Page 11 of 66 FirstFirst ... 9101112132161 ... LastLast
Results 401 to 440 of 2610
  1. #401
    Aug 11 2016
    CA
    Quote Originally Posted by BenMTL View Post
    So if I don't have that button on my steering wheel, I don't have a heated steering wheel?
    I asked because I've been shopping for A7s for a year now until I bought mine recently, and never once saw that button so in Europe it either wasn't an option at all or extremely rare....
    Correct.
  2. #402
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    This thread should be sticked at the top of this section
    Anyway, is the center bore for A7s 66.6 or 66.5? If I get wheels that are 0.01mm off, will I need hub centric rings or not a big enough difference to notice?
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
  3. #403
    Veteran Member Three Rings Frenetic's Avatar
    Dec 13 2015
    '17 Audi S7
    CA
    Center Bore: 66.5 mm
    Lug pattern: 5x112
    Lug size: M14x1.5
    OEM sizes (I think...):
    19x8.5 et32 @ 255x40zr19
    20x9 et37 @ 265x35zr20
    21x9 et35 @ 275x30zr21
    2020 BMW X5 M50i | 2017 AUDI S7 (gone)
  4. #404
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    I'm looking for front left and right fog grilles without adaptive cruise control in black optic.
    Does anyone know where I can find that? I thought I saw it on ECS but I can't find it anymore.
    Why? Because I originally had mine wrapped black and it started to peel up in 1 spot. I'm going to have it re-wrapped but I'd also like to get my order in for the black-optic edition so I don't need to maintain it. lol
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
  5. #405
    Sep 05 2017
    TX
    14' Q7 S-line
    Just bought it for my wife two weeks ago, and have what hopefully is a simple, silly question.
    Each time she starts it and turns the A/C on, the rear A/C comes on as well, which she'll reach back and turn off if the kids aren't onboard.
    Is this in a setting somewhere that can be changed? She wants to turn on the A/C and have only the front A/C come one.
    Didn't see anything in the manual..
    Thanks
  6. #406
    Sep 22 2013
    Norway
    Quote Originally Posted by ericw. View Post
    https://www.aliexpress.com/store/pro...752470825.html
    |A7|3.0|TFSI|B&O|NightVision|HeadsUp|Led Headlights|
  7. #407
    Dec 13 2015
    '17 Audi S7
    CA
    I know in our cars, this setting is found in Car settings (from the drive select screen) then AC or Climate settings (forgot the name, but it will only show up or be adjustable if the climate control is on) and then rear seat settings. You can adjust it to either mirror the front or leave it independent and hence off.
    Not sure about the Q7, although I wouldn’t imagine it being too different.
    Quote Originally Posted by Fly'n Family View Post
    14' Q7 S-line
    Thanks
  8. #408
    Apr 23 2011
    Sac Area, CA
    I'm looking for oem for an S7. Thanks anyway though.
    Sent from my SM-G950U using Tapatalk
    IG @lolzhax
    //AGILITYDRIVES.US
  9. #409
    Apr 23 2011
    Sac Area, CA
    Answering my own question for the future searchers. ;)
    https://europrice.us/bumper-grilles-a7-s7-black-optic
    IG @lolzhax
    //AGILITYDRIVES.US
  10. #410
    Veteran Member Four Rings scmtkings4's Avatar
    Oct 06 2016
    Brooklyn, NY
    Hey guys, probably a stupid question but how do you tell which side a caliper is for?
    I picked up two front calipers for an A7 from a junkyard but there seems to be no discernible difference between the two? How do I tell which side is driver side and which is passenger side?
    Sent from my BBB100-1 using Audizine mobile app
    2014 S5
    AWE Touring Exhaust l ECS Intake l EPL Dual Pulley 93 l AMS Alpha Cooler
  11. #411
    Active Member One Ring DownUnder's Avatar
    Aug 17 2017
    Australia
    Will an S7 rear diffuser / valance fit an S6 rear bumper (and therefore an s-line rear bumper on my C7 A6)?
    There seems to be more aftermarket options out there the A7/S7. I understand some people have fit an RS7 rear valance to an C7 and it required some modification, but I haven't come across an S7 one.
    I am looking for something a bit more aggressive that will accommodate quad tips.
  12. #412
    Apr 23 2011
    Sac Area, CA
    Quote Originally Posted by DownUnder View Post
    Will not fit without some heavy modification.
