I have a 2004 audi a4 1.8t avant and here is my problem:
EDIT: Video showing puffs of smoke: https://www.youtube.com/watch?v=sCZL...ature=youtu.be
READ THIS BEFORE POSTING: My brother and I noticed my car was puffing white smoke and after a little research we realized a common issue is the Valve Cover Gasket + half moon and cam tensioner gasket. We replaced ALL OF THESE recently (Annoying job to replace lol)
The problem persists however.
the exact problem I have is this: After driving for a little while, once the engine is warmed up, when stopped / parked afterwards there will be puffs of white smoke popping out from under the hood on the right side of the hood (Passenger side), I can also smell it through the vents if theyre on and it smells a lot like burning plastic which I assume is what burnt oil smells like. Sometimes its worse and sometimes it barely happens after driving, but if I stop and idle long enough it will happen almost 100% of the time, some times are worse than others but I suppose that could be from how hot the engine is at the given time. This morning when I arrived at school it was slowly shooting out puffs of lazy white smoke that just kind of fades. I will update this thread with pictures and videos later today when i drive home from class.
I've opened the hood while idling and noticed the smoke coming from behind the area where the half moon was replaced, I'm not the mechanically inclined one (my brother does that mostly) but I will show where with pics and videos in about 6 hours.
I assume what is happening is that oil is dropping onto the exhaust manifold and burning off, creating these puffs of white smoke and this gross burnt plastic smell. The problem is, I cannot figure out what else could be causing it, most of the advice from other threads is about replacing vgc and associated parts. Looking to see if anyone else has had this problem, or any advice. I'll say it again so that it's clear: WE REPLACED VGC + half moon + cam tensioner gasket
Has anyone else run into this, or have any ideas / advice?
For information's sake: There's no check engine lights or warnings of any kind, got the oil changed about 1000 miles ago and it was happening before, and has happened after the oil change as well.
car has about 85,000 miles and I bought it used at about 80,800, but it only started happening around 83000
