I am looking for some help and hopefully some advice.
I have new spark plugs and coil packs to install on B8- I was attempting this on the weekend and I started by trying to move the coolant overflow bottle. While it was easy to move the bottle from the two bolts; I noticed that when I tried to move the bottle, the coolant started to leak from a hose on the bottom of the bottle.
No matter what I did I was not able to stop the slow dripping leak; based on that I stopped the work as I was concerned that I had damaged the lower hose of damaged the clamp that secures the hose to the bottom of the bottle.
I did find some videos that show the step by step; however, none of them deal with the coolant leaking issues. I am wondering if the clamp is loose- I had have to have a new water pump and T stat installed about 5 weeks ago and I wondering if that hose clamp is either loose or defective
Anyone have any ideas or recommendations?
Thanks
