Results 1 to 9 of 9
    Mar 08 2011
    Pittsford, NY
    How to deactivate headlight washers (vagcom)
    Lately during the winter I find the headlight washers rather annoying. I would like to deactivate them right in vagcom (if possible) but I can't seem to find the right codes. I've seen a few posts on this but nothing that has worked.
    Has anyone had any luck with this?
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    Pull the fuse for the pump? I'm not sure it's a VAG-COM programmable item, and I know others have pulled the fuse and capped off the lines that run to them (mostly to avoid having to disconnect then when assuming the service position).
    Sent from the 7th Galaxy.
    Mar 05 2013
    CA
    Quote Originally Posted by egovreau View Post
    I did that, as per OG suggestion, for the reason listed. Dunno if I need to do anything beyond that, like pull fuse(s) or coding.
    I broke the sprayer holder/housing in the bumper, so I just epoxied the body-color caps on and deleted everything else as much as I could. I forget where the pump is. I just know I put a vacuum cap in some washer line to plug it.
    But later, I easily took the caps off by pushing from underneath, and chipped away the cured epoxy with a flathead.
    Which makes me wonder, to prevent water ingress or even loosening down the line, if I should use something else if doing that. Such as a windshield adhesive, with was recently mentioned as an idea to glue on doorblades.
    Established Member Two Rings Garf's Avatar
    Aug 23 2016
    Audi A4 B6 3.0 Quattro 6MT
    Toronto, Ontario
    Pulling out #37 fuse will disable both headlight and windshield wiper pumps. Don't ask me how I know.
    My permanent fix was unplug the headlight washer pump only. Also at the same time you need to change out the 30A fuse to a lower one to handle only the windshield wiper pump. I am using a 15A now. 30A would be dangerously too high for a single pump. I am pretty sure even a 10A will work but during winters, the pump may work harder and could blow the 10A too early.
    Mar 08 2011
    Pittsford, NY
    I was originally thinking pull a fuse until I also saw it disables both, that's what led me to possibly deactivating in vag-com since they come on through a "timer" holding down the switch. I'm thinking isolating the headlight pump might be the best.
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Deactivate??? I wish mine would just work! Only thing on my B6 that doesn't work...
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Jan 24 2010
    Paramus,NJ USA
    I think you can just disconnect the headlight washer pump at the bottom of the tank.
    Ziddy Autowerks
    Nov 15 2011
    Montreal | I sell in USD
    ^^Imo thats the best way if you dont have a leaky system.
    *****I sell in USD*****
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Quote Originally Posted by EuroxS4 View Post
    This or plug the hose from the washer tank going to the bumper if you have leaky headlight washers.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
