Thread: Coolant flush
    Mar 13 2016
    Denver
    Coolant flush
    About to do a coolant flush. Is 1 galllon of VW/Audi g12 and 1 galllon of distilled water enough ? And will just pulling the lower radiator hose be fine for flushing the system ? Thanks in advance
    Oct 28 2016
    Lacey, WA
    I used half a gallon of g12 and half a gallon of distilled water. I never got the reservior to drain down and the heater never made hot air. I think thermostat or heater core.
    Aug 06 2008
    Canadia
    That should be fine, remove lower rad hose and drain engine block from the rear, there is a drain bolt between the engine and trans on the drivers side of the engine.
    the B5 S4 is like the mafia... there is only one way out!
    Mar 13 2016
    Denver
    Quote Originally Posted by MacDaddy View Post
    Okay thanks but do I do have to drain it from the engine block ??
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    You don't have to, but wouldn't it be beneficial to drain all the coolant consider your "flushing" the system.
