdesign's Avatar
    Sep 13 2017
    Australia
    Went to change my puddle lights and was following the instructions from a previous post. Seems simple enough except my existing puddle lights don't seem to want to come out. I can drop the first clip easy enough but the other clip feels very tight as though it would break if I pull any harder. Anyone else have this issue?? Tempted to try again and pull harder but don't want to break anything or pull wiring apart. Does this sound normal?
  19. #459
    Jun 23 2017
    Gainesville, FL
    Quote Originally Posted by reggiesdesign View Post
    Mine came out very easily, no resistance at all. Actually installed a 4-ring to puddle lamp under the fronts and was done in 3-5 minutes
  20. #460
    Jun 23 2017
    Gainesville, FL
    Now that I write this I have to ask the silly question...have you tried pulling from the other side? Could be the clip is on the side you’re trying to maneuver from.
  21. #461
    Sep 13 2017
    Australia
    Quote Originally Posted by jtron View Post
    Thanks. Will check again tomorrow after work. Gotta be something silly like that. First mod for this car and stuck already. Maybe I'm just getting too old. 😉
  22. #462
    Active Member Two Rings gsujeff55's Avatar
    Nov 01 2017
    St Marys GA
    New owner of a C7.5 S6 here and have a couple of stupid questions about problems I can't solve.
    Is there memory for satellite radio so you can rewind like there is in every other vehicle with SiriusXM since like 2012? I can't seem to figure it out if there is.
    Is there a quick way to navigate through artists with apple car play that I can't find? Surely you don't have to scroll all the way through things to get to the end.
    Do all vehicles with the driver assist package have the parking assist feature? I can't find it anywhere on mine.
    Thanks fellas
    '18 Glacier White S6
  23. #463
    Jun 30 2016
    NNJ
    Quote Originally Posted by gsujeff55 View Post
    Nope, it's annoying.
    You might be able to write a letter to jump to it but I don't believe so.
    Thanks fellas
    Not available on US spec cars.
  24. #464
    Nov 01 2017
    St Marys GA
    Quote Originally Posted by MadMaxD View Post
    Thank you!
  25. #465
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    One end has a clip. The other end is the electrical connector. I pried mine from the center to see which end was loose and then pulled the loose end down. I used a butter knife to remove and it came in handy when used like a shoehorn for the installation. Another factor is the size of the electrical connector. Some are large, some are small. If yours doesn't match, you need a pair of jumper wires to make the connection.
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
  26. #466
    Sep 13 2017
    Australia
    Quote Originally Posted by tenspeed View Post
    It is the side with the electrical connector which is tight. I was worried about pulling too hard in case I pulled the wires from the connector. The puddle lights I bought came with an adapter for both sizes..... but haven't got to that part yet. Maybe tonight :)
  27. #467
    Senior Member Three Rings drdrewusaf's Avatar
    May 31 2012
    San Antonio Texas
    This one has been bugging me for a while... Adaptive dampening, and adaptive air, as far as suspension is concerned, are two different things, right? Like, if I install a lowering module, or links, and I have the car in comfort mode, I can have a ride that is both soft AND low (vs. stock where low=stiff)?
    Drew
  28. #468
    Dec 19 2012
    Europe
    Guys, I heard somewhere that some C7s (A6/A7, etc) cannot get a regular wheel alignment done...Due to some sensors or cameras.
    Instead that must get one done it done exclusively at an Audi dealership for a much higher cost...Does anyone have more info about this?
    What package/options are affected by this? I do have ACC for example, but not sure if related?
  29. #469
    Senior Member Three Rings 2wookies's Avatar
    Jun 03 2016
    Omaha NE
    WRONG! As long as nothing as been done to the Active Cruise Control system you can get a standard toe alignment(not sure on camber). I just went through this after raising my coilover's up on my car then taking it to the dealership for an alignment. I asked specifically about the $650 alignment and they said no as long as the camera's haven't been touched you're fine. But if a non-dealer is telling you this I would just go to your local dealership and have them do it.
  30. #470
    I have been experiencing a sputtering even slight jerking under moderate acceleration in my S7. I bought car about 6 months ago.. and Tuned with Epl Stage 1 + Roc Euro intake. I have been switching back oem intake and also to stock Program file.. seems to be more evident when its Tuned. However completely not noticeable at full acceleration ?? Anyone ever noticed this in their S6/S7 ?? Please chime inn I feel like something is wrongly going on.!
  31. #471
    Nov 11 2013
    Monroe Washington
    Quote Originally Posted by Hugonzalez01 View Post
    I get the same thing I believe third gear merging on the freeway slowly but slight acceleration maybe quarter throttle and I feel a small jerking like the car is hesitating or missing I dunno what it is im Apr stage 2
  32. #472
    Mar 11 2007
    Colorado Springs
    You would be correct. The clip is one sided. The side that's giving him problems is the side he shouldn't pull on. Go to the other side, learned the hard way...
    2012 A8L 4.2
  33. #473
    Established Member Two Rings Rlynch03's Avatar
    Oct 27 2017
    07 Acura MDX, 16 Dodge Durango Hemi
    Annapolis
    Thanks
    Which model do you have? I have thought the same thing.
  34. #474
    Sep 02 2017
    Quote Originally Posted by Rlynch03 View Post
    2013 S7
    I had to reschedule my dealership visit but still feel it's barely getting warm and is inconsistent.
  35. #475
    Quote Originally Posted by sickmade0331 View Post
    Ever had it diagnosed ? I took my car back to dealership thought it was transmission, or missing.. but switched tune to stock. They said it was Fine.when driving in Stock file & stock Air-box felt better. But Sower under full throttle..
  36. #476
    Nov 11 2013
    Monroe Washington
    No I don't drive like that ever only with my wife I drive like i stole it so never needed to
  37. #477
    Nov 08 2010
    MD
    I think this is as good a place as any for my dumb question .... I've never really understood this ... once my S6 is lowered in Dynamic, does the car lower *more* at highway speeds or is it already as low as it goes. Reason I ask, I'm lowered with VCDS and wondering if, again in Dynamic, the car lowers even more at higher speed? That would be getting too low for me. Thx for any input!
    2021 SQ8 Prestige - Daytona Gray Pearl
    2018 Q7 Prestige - Samurai Grey
    Past: '19 Cayenne S | '15 S8 | '17 Q7 | '17 Macan S | '14 S6 4.0T | '14 Q5 3.0T | '13 RS5 Coupe | '13 Q5 3.2 | '11 S5 Coupe | '10 Q5 3.2 | '05 allroad 2.7t | '02 A4 3.0 | '00 A6 4.2 | '99 A6 avant 3.0
  38. #478
    Apr 23 2011
    Sac Area, CA
    Quote Originally Posted by KT88 View Post
    Nope, what you see is what you get.
    IG @lolzhax
    //AGILITYDRIVES.US
  39. #479
    Sep 28 2009
    suburb
    OK I just tried to change them. What's the secret? Do I just push down (or up since it's at the bottom) forcefully on one side and it should pop out?
    Audi SQ7
    Audi B8 S5 (gone)
  40. #480
    Sep 28 2009
    suburb
    Here's a vid on how to do the puddle lights: https://www.youtube.com/watch?v=G-9nfBrqSX4
    Audi SQ7
    Audi B8 S5 (gone)