    IG @lolzhax
    //AGILITYDRIVES.US
  13. #413
    Oct 06 2016
    Brooklyn, NY
    Quote Originally Posted by scmtkings4 View Post
    Nvm, got my answer from a gentleman here on the forums.
    Bleeder screws always have to be at the top of the calipers. That's how you tell rh from lh calipers
    2014 S5
  14. #414
    Oct 02 2005
    The Moon
    Audizine mobile app
  15. #415
    Oct 06 2016
    Brooklyn, NY
    Quote Originally Posted by p3u View Post
    The bleeder and brake lines are at the top of calipers no? That's how you tell which side the caliper is no?
    If that's not the correct answer wouldn't it be more helpful to actually provide an answer instead of a useless meme?
    2014 S5
  16. #416
    Oct 02 2005
    The Moon
    Face palm because you're telling us like it's news the bleeder valve goes on top...air always raises to the top on any caliper lol. This is your first time working on brakes?
  17. #417
    Oct 06 2016
    Brooklyn, NY
    You'd be surprised, I asked several guys on the forums this and they couldn't help.
    I wasn't touting the valve being on top as news. Just merely following up on my own question on caliper differentiation
    2014 S5
  18. #418
    Established Member Two Rings jtron's Avatar
    Jun 23 2017
    Gainesville, FL
    Can't believe I'm going to ask this, thank god for this thread.
    Having a devil of a time finding an intercooler for the 2.0, is there any other model I could buy for and have it easily fabbed into the same area? I just find it so mind-blowing that I can never find any real parts for this engine. There's not even exhaust that won't have to be modified to work, it's insanely frustrating.
    2014 A6 2.0 TFSI Prem Pl | APR 93 STG II | K&N RAI | APR Downpipe | Custom 3" w Borla Mufflers | Spec 1 SPL-001 | H&R Coil Springs
    Prev: 2012 A4 S-Line
  19. #419
    Oct 14 2014
    United States
    I recently changed the oil on my 2015 RS7 and reset the oil change reminder.
    However I still get a service reminder warning.
    Can this be reset without going to a dealer?
    Does it require some sort of tool like VCDS? If so what are the best options at a reasonable cost?
  20. #420
    Mar 17 2017
    Redondo Beach, CA
    Quote Originally Posted by jb1970 View Post
    Yes, you need a Vagcom capable tool. I used OBDEleven tor reset mine. https://shopdap.com/store/vw-audi-sc...obdeleven.html
    You can use it to do all the VCDS modifications as well.
    2013 Phantom Black S7 | Bang & Olufsen | Driver Assistance | Night Vision | HUD | Comfort seats | LED headlights | 20" 5-arm-rotor design | Carbon atlas inlays | Cold weather package | EPL Stage 1
  21. #421
    Deactivated Four Rings
    Oct 22 2013
    New York
    Not sure if this has ever been asked but I’ve noticed after warming up my car sometimes my redline will be at 5K and then resort back to about 6400 rpms. I’ve noticed it’s more or less happens when I’ve got less than a 100 range on my gas. Anyone else run into this?
  22. #422
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    As the engine warms up the redline increases
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
  23. #423
    Veteran Member Three Rings sickmade0331's Avatar
    Nov 11 2013
    Monroe Washington
    Quote Originally Posted by B6Michael View Post
    That happens every time your car is cold and the engine isn't warmed up to stop people from doing stupid things before the car is warmed up!
    Sent from my SM-G955U using Audizine mobile app
  24. #424
    Oct 22 2013
    New York
    Quote Originally Posted by sickmade0331 View Post
    Thanks hahaha I thought it might be that but seeming as it went to the next bar over for being warmed up I thought it was strange.
  25. #425
    Aug 07 2017
    Miami Beach
    How do you brake boosting (spooling the turbos) during a roll race ?
    2019 Lexus RX450h - Current
    2019 AUDI RS3 - Current
    2018 Audi Q7 - SOLD
    2017 Audi S6 - SOLD
    2012 Toyota Venza - Daily
    2009 Toyota Venza - Other Daily
    2016 Audi S5 - SOLD
    2015 Toyota Tundra - SOLD
    2014 Honda Crosstour - TOTALED
    2008 BMW 535 XI - GONE
  26. #426
    Nov 11 2013
    Monroe Washington
    Quote Originally Posted by TuanQT View Post
    You don't need to brake boost these cars they are twin turbo usually you would hold the e brake and give the car gas. Just keep the car in a higher range they will spool almost instantly.
