Results 1 to 10 of 10
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    ? About inner xenon bulbs
    So i was curious when i did the j code mod on my bi xenon swap there were these tiny orange bulbs inside that i am assuming are the innner turn signal bulbs. I was wondering if its possible to replace these tiny bulbs with a clear white bulb?
    Has anyone done this I couldnt find any threads on this cuz I wasnt exactly sure what to search for I am not sure what bulb it is or if its replaceable I assume it is?
    Sent from my SM-G920T using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by A4QuattroV6 View Post
    Some info here, if you mean turnsignal bulbs:
    http://www.audizine.com/forum/showth...=1#post7983795
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Jan 16 2011
    Earth
    I cant tell what their talking about the corner turn inricator or the inner bulb. Theres 2 I was referring to the onr on the inner part of the headlight not the bulb for thats behind the lense for the j code mod on the corner.
    Established Member Two Rings Iridium.'s Avatar
    Nov 07 2012
    Okanagan Valley
    Why not look into a switchback LED for the turn signals? It's white when you're not indicating to turn, and orange when you are. There's another member here who did that mod. You can find out more about it here.
    Jan 16 2011
    Earth
    Interesting. Thanks for the info. I think i'll pass on taking a dremel to my headlights. I'm too OCD for something like that. I guess the bulb is just not your typical bulb so there isn't a white replacement for it other than doing a mod like that.
    Nov 18 2016
    Lehigh acres Florida
    What's the j code mod for the bixenon's ?
    Oct 21 2012
    Earth...
    Quote Originally Posted by paulxxwall View Post
    http://www.audizine.com/forum/showth...ont-reflectors
    Nov 18 2016
    Ah ok anyone knows kelvin temps on oem Xenons and can you swap ?
    Jan 16 2011
    Earth
    Can you swap what? Halogens to xenons? Yes. Xenon bulbs in a halogen no.
    Temperature isnt whats important. Lumens are. The higher the temperature the lower lumens you will have. The best bulbs are osrams CBI (cool blue intense) in my honest opinion... they have a slightly increased temperature while still retaining good output and habe a nice white with slight blue tint. Be careful for cheap knock offs though on ebay. A genuine set isnt cheap.
    Nov 07 2012
    Okanagan Valley
    As that was done a couple of years ago, there may be a switchback replacement bulb for the turn signals. It may be worth looking into!
