Thread: Cross Bars
    Veteran Member Three Rings IinsureU's Avatar
    Nov 02 2012
    Thousand Oaks, CA
    Cross Bars
    Going Skiing in about 4 weeks and curious to know what the masses use to secure snow skis, poles and so on to the cross bar racks on their Audi's. Thanks in advance for your time and information...
    2019 Q7 3.0 Premium Plus- Glacier White Metallic
    2015 Q5 TDi- Monsoon Gray, MMI, B&O, 20" wheel and Sports Interior Package, Eurocode sways/links and Alu Kreuz
    2014 Audi RS5- Shiraz Red, Black Nappa/Alcantara, MMI, Titanium Pkg, Sports Exhaust, Rear Shade, CF Trim- SOLD
    Jul 16 2013
    Quote Originally Posted by IinsureU View Post
    I use an Inno ski rack from Amazon. Cost about 100$ and attached to the bars nicely. You may need the longer screw set for your skiis and boards depending on their thickness.
    Aug 19 2016
    Colorado
    I use Yakima Fat Cat 6. They work great.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Veteran Member Four Rings jomama229's Avatar
    Jun 07 2013
    orange county, ca
    with the limited cargo space we have, i went with the thule force xl cargo box. that way, i'm not limited to just putting skis/snowboards on the roof. i can throw all my ski clothes, boots, helmets, etc., up there as well.
    2014 Q5 3.0T Glacier White Metallic - 034 Stage 2 / TCU - Bilstein B8/H&R
    Veteran Member Three Rings mkasperzak's Avatar
    Jan 16 2014
    Transition Patrol Carbon, Transition PBJ, Commencal Furious
    Im running Thule aeroblade crossbars, they are the only adjustable crossbars. The other options slot straight into the factory holes on the rails and sit pretty far back on the car. I have a Thule flow 606 ski box on order for the winter setup, wanted a little more space for gear and to keep boards/skis out of the snowy road muck.
    2014 SQ5, BBS CH-R, GIAC DP 183 Fluidampr/57 AWE SC(3.18 PR), AWE Touring, Roc-Euro, Bilstein PSS10, 034 HX/X-Brace/RSB/Inserts, Thule Edge/Flow, Kuat Trio
    Build Thread / IG @thebird_sq5