  27. #427
    Senior Member Three Rings RSLRS71's Avatar
    Mar 03 2017
    18' SQ5 and WK2 SRT8 Jeep
    Castle Rock, CO
    so....had my car services at 5000 miles (Audi Denver), had an oil change done (supposedly) but a few days ago got the engine light on saying to add no more than 1.5 quarts....find this kind of odd as these cars potentially can go 10K without a change....if the change had been done at 5K miles and i now have 835X miles....doesnt it seem odd that i'd be low? have not seen any leaks indicating the turbo seal may be leaking....i am paranoid and thinking the dealership didnt do the oil change....planning to either top it off with the proper oil or calling the dealership and letting them top it off....either way. havent checked the level yet, but figured when i do, if the oil is dark then maybe they didnt change the oil? would prefer to top off after checking but was wondering which oil to use....5w40 or 5w30? any recommendations?
    2017 RSL RS7 (1 of 3 stateside)
    Mods:
    Current: APR Stage II w/ HF DPs and KW H.A.S kit , Rotiform 3 piece SPF 21x10.5 wheels, Tag Motorsports Side marker delete and Badge blackout, ...
    Next: looking to be the quickest RS7! ;)
  28. #428
    Veteran Member Four Rings lnferno's Avatar
    Oct 14 2006
    Rocky Mountains
    Quote Originally Posted by RSLRS71 View Post
    5w-40
    Current: 2021 Audi SQ7
    Past: 2014 Audi RS7 Stage 2 (quickest in Colorado) | 2014 Audi S6 Stage 1 | 2011 Audi A6 Suzuka Grey Avant (1 of 1) Stage 2 | 2006 Porsche Cayenne Turbo S | 2001 Audi S4 - Stage 3+ | 2006 VW Toureg V8 | 2006 A4 Avant - Stage 1 | 2006 Audi A4 - K04 | 2001 Audi S4 - Stage 2
  29. #429
    Mar 03 2017
    Castle Rock, CO
    Quote Originally Posted by lnferno View Post
    5w-40
    Castrol or RAVENOL VMO 5w40 Motor Oil
    Mods:
  30. #430
    Oct 14 2006
    Rocky Mountains
    I've always used Mobile 1
  31. #431
    Dec 19 2012
    Europe
    vw507 oil is what you need/want to use, and that spec is always 5w30, although I also personally prefer 5w40.
    But I won't use a non-507 oil so switched.
  32. #432
    Sep 02 2017
    When I turn on the AC I notice (even when the temp is set to 77 degrees) the AC comes on and starts blowing cooled air. It kicks out cool air for a while and then eventually get to temp (or around that set temp area) 5-10 mins later. Is this normal?
    I also see a lot of water condensation under the car when I actually have the temp low during the summer..
  33. #433
    Veteran Member Four Rings Street Nasty's Avatar
    Jan 20 2009
    B5 S4 Avant
    Quote Originally Posted by Reflexxx View Post
    It works as a dehumidifier for the car at initial turn on.
    Sent from my LG-LS993 using Audizine mobile app
  34. #434
    Aug 07 2017
    Miami Beach
    What tires pressure should I be at when I am at the strip ?
    2018 Audi Q7 - SOLD
    2017 Audi S6 - SOLD
    2016 Audi S5 - SOLD
  35. #435
    Dec 19 2012
    Europe
    How common is an A7 with no air ride suspension? Mine is a European model and it doesn't have air suspension (does have other audi connect options).
    Do all A7s in the US have air suspension?
  36. #436
    Apr 23 2011
    Sac Area, CA
    There are exactly 0 A7's in the USA with OEM air ride. They're all on springs here.
    IG @lolzhax
    //AGILITYDRIVES.US
  37. #437
    Dec 19 2012
    Europe
    Huh? But don't they all have the MMI setting to raise and lower the car via Audi connect? Doesn't that require air suspension?
  38. #438
    Apr 23 2011
    Sac Area, CA
    No they have a static ride height and only adjustable dampers. They get a choice of stiff or soft ride, not height adjustable.
    IG @lolzhax
    //AGILITYDRIVES.US
  39. #439
    Dec 19 2012
    Europe
    Very interesting...In Europe, some A7s have air suspension adjustments via MMI, like;
    https://www.youtube.com/watch?v=egZqgdBpza8
    Was it at least an upgrade option? Or only S6/7 and above?
  40. #440
    Apr 23 2011
    Sac Area, CA
    It's standard on S6/7/RS7. No upgrade options for A6/A7 to my knowledge. Aftermarket only.
    IG @lolzhax
    //AGILITYDRIVES.US
