So little back story, bought this car last tuesday, noticed a coolant burning smell 3 days later when I was under the hood, and noticed a little bit of coolant puddling under the water pump. Took the car back saturday and the dealer called me monday morning and claimed that it was residual from when they changed the radiator hoses, and the tech cleaned the engine bay thoroughly and pressure tested the system to get rid of any residual coolant burning off the engine. Long story short, went to pick up the car last night, and when they pulled the car around I had a charging system malfunction indicator, and the car died 2 minutes later while still sitting in front of the dealer. They called me this afternoon to tell me they would be replacing the alternator free of charge and that they checked out the rest of the car and everything was fine. But heres my real question, is there a possibility that I am being lied to here, and they are just trying to get rid of me, and in their rush damaged the alternator by hosing the engine bay down with the car running? Obviously I am going to check the spot i saw the coolant puddling (see pic below) and check the coolant level before I leave, as I topped it off at the max line prior to bringing it in, but now I am worried that I may have damage to the car. Anything I should look out for now before I leave the dealer? Is it even possible to pressure test these systems since they run a pressurized overflow bottle instead of a capped radiator?
