Results 1 to 19 of 19
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Purge air from coolant while system is full?
    So, I may have air in my coolant system due to the recent PLM kit install and not having access to a vacuum refill tool. Does anyone know if we can simply use the vacuum tool to remove coolant from the system while it's full or is it necessary to drain the coolant first.
    Tool I'm referring too: Coolant Refill/Air Purge Tool
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Apr 05 2016
    Portland, OR
    Have you tried using the bleeder screws on the SC?
    There's another one under the plenum cover as well.
    Geoff
    Sep 20 2006
    MD
    Yeah, I've tried that method as well. Now, which other under the plenum are you referring too?
    Apr 05 2016
    Portland, OR
    Geoff
    Sep 20 2006
    MD
    Here? Sorry but I'm not sure I'm following.
    Mar 21 2015
    ^ That's not the last bit of the post
    Sep 20 2006
    MD
    Still mentions nothing about a bleed screw under the plenum. I only know of the 2 on the supercharger
    Apr 05 2016
    Portland, OR
    Sorry, guess it is just a hole not a screw.
    My loops is divorced so I never actually performed that step when bleeding mine. Excuse my ignorance.
    Geoff
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    How do you know that you have air in the system?
    I got my supercharger to bleed. I didn't even have to give the car revs. Just make sure you're on flat ground.
    -DL
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
    Sep 20 2006
    MD
    I ran a few logs and the IATs were in the mid 50s Celsius on a 70 degree F day and I'm sure the kit should due much better to reduce IATs than that.
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    Quote Originally Posted by RLB6 View Post
    Were you driving spirited at all? My car got up to 65 Celsius while doing pulls when I was just single pulley E85 with HX.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    "Under the plenum cover" means the black plastic "leaf guard" cover between the base of the windshield and the forward firewall. Under the cover are the heater hoses. There is a bleed hole on the upper hose, where is slides onto the metal mating nipple. Loosen the hose clamp and pull the rubber hose back about an inch or so till the hole is exposed, and then the air can be bled out.
    If you are going to use the vacuum fill tool, you will have to dump all the coolant out first, and then pull vacuum, then refill.
    Sep 20 2006
    MD
    Yeah, I've bled the heater hoses as well. I was hoping to be able to vacuum the coolant out then fill again.
    Sep 20 2006
    MD
    Quote Originally Posted by LittleDozer View Post
    Ok so my IATs would be normal? Hmm. Just thought hat was pretty high for having an upgraded HX.
    Senior Member Two Rings Turbocoop's Avatar
    Jun 08 2014
    Charleston, SC
    When bleeding my system I couldnt get coolant fully flowing through those two hoses at the firewall even after the T-stat opened until I held the RPMs at about 2K for 3-5 minutes. After that it was easy to bleed through the small hole on that upper hose...
    Feb 20 2006
    NC
    Hmmmm. I Just bled the coolant from the top of the HX and kept the heat on high. Never messed with the S/C or heater hose. Usually air the system is pretty obvious when you turn the heat on max, it will not blow hot when the heat passes through.
    2021 BMW M340i
    2021 Tesla Model Y Performance
    GONE - 2019 RS5 Sportback
    GONE - 2021 Audi Etron
    GONE - 2019 Audi Sq5 - JB4 Rev9 intercooler
    GONE- 2013 S4 DSG - DP stage 2 EPL
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by scottycs View Post
    I did this too but not all of the HX's have a bleeder screw on the top.
    Geoff
    Feb 20 2004
    I ran mine and allowed the car to idle with the heat on high. Make sure the car is flat on the ground.
    I idled the car with the coolant overflow cap off, and opened up the following bleeders:
    Res-tank/pump (fills first in the fenderwell)
    Heat Exchanger (fills second)
    Supercharger (both screws, fills last)
    Worked for me.
    -DL
    Previously:
    Sep 20 2006
    MD
    I'm definitely not having any heating issues as it blows hot quickly in the cabin. I guess I'm just imagining the IATs would be a bit lower than what I've seen. When I finished the install, it took nearly 2 gallons of G12/water to get the levels back to normal.
