Results 1 to 25 of 25
    Nov 11 2004
    Early 911s, 914-6 GT, A-H 100, BRE 510
    Chicago Area
    Factory Sport Suspension Replacement Suggestions
    Hey B7 A4 experts, need your recommendations for replacing/upgrading my shocks on my A4. It is an '08 that has 131k on the clock and is starting to get a little funky feeling over bumps. I am thinking it is time to replace the shocks and struts. What does the brain trust here recommend? Car is already lowered with the factory sport suspension, so I don't think I need to go any lower. I put the H&R sport springs and shock set up on my 96 A4 and loved the look and ride, but that may not be necessary for this car. Shock and strut replacement should do the trick, no? Recommendations...?
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    I have Koni Sports set to the softest setting and my car rides awesome. I have them paired with Eibach ProKit springs.
    Veteran Member Three Rings king_j's Avatar
    Sep 09 2009
    Minneapolis
    miaA4, is wheel gap the same front and back?
    2006 A4 2.0T Q. S-Line 6MT - Arctic White
    JHM stage 1, 034 hfc, Europaparts exhaust.
    Miro 111 18x8.5 et 35, 034 RSB.
    Jul 17 2015
    miami
    I have minimal wheel gap for both front and rear. I can fit a finger in between the tire and fender.
    Feb 15 2016
    Cambridge,Ontario
    im interested in this thread also as I have factory sports suspension ( red struts ) . My car is at 255K so I think il be doing this project in the spring. is there a direct replacement and who is the big supplier ?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Oct 24 2015
    Perth, WA
    Bilstein B12 Pro Kit.
    My respray thread
    Sep 09 2009
    Minneapolis
    Ajusa.com has the b12 kit for $587.
    Never used the site before, just saw it while searching.
    Oct 24 2015
    Perth, WA
    My respray thread
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    When I had my sedan I bought the complete control arm kit from FCP Euro and was very pleased with the bits included. I plan to buy from them again for the Avant and I want the same thing eventually for springs & shocks: fresh bits without lowering it. OEM Sport suspension level is just about right for me and finding quality parts to do that for a reasonble price is tough. Seems like 99% of the information here is for lowering your car.
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Nov 15 2011
    Montreal | I sell in USD
    Check germanparts.ca
    They have the front Bilstein sport shock replacement @134$ and rears @145$.
    *****I sell in USD*****
    Senior Member Three Rings 67Twisty's Avatar
    Jul 11 2015
    North Carolina
    I replaced mine with the Koni yellows and Eibachs. It is lower than OEM sport with almost no fender gap on 18" BBS wheels. Eliminated the reverse rake but I now need to be more careful on speed bumps and steep curbs. Feels fine for a DD although I took the fronts out again and set to 80% firm. The eibachs are softer than the original sports so I wanted a firmer rebound.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Oct 24 2015
    Perth, WA
    Yeah, the pro kit drops it about another 1.5cm over stock sport. I think it does actually look better and the improvement is massive when changing over control arms, shocks and springs. I did a brake upgrade (pads and rotors), braided lines, brake flush and caliper paint job while I was there.
    My respray thread
    Apr 24 2015
    San Diego, CA
    Bilstein also makes the "OEM Sport" replacements, they are called B4 as well, but make sure it says for Sport, they are different part number than standard. Rockauto has them for around $55 each.
    Fronts should be 19-164472
    Rears are 19-164489
    The only problem I see with this is that if you are using B5 spring perches, you won't be able to reuse on this setup, as the OD of the B4 strut is larger than stock Red struts.
    I am running the rear ones on my car that originally had OEM sport suspension, and the rear rides well.
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by blauslc92 View Post
    Rears are 19-164489
    B8s are for B7 cars.
    My respray thread
    Apr 24 2015
    San Diego, CA
    Quote Originally Posted by Okedokey View Post
    Correct, B8s are the yellow Sport struts and shocks, those are the high performance version. The B4 oem sport I mentioned above are supposed to be used as a replacement to the Oem sport red shocks. At least that what Bilstein shows in their catalog.
    Nov 15 2011
    Pretty sure thats correct
    Oct 24 2015
    Perth, WA
    Fair enough.
    My respray thread
    Veteran Member Four Rings pat_do's Avatar
    Feb 19 2012
    Montreal
    Valving on the sport red shicks are stiff.
    Can i run regular shocks with oem sport springs to help smooth out the jarring ride?
    Oct 24 2015
    Perth, WA
    I wouldn't the dampening rate is different. The B8s are very nice mate. I just installed them.
    My respray thread
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    ^^/end thread
    Stage 1 more than you RS3
    Jun 27 2011
    Quote Originally Posted by pat_do View Post
    It'll be a bit bouncey if you do that. Also the non-sport shocks aren't valved properly to last as long on the lower Sport springs.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 19 2012
    Montreal
    Uhmm dont want that
    Nov 11 2004
    Chicago Area
    Thanks for the replies guys. So a couple of comments... I do not want to lower my car any more. I had a B5 A4 and installed the H&R sport spring and shock system. Liked it at the time, but don't want to lower this car any more than it is. So, I think just a shock and strut replacement should fit the bill nicely - unless you can give me a good reason to replace the springs too. Don't think that is necessary as the factory springs should still be good.
    The other thing that I am concerned about is removing the pinch bolt to get at the struts. I did a wheel bearing replacement last summer and I could not get that F'er out. Tried PB Blaster and an impact wrench and that bolt would not budge. I DO NOT relish the thought of going at that again. Any suggestions on how to handle that? I am all ears. One of the posters suggested replacing all the suspension components - is that really necessary? I would welcome your thoughts and ideas on how to tackle this without going whole hog on unnecessary suspension part replacement. Thanks.
    Sep 09 2009
    Minneapolis
    I think Bilstein makes a strut that's a replacement for the oem sport struts.
    Look into the vogtland jr cup kit, it's basically a aftermarket kit that is similar to the oem sport in terms of drop.
    Jan 15 2012
    k20 Integra
    LA,CA
    Quote Originally Posted by t6dpilot View Post
    Did you read the replies before you? there have been 3 options given to you to solve your dilemma.
