Results 1 to 9 of 9
    Jan 09 2008
    '03 BMW M5, '02 Z06; '12 Street Triple R; '03 V-Star 1100
    Crystal Lake, IL
    Annoying noise while driving
    I have a 2006 A4 2.0 Quattro Automatic with ~127,500 miles on it.
    For the last year or so I've noticed a sound, or more like a buzzing (can feel it in pedals) while driving. It happens at all speeds (gets a little better up at around 80) and in all weather conditions and road surfaces. It completely goes away when turning the wheel left through a curve or turn, but as soon as I start to straighten out it comes back.
    I replaced the front wheel bearings, brakes and rear brakes, but none of that has helped.
    Any ideas what could be causing this? My latest theory was something with the CVs / axles but I'd rather have an idea before I start throwing money at it.
    May 20 2010
    Check the dust shields up front. I have some buzzing and noise but, like you, when I turned a certain way, it went away. Turned out to be dust shield slightly bent and rubbing on either the disc or wheel.
    Jun 27 2011
    I was going to say wheel bearings but looks like you replaced them.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jan 09 2008
    Crystal Lake, IL
    I'll check them but I believe them to be clear as they were removed during the new bearing install. Thanks!
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    More than likely it's the front axles. I just replaced mine last weekend. I was getting grinding noise when backing up and turning, and a constant low pitch drone while driving. Now all I hear is the occasional hum from the snow tires and the exhaust. That sweet, sweet rumble of the V8 exhaust. It also took away the slop in the drive-train.
    It's been my experience that CV axles last 100k miles. Then, like shocks, they slowly wear out to where you are now. My dad's Maxima had that "Dinah Moe Hum" with 135k. I replaced the axles and it was gone.
    If you plan on keeping the car for a couple of years, go with Raxles. They cost alittle more but worth it. Forgot to mention, the S is at 110k,
    Senior Member Three Rings 67Twisty's Avatar
    Jul 11 2015
    North Carolina
    Wont failing CV joints at the axles will make more of a clicking sound and not a drone/vibration? I used Marty's rebuilds on mine too and have been pleased so far. But the OEMs should go well over 100k unless you are lowered. Or if a boot rips and you don't replace immediately.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Mar 10 2010
    WI
    Quote Originally Posted by 67Twisty View Post
    Yes. A failing CV will make a clicking noise. However, one that is just worn after 100k+ of use, you are going to get a constant hum/drone.
    OP-Have you changed the front diff fluid?
    Jan 09 2008
    Crystal Lake, IL
    Quote Originally Posted by JayDog747 View Post
    I haven't changed the fluid yet, that was another thing I was looking at. The fluid, and I'm guessing there are bearings in there?
    Mar 10 2010
    WI
    Quote Originally Posted by joseb View Post
    Yes, there are bearings in there. It has to be pumped out, there is no drain plug for the diff. Don't believe them if they tell you it's lifetime fluid. It's bullshit.
