Results 1 to 9 of 9
    Nov 28 2015
    Montreal, QC
    034 front upper strut mounts - review ?
    Tried searching.. all i got was tranny mount and engine mount lol.. Why no one talk about it ? too cheap to be worth mentionning or useless as no one ever got to install these mount ?
    S4 B8.5 no track, just enjoying spirited driving.
    Established Member Two Rings kcobourn's Avatar
    Jan 04 2013
    2008 Acura MDX
    United States
    Quote Originally Posted by waxxonMTL View Post
    I use them. Can't tell any difference though.
    B8 P+ Ti 6MT, APR Stage 2, Alpha Cooling, EuroCode TRUfit, AWE Touring, H&R OE / R Sway, Bilstein B8s, CR-15, JHM SS, Q5 Brembos, ECS two-piece rotors / SS lines, 034 Trans / ECS diff mounts, ECS 8mm(f)/10mm(r)
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by kcobourn View Post
    Same here. Not a bad idea to replace them if you're already in there, but don't expect anything noticeable if that the only change.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    I added them when I switched from Koni Yellow dampers to Bilstein B8 dampers. The car would crash over larger bumps badly in the front beforehand and after it soaks them up like stock. I don't know how much to attribute to the damper change but the car felt loose and cheap before and nice and tight after.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    034 reccomeneded to install these when installing my kw h.a.s since your removing the struts already. I believe the idea is when installing springs/coilovers you install these instead of putting the weak factory ones back in. With that being said I wouldn't have noticed if these were installed or not but I'm sure it's a good idea for the long run to have them. The factory ones are super weak in comparison, dude showed me both
    Nov 28 2015
    Montreal, QC
    I was told, I need to re-do an alignement since the coilover has to be removed to install these mount. I regret not doing it when I did my coilover install tho, but i genuinely didn't knew about these mount lol
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Nothing in your alignment should change from removing and re-installing the coilover.
    Mar 21 2015
    I had them installed recently with my B8 set up and like others have stated I wouldn't really know the difference if I hadn't put them in. I only had 14k on the stock ones also so i'm not sure how worn they were.
    Jan 30 2015
    SC
    I also used them when I did my suspension install as 14S4GWM suggested. I could easily bend the OEM mounts by hand, but could barely deform the 034 ones if that tells you anything.
    2014 S4 Prestige Monsoon Gray DSG / EPL ECU Tune/ EPL TCU Tune / 183mm Fluidampr / CTS 57mm / MercRacing HX / Autotech HPFP upgrade / AWE track 102mm / Modified stock airbox / aFe Pro Dry S / 034 transmission mount insert / 034 rear subframe inserts / CR-15 / H&R OE Sports w/ Bilstein B8 dampers / S5 Rotors / Michelin Pilot Sport 4S
