Results 1 to 21 of 21
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    For those who have went OEM --> Stage 1 --> Stage 2
    Question for those of you who have went OEM to Stage 1 to Stage 2..
    I ordered EPL Stage 2.. I now have access to Stage 1 software as my cable/pulley are en route.. It will likely be a few weeks (maybe more) until I have time to install the pulley and load the S2 software.. Question is an opinion for those who bridged and went Stage 1 in the interim --- do you think I should wait and go Stage 2 direct? Or should I flash Stage 1 now and ride on it for the next weeks/month? I've heard feedback from a lot of people (and dyno proven) that the jump to Stage 2 from S1 isn't nearly as drastic and I'm wondering if I'll feel disappointed/bummed by not getting "more" out of the Stage 2 jump.. The old dive right in vs. ease right in discussion.
    Anyone have any thoughts? Did you do one and wish you did the other? Stoked either way to be tuned - just want to do it right for maximum satisfaction.
    '18 S5 - BBS / EPL
    Jul 10 2011
    royal oak mi
    I think it is worth it although i went Stage 1 93 to Stage 2 dual pulley 93 and it was huge increase.
    2017 Sepang Blue RS7 - Stock for Now
    Sold 0 2013 Ibis White S4 Prestige with 6MT and Sports Diff - Roc-Euro Intake
    May 07 2016
    Quote Originally Posted by Bclippard View Post
    I wish.. :-)
    '18 S5 - BBS / EPL
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    Since you already went Stg 2, just go to Stg1 for now and enjoy. Who cares about the jump - you have both anyway.
    Euro Tails Crew
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    I thought the jump from OEM to Stage 1 was better than Stage 1 to 2, but who cares? More is better at all times.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Apr 05 2016
    Portland, OR
    Go Stage 1 first. No point in waiting.
    Stage 1 feels like a bigger jump as it adds a lot more up top.
    Stage 2 feels like a smaller jump but can be felt all across the power band.
    Going Stage 1 first will make you thirsty to get even more performance out of it
    Geoff
    Veteran Member Three Rings jachien's Avatar
    Nov 12 2012
    Cerritos CA
    Having driven both (mine being a stage 1 and stage 2 was a friend's) I can say that even though the stage 2 gains aren't as drastic, there is still a noticeable difference in low end response due to the pulley ratio producing boost sooner. If you're concerned about the way it feels, I would say if you bought the DSG tune as well.. just do stage 1 now, and then stage 2 with dsg tune later so you wont be disappointed either time.
    Jun 17 2010
    Madison WI
    I definitely recommend enjoying stage 1 until you have the time to install the pulley. I did so, with EPL, and stage 1 was very noticeable, as was the upgrade to stage 2.
    2015 6MT S4, EPL Stage 2 no more...
    2010 6MT S4, APR Stage 2 no more...
    Senior Member Two Rings unasupra97's Avatar
    Sep 28 2016
    nj
    In the same boat as you just went stage 2 but have to wait for the pulley to come in..think i will enjoy stage 1 for now
    Sent from my SM-G935T using Tapatalk
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    all i will say is stock to stage 2 was a very dramatic difference, the first time you really lay into it its going to surprise you.... in a good way
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    I felt the opposite.
    Stock to Stage 1 wasn't as drastic. The only real difference was way high in the RPM where boost would not bleed off.
    Stage 1 to Stage 2 I felt was a bigger jump because of the increase in low end tq which is much more useful in daily driving.
    Mind you - neither felt as drastic as tuning a turbo. Our SC engine is so smooth and power delivery is so linear that it's not the same as a turbo power delivery when tuned.
    Regardless - for sure go stage 1 then stage 2. Enjoy both and appreciate each for what they are... the evolution of your car...
    I have slowly modded my car for 5 years now and it's kept it fresh and fun the entire time. Had I done everything at once I'd have missed out on the journey.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Quote Originally Posted by MrFunk View Post
    I had a similar experience, stage 1 was a nice power bump but majority above 5k. Therefore you don't feel all of what is has most of the time. For me stage 2 is how I like to drive the car, ripping from a low rpm especially since these cars have such amazing traction. You will appreciate both, very different...
    Established Member Two Rings sixoclub's Avatar
    Jan 02 2013
    2011 Jeep Cherokee
    Northern California
    Up to what your pleasure is really. Ask your self if you want your car at it's funest or do you enjoy the process of modding?
    I went stage 1 then stage 2 but would have been perfectly happy doing it all at once. I get very little pleasure from modding and deep down wish it came that way stock.
    May 07 2016
    Thanks Fellas. Great feedback!
    '18 S5 - BBS / EPL
    Jun 28 2016
    US
    Flash Stage 1 dude... that's almost like a no brainer honestly. If you're gonna wait and install pulley when funds or time allows, might as well enjoy Stage 1 while you have it... why not? You'll notice a nice boost in power with Stage one, no doubt. With Stage 2, you'll get a bit more torque and response down low with a little bit more gain up top, but it's not like Stage 1 is a slouch or whatever and not worth it. Honestly, I would have stayed at Stage 1 had my damn crank pulley not taken a shit on itself at 70k. When that happened, I wasn't going to install another OEM unit, so I got a JHM and installed that myself and then called up Chris and asked him to process my payment for Stage 2. I rode on JHM pulley and Stage 1 EPL for about a day or so I think while my account got updated to Stage 2 file.
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    I went from Stage 1 to Stage 2 and there was no disappointment.. and once you go stage 2 then go to the Dual Pulley file...
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Since you are at altitude, stage I may not be significant jump. Still worthwhile to flash it though.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Nov 25 2014
    Alabama
    Is stage one all up top or is there anything added down low? Even butt dyno feels?
    Sent from my SM-G935T using Audizine mobile app
    2018 SQ5 | Monsoon Gray | Prestige
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by turbophreak View Post
    It's across the whole rev band but most noticeable up top.
    Geoff
    Established Member Two Rings ZGskibum's Avatar
    Jan 17 2016
    Aspen, CO
    Quote Originally Posted by Hofahome View Post
    Stage 1 is still a beast at altitude. And then when you jump to stg II, it's a whole new car all over again. For max fun, definitely flash asap, then go stg II as time allows.
    2011 S4 6MT Sport Diff | Ibis w/ Black Optics
    APR Stg II+ | AMS Cooling | AWE Touring - Res DPs | Roc Euro Intake | Sachs X-Tend Clutch w/ USP SS Line & Lutz (OEM) FW | Stoptech ST-60 355 BBK w/ SS Lines | H&R OE Springs | Bilstein B8 Shocks/Struts | CR-15 | H&R Rear Sway | Alu Kreuz | 034 Trans/Engine/Diff./Strut Mounts | BC Forged EH 307 19x9 ET 40 (Summer - Michelin PS4) | VMR V810 19x9.5 ET 40 (Winter - Pirelli Sottozero) | ECS Shortshifter | P3
    Senior Member Two Rings S4ilicious's Avatar
    Feb 09 2015
    2001 A4 2.8 Quattro
    Bay Area, California
    I say go flash stage 1, it defenitely is a great increase from stock but as others have mentioned you will mostly feel it up Top since that is its main function (:
    Personally i went stage 1 and then did Stage 2 with DSG tune and man the car rips now haha Like others have already mentioned
