View Poll Results: Which Intake Should I Buy?
Voters
22. You may not vote on this poll
  • 034
    8 36.36%
  • APR
    3 13.64%
  • HG Motorsport
    0 0%
  • AWE
    2 9.09%
  • CTS
    4 18.18%
  • Neuspeed
    2 9.09%
  • AFE
    2 9.09%
  • ARMA
    0 0%
  • Forge
    0 0%
  • Evolution
    1 4.55%
  • Mishimoto
    0 0%
Results 1 to 12 of 12
    Jan 12 2016
    Los Angeles, California
    INTAKES: So many options, which is best/ most popular?
    I have been looking at getting an intake for a while, and its about time. There are so many different options, all with unique designs. I like a few of them in particular, but I would like to know what the consensous is among AZ users.
    So, which intake do you think is best/ which do you have/ which would you buy if you were to buy one?
    2016 Monsoon Grey S3 P+ w/ BO, Resonator Delete, AWE Resonated Catted DP, Unibrace UBQ, 034 Rear Sway Bar, 034 Dogbone Insert, 034 Rear Subframe Inserts, 034 P34 Intake, CTS Turbo Inlet, ED Springs, Eurodyne ECU and TCU
    May 20 2010
    Stock. Done.
    Veteran Member Three Rings 1S32K16's Avatar
    Jul 07 2016
    I am curious also. I am running just a AFE dry filter for now. I like that the 034 uses the factory air box base.
    2019 Quantum Gray SQ5 with black optic package, 20% Rayno Ceramic tint, TAG Motorsports Painted Front Reflectors, BMC Air Filter, JB4, 034 Trans Mount, OEM Black Badges, 21’ BC Forged RZ39, Redstar 200cel DP, ODIS factory lowering
    2016 Monsoon Gray S3 with black optic package, Emmanuele design springs, rear sway bar and endlinks, 19' Forgestar CF5's
    Established Member Two Rings MathildaS3's Avatar
    Apr 14 2015
    Palm Beach Gardens, FL
    The 'stock mod' wasn't listed, but it does rock! $50 for a drop-in filter and 30 minutes' work does make a huge difference.
    2016 Sepang Blue S3. MagRide, SuperSport seats, B&O, RS3 grille, wheel spacers 10mm/17.5mm, K&N drop-in filter, stock intake mod, LED interiors, Spulen engine mount insert (modified), BMS JB4 tune. Sleeper AF...
    Jan 12 2016
    Quote Originally Posted by MathildaS3 View Post
    I have already opened up the airbox inlet, and removed the snow grate. I am looking for a complete intake system after about 10 months of using the modified stock intake
    Jan 15 2010
    Santa Barbara, CA
    I have the AWE and love it. I was convinced it would yield the most power since it's closed, but the 034 likely accomplishes the same thing (and might flow better due to the CF outlet vs. stock accordion).
    It increases turbo noise a tad - maybe 50%.
    Aug 19 2016
    Southern, NH
    I like the CF intakes, particularly the 034 motorsports one. It also helps that 034 are coming out with a CF valve cover to match.
    Nov 17 2014
    San Francisco, CA
    So I just was thinking the same and cannot justify $500 for an intake with nominal gains. Long story short, there is the CTS Turbo inlet pipe that's about $100ish along with k&n filter, you should gain the same for about $150. A user dynod the CTS, aftermarket intake and OEM intake separately and the CTS gained 6-8whp, the intake nada.
    While the intake make the engine bay pretty, I'd spend that money on other things (jb1, ecu tune, downpipe, exhaust, etc.)
    Sent from my SM-N910V using Tapatalk
    Senior Member Two Rings JohnnyUtah787's Avatar
    Oct 03 2015
    Illinois
    I've got an AWE one on the way. Urotuning was running a solid deal on them (10% off plus $50 gift card) so I went for it. From what I can tell, the gains on the AWE and 034 are pretty much the same. Probably can't go wrong with either. I like the cf engine cover 034 is making to match, hopefully the cf pattern is similar to the AWE intake, would really like the cover as well.
    2015 Audi S3 - Glacier White, 19" Performance Package, B&O Sound System, LED Lighting Package, Black Optics grille, Black optics fog grilles, Black powder coated OEM exhuast tips, Satin black 19x8 ET45 Neuspeed RSe10 wheels with Continental ContiSportContact 5P tires (summer set-up), OEM 19x8 ET49 double 5-spoke wheels with Pirelli Winter Sottozero 3 tires (winter set-up), 15 mm ECS spacers all around, Emanuelle Design springs, 034 Motorsport dogbone mount insert
    Apr 11 2012
    I wanted a closed system so it wouldn't be obnoxiously loud.
    I wanted carbon fiber, because pretty.
    I wanted a good looking design.
    When I decided there was AWE and APR to choose from, APR was lower cost, and looked a little cooler, so I got that.
    No issues with it, works as advertised, and sounds good with the windows down (can't hear much with them closed). The only thing I would like different is CARB exemption.
    Veteran Member Four Rings Saracen's Avatar
    Apr 25 2009
    PNW
    CARB Exemption is why I go straight to Neuspeed. Doesn't hurt that their parts have excellent build quality and reasonable pricing.
    "A car can be a tool but it can also be so much more. It can be a heart-starter, it can be a drug, it can be a piece of art and it can stir your soul" -Clarkson
    "It's like being an ass man but there aren't any nice asses around so you go find a fat chick b/c at least she has something to hold on to. It's not the same and you just don't do it. #avantsforlife" -02silverbullet
    Established Member Two Rings ahfunaki's Avatar
    May 23 2016
    Northeast Ohio
    No issues with my AFE. And I love the sound. That's the only reason I purchased it...
    2016 S3 Premium Plus | Glacier White Metallic Exterior | Black / Titanium Gray Interior | Black Optic | Technology | LED | B&O
    Emmanuele Design Springs | 15mm Spacers Front & Rear | aFe Magnum FORCE Stage-2 Pro 5R Intake | OEM Resonator Delete | AWE SwitchPath Exhaust Remote
