Results 1 to 6 of 6
    Veteran Member Four Rings prizmatik's Avatar
    Dec 15 2009
    Hell hole
    Looking for correct Turbo Inlet Hose
    I'm putting my 2002 A4 1.8T Quattro manual's intake back together with appropriate parts due to a running lean issue. I purchased the car with an AFE setup, but wasn't installed properly, and I also noticed some wore out hoses. I got an OEM Turbo Inlet Hose from an '03 A4 1.8T auto fwd parts car, but seems to have an extra hole near the MAF that I can't seem to find that goes to my car. Is there a difference between the 2 years I don't know about?
    Dec 02 2015
    Massachusetts
    At one point during the b6 I thought it was in 04 but could have been in 03 they added another hose not sure what for I only know this from looking at silicone tips. Selling the afe btw?
    Dec 15 2009
    Hell hole
    Eventually would like to reinstall the AFE, but missing the rubber hose that mounts the intake to the turbo. Original owner clamped the plastic intake to the turbo, but would easily slip off
    Dec 15 2009
    Hell hole
    This is a picture from the parts car I got the turbo inlet hose from. I don't have the hose assembly circled in yellow
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The 2002 ran the lower block breather (PCV) through the SJP to the intake manifold. In 2003 that was changed and the SJP received a fresh supply line coming from the TIP and the PCV was connected directly to the intake manifold. Thus the extra port on the 2003 TIP.
    Simply plug the hole for your 2002 model.
    Dec 15 2009
    Hell hole
    Thanks. I did that, but ran like crap. Suppose I'll do a boost/vacuum leak test next.
