Results 1 to 20 of 20
    Oct 25 2016
    e46
    St. Louis
    Taking car do stealership...do you change intake/filter back to stock?
    Quick question taking the car in for service and have a carbino intake/filter. Do you guys switch back to stock? Car is still under warranty. If you dont, what do you do with the filter? Ask for a refund on it. Keep it and sell it?
    Sent from hell
    Apr 05 2016
    Portland, OR
    I used to when I was mostly stock just because it took 10 minutes.
    Now days I don't bother. Between my exhaust and cosmetic mods it is very clear my car is modded.
    Just be sure to pull the tune off if you have it. If not you should be fine.
    Filters for the intake are considered life-time items by Audi. They shouldn't do anything with it other than clean it.
    Geoff
    Mar 21 2015
    I would install the factory air box before service. It doesn't take long, I do it every time. Some dealers are mod friendly so you might get lucky with that.
    Established Member Two Rings volyer's Avatar
    Sep 09 2016
    B9 S4, MB GLK350
    Tennessee
    I've wondered this too. Has anyone actually ran into trouble down the road with a warranty claim because of an intake? I have the CTS turbo one, but no other powertrain mods (just cosmetic for now).
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    I never removed mine. Nor did I ever flash my ECU back to stock. Nothing to hide... Plus my dealership installed most of my mods anyways. LOL
    Never received TD1 either.
    Senior Member Three Rings MS203's Avatar
    Apr 09 2011
    '15 S4
    Newport Beach, California
    It depends on your dealership. My SA told me that if possible I should put my stock intake back on before service.
    Why not just change it before? it takes so little time - plus it reduces the risk you would be denied warranty. 20 minutes for better peace of mind is worth it IMO. My car is obviously modded at first sight too. An aggressive drop and AGs give it away. Talk to your SA though. It depends. For example, as i mentioned mine told me that if i can to throw the stock intake back on each time that i definitely should, but told me that catback only exhausts (such as my AWE Track) are fine and the techs are cool with them.
    *edit*
    Its not that a tech will see the intake and go "OHH SH*T. TD1!!!!!!! Im going to flag this mother ******" and flag you based off of solely noticing the intake. At least 99.9% of the time that won't happen. The reason for swapping the intake is that so if they find do find something ELSE that is busted (i.e. water pump, etc.) that they will cover it no questions asked. and won't even have the chance to blame the intake.
    –Matt
    2015 S4: Brilliant Black, hardwired V1, Roc Euro intake, H&R Street Coilovers, CR-15, SPC Adjustable Upper Control Arms, 034 Rear Sway Bar w/ Moog Endlinks, 034 Rear Subframe Mount Inserts, AG M510's 19x9.5 on Michelin PS4S (255/35/19), AWE Track w/ 102mm diamond black tips, Chipwerke Pro-S.
    Veteran Member Three Rings PSUGOLD's Avatar
    Mar 10 2014
    Philly Area, PA
    I flash back but never put the stock intake back on. Never had an issue.
    2016 Daytona Grey Pearl Effect crystal effect , Sports Diff, Adaptive Suspension, Carbon Atlas inlays, Borla Cat Back, DS1 Stage 1 w/ Boosted Euro TCU.
    Oct 25 2016
    e46
    St. Louis
    It is easy to do for sure but I was wondering if anyone had personal experience. My plan was to switch it back and flash to stock for peace of mind and to minimize the chance they would say "a caused c so we won't cover it". Thanks for the responses.
    Sent from hell
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    Never switched mine back, dealer doesn't care.
    2012 S4 (sold)
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    Just talk to your rep and see what he/she says, I've got like everything but Meth injection and I'm still not TD1 *yet*.
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    Junior Member Two Rings
    Feb 01 2013
    NoVa
    Going in for a service recall and an MMI issue next week - I replaced my OEM airbox for piece of mind. It was my first time back to stock so it took some time remembering all the nuances of the install such as: 1) Reusing the rubber grommet feet 2) The metal adapter you inserted on the smaller breather filter on the side 3) The two-way hose coupler between the airbox and hose was also reused. Remember those and you'll cut your time down by 15 additional minutes.
    2019 Q8 P+
    2016 A7 TDI Prestige
    2013 S6 Prestige
    2013 S4 P+
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    I leave my drop-in filter in, but I would swap back to a stock air box to be safe. You don't need a tech having a bad day to manually input TD1...
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Senior Member Three Rings Dasaudi mtl's Avatar
    Dec 04 2012
    Montreal & Florida
    you can leave everything in there my only concern would be being flag TDI
    2018 SQ5 Black
    Jul 14 2013
    British Columbia, Canada
    I have never had to remove my intake. Thermostat recently went out and they replaced it under warranty without any fuss. I guess it depends on the dealership.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Feb 06 2015
    Nope. Mines been for service twice also two different dealers no issues.
    19’ Audi RS5 SB H&R VTF Has Kit|034 Motorsport|ECS Tuning
    Veteran Member Four Rings MKGIY's Avatar
    2012 S4, 2012 GMC Acadia
    New Jersey
    I have the CTS Turbo intake and have yet to remove it. My car has been in for multiple services as well as warranty work and I have not had an issue. Now that I am out of warranty I just ride or die!
    Jun 16 2016
    Victoria, BC, Canada
    I leave my CTS Turbo intake in and no issues with warranty.
    Established Member Two Rings ZChicagoS4's Avatar
    Nov 02 2013
    Chicago
    I have never removed it for service and never will.
    2015 Audi S7 Prestige. Bang & Olufsen, Black Optics, Night Vision, Driver Assistance, Adaptive, Alcantara Headliner, Pre Sense, Lane Assist, Cold Weather, etc.
    2017 Jeep SRT. Borla ATAK.
    2017 Wrangler Unlimited Hard Rock
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    OP, obviously YMMV.. but it takes less than 10 mins to swap from CTS to stock. I hedge and always do it, and by always I mean 2 times on my 16'. Initial 5k service and mount/balance winter tires.
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Established Member Two Rings Deviruchi's Avatar
    Jan 13 2013
    RI
    Like others have said, depends on the dealership. For mine, the head mechanic asked me if I had modified the engine software. I said no, and he told me good, never do that I'd be fine.
