Results 1 to 13 of 13
    Jan 19 2014
    United Kingdom plymouth
    What part is this
    Hi what part is this, ive just had a engine rebuild on my A4 B7 Advant SLine 2.0TDI
    noticed this cable tied on.
    what is it and where has it come from??
    [IMG]IMG_2253 by Andrew Kavanagh, on Flickr[/IMG]
    IMG_2252 by Andrew Kavanagh, on Flickr
    Dec 23 2011
    Sensor for motor mount w/ fluid?
    Mar 24 2013
    Oakdale, CT
    Yeah, looks like they broke the sensor off and just ziptied it back to the mount instead of admitting they broke it.
    -Adam
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    It also looks like an aftermarket mount...that doesn't look stock...or maybe it's missing the "cover"...
    Jan 19 2014
    Is it a big issue, can it be fixed or should i just secure it??
    Jan 19 2014
    Sep 04 2015
    Clear Lake, TX
    If it isn't throwing an error code then don't worry about it. I replaced my mounts recently and left the sensor unplugged; I have yet to get an error code.
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by drmonkey View Post
    Leaving them unplugged will not trigger a fault code, you will just see the code if you're using vag com.
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Sep 04 2015
    Clear Lake, TX
    Quote Originally Posted by Hugh@EuropaParts View Post
    Ah, good to know.
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    And they don't really seem to work anyway. My mounts were completely shot and I didn't have any code for it. Maybe someone could enlighten me
    I put in RS4 mounts that don't have sensors, so now I'm getting a soft code for them
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Feb 15 2016
    Cambridge,Ontario
    yeah someone posted a pic a couple days ago of one broken off and hanging down
    Why on earth would you want a sensor on a motor mount ? what does it do ?
    I would say with all due respect its not likely to be a sensor at all. more likely to be some type of actuator to control damping.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Oct 24 2015
    Perth, WA
    No its is a sensor. It probably detects lateral movement. You can put resistors there to prevent the soft code. I installed 034 mounts, lovely ride.
    My respray thread
    Jan 19 2014
    Cheers for the info guys, I'll secure it and forget about it. They have also done something to my front Fogs. Probably disconnected them but i haven't had time to check yet. Both are out with a warning light.
